Page 313 of 775 FirstFirst ... 213263303309310311312313314315316317323363413 ... LastLast
Results 6,241 to 6,260 of 15487
    Oct 2011
    #6241
    Naka! Haven't checked mine.
    Diba medyo asa baba na yun?
    how do you check the whole belt?
    pede ba siya hilahin to rotate manually so i can check the whole belt?
    Sir, masisilip mo lang ung portion ng belt sa bandang ilalim, dun mo makikita tiny cracks, ung sa other side ng belt (top side) wala ka makikita na crack dun. kung tatangalin mo, kailangan luwagan muna tensioner and then mabaklas mo na buong belt mahirap lang sir pagkabit nun.
    #6242
    Naku sir hindi ko na papangarapin baklasin.
    Pa-check ko na langs a mechanic.
    #6243
    yung sa akin, wala kang makikitang crack kahit maliit.... nong tinanggal doon sa casa doon lang napakita sa akin na may crack na maliit... di ko ma gets.
    Oct 2011
    #6244
    normal lang cguro ung mga crack na maliliit due to wear and tear wag lang malaking cracks afaik. pero to be safe, have it change na lang. im just not sure ung typical na odo reading bago palitan ito kasi nakalagay sa manual ay timing belt lang.
    Jan 2012
    #6245
    good afternoon.. sino po nakasubok na tanggalin yung cylinder head cover ng 1tr-fe? pag ibabalik na, kelangan ba bumili ng gasket (P/N: 11213-0C010/11214-0C010) o pwede kahit lagyan na lang ng gasket sealant? may konting leak kasi sa exhaust manifold side nung cover kaya kailangan ko icheck kaso di ko agad maibalik since for order lagi kasi yung mga parts.
    TIA
    Jan 2013
    #6246
    hello mga ka innova..
    question lang po.. meron bang AC cabin filter ang innova natin? Paano ba nililinis yun kung meron man?
    maraming salamat..
    Jan 2010
    #6247
    Quote Originally Posted by homhomnova View Post
    maraming salamat..
    meron model 2010 up may cabin filter... can be found behind the lower glove compartment.... work on one side of the compartment first, pull it carefully until lumabas yung ear stopper... then do the same opposite side... nung nagpalit ako ng cabin filter i tried washing yung luma para may spare ako, but sobra na itim di ko na mapaputi... so nabili na lang ako ng new from casa 900 pesos ...
    Sep 2011
    #6248
    bakit yung left wiper ko ,ang panget mag wipe parang hindi ganun kadulas yung goma sa winshield , ganun din yung rear wiper ang pinag kaiba lang maingay mag wipe yung likod :hammer:
    Jan 2013
    #6249
    Quote Originally Posted by Capsaul View Post
    maraming salamat sir sa reply.. gaano katagal bago ka nagpalit ng cabin filter?
    Feb 2013
    #6250
    Quote Originally Posted by 1natzt View Post
    TIA
    Di lang yung cylinder head gasket ang dapat mo palitan, pati yung gasket ng sparkplug. 1k ang set nyan sa toyora, PhP 600 yung sa cylinder head at PhP 400 yung sa sparkplug, meron sila stock dun.
    Kung nag leak na, dapat na nga yan palitan.
    Oct 2011
    #6251
    Sir, ung 2009 below wala ba nyan?
    Feb 2013
    #6252
    Meron paps, 2008 yung sa akin, meron ng cabin filter.
    Not sure sa 2007 models.
    #6253
    By the way sa mga medyo may edad na yung innova.
    OEM pa din ba gamit niyo air filter?
    i think so, since it came with the car from the factory, way back in 2005. hinihipan lang ng hangin at hinuhugasan ng sabon at tubig para luminis..
    mahal kasi kung papalitan, e..
    Oct 2011
    #6254
    Huh? Pwede ba hugasan un sir? Pagka alam ko disposable kasi un.... Meron ung sakura na air filter half the price of oem.
    #6255
    why dispose of it when you can easily wash it clean? mura lang tide and water.
    fuel filter, oil and oil filters lang ang one-use only sakin..
    Oct 2011
    #6256
    okay sir, try ko i-wash next time.
    #6257
    Madaling maglaba... Mag-aral ka muna kung papaano tatanggalin, bro.
    19.2K:book:
    Aug 2006
    #6258
    TIA
    I have done this twice already, bought the inner and outer gasket and did not put gasket maker (sealant) and it leaked.
    Solution: put gasket sealant.
    Take note: the original setup has sealant, if you look at the cylinder lip it has a slotted/uneven surface near the power steering fluid reservoir.
    Jan 2010
    #6259
    15,000 PMS ko pinapaltan ko na, ang itim na kasi, pwde nga siguro wash and dry, try ko ulit i kula with bleach yung spare ko, last time na nag tanong ulit ako nasa 1,300 pesos na grabe lalo namahal....
    Jan 2010
    #6260
    last sunday from car park incline kasi ang pa exit, i approached the incline on 2nd gear, di pa sya nangangalahati sa inclined ramp kinapos ang innova ko, kapos to the point na tumigil sya halos midway...straight naman yung ramp pero kinapos talaga, at madami pa ako kasunod sa likod...i applied the hand break
    then shifted to 1st gear... then pressed the gas pedal almost to the metal then depressed the handbreak,,, after the climb may naamoy ako na parang sunog na goma or break lining ...inside the cabin medyo kinabahan ako what caused the smell, ano kaya sa tingin nyo, nawala naman after a while and wala naman kakaiba sa takbo after that incident... Ride is innova G gas....yung carpark is Remington Hotel sa may paranaque..
    sa MOA carpark i can use 2nd gear climbing its spiral ramp to carpark.
    survey nga tayo whats the best carpark in metro manila...
    for me yung new carpark ng Solaire no. 1 ... the best so far kasi libre pa hehehe
Toyota Innova Owners & Discussions [continued 3]
