Page 262 of 775 FirstFirst ... 162212252258259260261262263264265266272312362 ... LastLast
Results 5,221 to 5,240 of 15487
    Oct 2011
    #5221
    Quote Originally Posted by trucker111 View Post
    dami rin pala.
    what oil do you use? ok ba ang Top 1 SDO or Delo 400 sa Innova 2.5g?
    btw CI or CI+ ang rating ng engine ng 2.5g?
    Sir ung CI or CI+ rating ng oil yan, not the engine. Both are good oils, preference mo na lang sir if you will go with a synthetic or mineral.
    #5222
    Hi! balak ko po kasing bilan ng seatcover yung innova E ko, ang presyo sa Seatmate 8,500 tapos ang sa Toyota Leatherette Cover nila 9,600 w/ 10% discount so 8,640 na lang....
    ano po kaya ang mas maganda? sino po ang naka toyota leatherette dito? kamusta po ang quality? nalilito po kasi ako kung ano sa dalawa ang pipiliin ko
    Oct 2011
    #5223
    Quote Originally Posted by karai View Post
    For me, okay din naman workmanship sa seatmate. I drop by there yesterday when i was in terminal 4 malapit lang kasi.
    Aug 2010
    #5224
    saan yang exact location ng seatmate?
    contact nos?
    Oct 2011
    #5225
    contact nos?
    Ung branch nila dito malapit sa terminal 4 nasa kanto lang ng domestic rd and andrews ave.... wala ako contact no. nila, check mo na lang sa website nila sir.
    Jul 2012
    #5226
    pros and cons sir ng synthetic to mineral? and which is better and you prefer?
    Jan 2011
    #5227
    Quote Originally Posted by millean View Post
    Check your owners manual. Innova Recommended oil for Gas: 5W-30 or 10W-30 or 15W-40, 20W-50 API SL. Recommended for Diesel: API CF-4, CF, CD, or CE. Diesel needs CF ang API spec kahit obsolete na yong spec na yan kasi nga due to our high sulfur content (500ppm) ng diesel fuel dito sa atin. Mobil 1 synthetic 10W-30 has API SL and SM for gas and also API CF for diesel.
    Oil Spec website oilspecifications.org - Lubricant standards and specifications
    #5228
    Quote Originally Posted by vic2rem View Post
    Pero pansin ko ang toyota they are using 5w-40... for fully synthetic... wala sa recommended oil... same lang ba yan sa 15w-40?
    Aug 2005
    #5229
    This thread >>> http://tsikot.com/forums/engine-fuel...nthetic-80632/ will yield the answer/s for you.
    May 2005
    #5230
    Quote Originally Posted by kristine123 View Post
    Better cold weather performance (esp. during initial startup).
    Aug 2010
    #5231
    para hindi OT, i'll post my follow up question on this thread
    #5232
    ang 5w-30?
    or 5w-40?
    May 2005
    #5233
    ang 5w-30?
    or 5w-40?
    5W-40.
    The lower the number in front of the "W" the better for cold weather. At 5 C it would operate like weight 40. Some people claim we don't need multigrade oils in this hot country.
    Jan 2011
    #5234
    Synthetic is still the best for Innova Gas. Maganda ang low viscosity kasi improve ang fuel economy. That's why mga Toyota or Honda sa US ngayon ay 5w-20 ang recommended oil. Check your owners manual. Innova recommended oil pag below freezing 5W-30, siguro sa northern India kasi malamig. Due to our tropical weather, 10W-30 ang recommended. Hirap humanap ng 10w-30. Honda casa sells 10w-30. Mobil 1 dito sa atin is only 5w-40..... I posted this before. Ask someone from US to buy you three 6quart boxes na Mobil 1 10W-30 good for three 10K PMS na yan. 6quarts would cost $38 from COSTCO(parang S&R) or sa Walmart. Bili ka rin ng Toyota Oil Filter 90915-yzzd1 or 90915-yzzg1 sa ebay or any toyota online stores sa US. 10 oil filters is only $45 yata yon. Pa balikbayan box mo lahat and every 10K PMS sa dealer that would accept your own oil and own toyota filter. No need to do every 5K PMS pag gas. Base sa experience namin, Pasig allows your own oil, oil filter and iridium plugs and Pasig will NOT void your warranty kung not every 5k ang PMS. Labor na lang babayaran mo sa dealer which would be around P1,500 every 10k PMS. Tapos after the 3 year 100,000 warranty, sa petron or caltex na lang pa oil change for P300 labor.
    Dec 2009
    #5235
    Im using 10w 30 Royal Purple for my innova vvti. Correct si Vic2rem sa Toyota Pasig pwede magdala ng oil and oil filter na d ma void warranty, dun din ako nagpapa pms.
    Oct 2011
    #5236
    Basically ung OCI ng synthetic ay mas longer comapred sa mineral generally speaking.
    Jun 2009
    #5237
    Out warranty na po innova ko. Model 2009? 34k na po odo ko. Safe na kaya kung out of casa ma tuneup change oil ko?
    Advise naman po mga gurus.
    May 2005
    #5238
    Quote Originally Posted by desertfox615 View Post
    Its safe as long as you take it to a trusted reputable shop that would use the right type of oil and oil filter.
    Otherwise, stick with casa.
    PS: casa price for oil change sometimes cost less than what the shop "s" charges. fyi,
    Oct 2011
    #5239
    pag change oil lang naman, okay lang.... common lang kasi.
    May 2012
    #5240
    Mga masters and experts pa advice naman. I had my 65k PMS at Toyota Cubao last sat and i was informed na need ko na ireplace mga ito:
    1. Clutch components (19k estimate nila)
    2. Rack End (4,500)
    3. Brake Pad (2,500)
    Kailangan ko po ba palitan ang clutch components and rack end immediately? baka naman po meron po kayo alam na shops na mahusay gumawa baka makamura po ako? and san po kaya mahusay mag palit ng brakepad? actually hesistant ako sa casa magpagawa bukod sa mahal, baka d naman talaga sira yung mga parts.
Toyota Innova Owners & Discussions [continued 3]
