Page 267 of 775 FirstFirst ... 167217257263264265266267268269270271277317367 ... LastLast
Results 5,321 to 5,340 of 15487
    Oct 2011
    #5321
    What do you mean by that sir? lalabas na ng new model?
    Aug 2010
    #5322
    TMPI style - slowly bring out the goodies little by little each year. Generally, Toyotas are most loaded at the end life of the model ie. Vios SE Limited, 1.3G, 1.3 J Limited, etc..
    All these upgrades are a sure sign that this Innova is really on its last leg now.
    its about time. ang tagal na ng innova design na yan.
    #5323
    mga sir tanong lang..dati kasi may sasakyan ako mazda 323 pag aalis ako pinapacheck sa akin lagi yung tubig nun baka daw kasi matuyuan at mag over heat... nung bumili kasi ako ng innova tinanong ko dun sa ahente kung san tutubigan ung makina..natawa ung SA sabi naku sir di na po tinutubigan yung mga makina ngayon yung mga luma lang po.so ang tanong ko wala na ba talagang ilalagay na tubig? pasensya noob thanks and more power
    #5324
    Quote Originally Posted by yakuini12 View Post
    coolant po ang nilalagay sa radiator pwede namn po distilled water ...paki check po nang owners manual nyo nandun po yung info na hinahanap nyo sir ;)
    May 2005
    #5325
    Just monitor the coolant reservoir when the engine is still cold (not yet started) in the morning. Level should be near "high or full" line. Even then the level will not go down significantly. If there is a need to fill up everyday then its a sign of leakage in the system.
    Note: Coolant level goes up after the vehicle has been started up and used.even on short trips.
    Only use the pink colored coolant for top up. Don't top up with water as this dilutes the coolant.
    May 2005
    #5326
    Quote Originally Posted by trucker111 View Post
    Exactly! 2004 pa in Thailand and Indonesia. Dito sa pina since 2005.
    Feeling ko next year 2014 or 2015 bago ilalabas ang all new body innova dito,
    #5327
    baka hindi na INNOVA ang name... ano kaya?
    #5328
    salamat sa reply mga sir. ;)
    Aug 2010
    #5329
    OT
    i was told by a mechanic not to use coolant. nakakasira lang daw ng radiator. water is enough.
    any comment?
    Oct 2011
    #5330
    OT
    any comment?
    Some of the properties found in coolant includes anti rust, anti boil and anti freeze. Water alone couldn't do that.
    May 2005
    #5331
    OT
    any comment?
    I also hear this from time to time, usually from old school mechanics.
    There is also a reason why auto manufacturers use coolant (instead of just water) as their factory fill for all the radiators that they use/produce.
    Sep 2011
    #5332
    Quote Originally Posted by kristine123 View Post
    Innotang hehehe :hysterical:
    Oct 2011
    #5333
    may nakita akong photo na may 'innotang' emblem sa innova. lol.
    Sep 2008
    #5334
    As in pure coolant lang ilagay sa Innova? Ilang liters po capacity ng radiator?
    Aug 2010
    #5335
    OT
    any comment?
    kaya advice ng mechanic na wag lagyan coolant para di sila mawalan customer, plain water more prone to rust so babalik ka ulit sa kanila hehe.
    Dec 2007
    #5336
    Sana magdilang-anghel ka sir for 2014. One year after, i will be eligible for my new car plan. He. He. Sarap mag "ilang tulog na lang countdown" though matagal pa ang 720+ days
    Dec 2007
    #5337
    Quote Originally Posted by mumuy View Post
    You can buy the pre-mixed coolant sa casa. The manual will have information on total capacity, tingnan mo na lang.
    Feb 2013
    #5338
    gud pm. un nga rin ang sabi sa akin n nag palit ako ng water pump un raw ang cause kaya nag leak. pink coolant p rin ang gamit ko. BTW bro, ask ko rin ung check engine kung na experience mo n sa innova mo? pls. advise
    May 2005
    #5339
    NOT pure. It should be PREMIXED (meaning it has the right ratio of pure coolant mixed with distilled water mixed together from the factory).
    I just buy the Toyota labelled premixed coolant from the casa. A small jug will last you a long time (provided your vehicle doesn't suddenly develop a leak).
    May 2005
    #5340
    Quote Originally Posted by boyblues View Post
    CEL or Check Engine Light always "on" could mean a lot of things. It is better to take it to the CASA and have them diagnose.
Toyota Innova Owners & Discussions [continued 3]
