Page 582 of 662 FirstFirst ... 482532572578579580581582583584585586592632 ... LastLast
Results 11,621 to 11,640 of 13229
    Aug 2005
    #11621
    Sirs,
    Please patulong naman hanggang ngaun hindi pa tumatakbo ang innova ko! taga de castro kami nalubog talga cya! Bumili na ako ng new ECU (40K) tapos pinacheck na injector ok naman daw! Sabi ngaun ng mekaniko mukhang grounded kc pumipitik daw un parang butterfly(hindi ko alam tawag dun kc nandito ako sa saudi bayaw ko lang nagpapagawa) kahit walang susi. Ang hinala ng mekaniko baka daw ung mga fuse sa ilalim ng manebela, kaya ayaw umandar...
    baka meron naman dyan same experience pahelp naman po mga sir, o kung anu pang pwedeng maging sira... apprecite po ang tulong nyo.. email ko po jveslabra*gmail.com
    Oct 2009
    #11622
    Hi guys! anyone here selling or knows where I could buy an instrument panel gauge automatic for 2005 up innova or fortuner, aircon climate control switch and aircon amplifier for 2009 innova v? thanks guys! second hand will do.. please text or call me 09228869795
    Oct 2008
    #11623
    Hi to all,
    I noticed that after my 20T KM check-up with the Toyota Service Center, my radiator's coolant is not full. Can anyone tell me if it is just ok or not? As per my service billing which cost me Php 9,535.65, below are the description of works done in the check up. Thanks for your input/s.
    1. Inspected the ff:
    - Drive Belts
    - Engine Coolant
    - Exhaust Pipes and Mountings
    - Battery
    - Air Filter
    - PVC Valves, Ventilation Hoses & Connections
    - Brake Pedal & Parking Brakes
    - Brake Pads & Discs
    - Brake & Clutch Fluids
    - Brake Line Pipes & Hoses
    - Power Steering Fluid
    - Steering Wheel & Linkage
    - Drive Shaft Boots
    - Ball Joints & Dust Covers
    - Transaxle / Transmission Oil
    - Front & Rear Suspension
    - Tires & Inflation Pressure
    - Lights, Horns, Wipers, & Washer
    - Air Conditioning
    - Water Sedimenter
    2. Cleaned & Adjusted Brake Lining and Drums
    3. Lubricated Propeller Shaft Grease Lubrication For IMV
    4. Tightened Bolts & Nuts on Chassis & Body
    5. Repacked Wheel Bearing
    6. Replaced Engine Oil & Filter
    7. Road Test
    Oct 2008
    #11624
    By the way, I am referring to the engine coolant's reservoir (as not full) and not the radiator itself.
    Toyota did not inform me that it needs to be filled up. I don't know what kind of inspection they did on the engine coolant.
    Dec 2009
    #11625
    Quote Originally Posted by pugee View Post
    Sirs,
    maganda gawin dyan kung grounded pa check mo na lang sa auto electrical para sigurado ka. kung alam mo yung rey auto electrical shop sa may d. tuazon, marikina near sta lucia mall ok dun saka may technician sila na pwede mag home service. look for louie or bitoy.
    Jun 2006
    #11626
    di naman dapat full ang coolant reservoir. Dapat nasa Full mark lang, which is nasa 3/4 lang ng container.
  7. #11627
    guys badtrip ang araw ngayon,
    saan kaya makakabili side mirror for '09 innova? di ung buo, ung mirror lang, ung madaling sikwatin
    salamat!
    marikina o alabang area sana
    madami na ako tinatawagan pero panay wala
    last resort ko banawe at casa,
    hehe salamat!
    Aug 2006
    #11628
    Quote Originally Posted by innoBOB[09JmtG] View Post
    salamat!
    hehe salamat!
    [/IMG]
    Since isa lang ang kailangan mo, Banawe or Evangelista lang ang choices mo.
    Aug 2009
    #11629
    good day ka innova owners. ask lang ako, if its ok that I had run my innova naka handbrake pa cya. pero short distance lang i think 30 feet lang hindi ko kase na notice naka handbrake pa cya meron nag bosina sa ligod ko. thanks
    Aug 2006
    #11630
    Quote Originally Posted by annika View Post
    Kung gumagana pa naman yung hand brake okay pa yan. Napudpod lang ng konti yung brake shoe mo sa rear wheels.
  11. #11631
    Quote Originally Posted by Mile2 View Post
    any recommended shops in banawe?
    ung evangelista saan yun?
    thanks!
    Aug 2006
    #11632
    thanks!
    Ng magpa-install ako ng mud guard sa AutoBacs Banawe nagpahanap na rin ako ng side mirror dahil nanakaw yung sa akin. P1,000/pair yung nakuha ko na side mirrors. AutoBacs near corner Banawe and Quezon Blvd, malapit sa McDo. Marami yang mga side mirrors ng Innova dahil pareho lang yan sa Fortuner at Hilux. Dahil isa lang naman ang kailangan mo, sigurado di ka makakakuha ng isa lang sa casa.
    Sa Evangelista marami din doon, magapahanap ka lang sa mga mokong doon. Yung buong street ng Evangelista puro car accessories at surplus doon. Evangelista sa Pasay.
    Oct 2008
    #11633
    Quote Originally Posted by shibby75 View Post
    Thanks sa reply. Nasa full mark nga siya ng ma-check ko mismo. Sinabi lang kasi sa akin ng driver ko na di daw full yung coolant level. Baka di lang niya napansin yung full mark sa coolant reservoir.
    Dec 2008
    #11634
    Quote Originally Posted by ajOT View Post
    currently po what I am using is Castrol Magnatec (synthetic)
    sir, ang ginagawa ko po kasi every changing of oil, I make it a habit to do flushing to remove the residue from the previous oil... kasi po kung hindi ako nagflushing, despite my oil is new or a week old, maitim na kaagad, kaya nag-flushing po ako every change oil....
    pero pre masama ang palaging flushing mababawasan ng lubricant ang makina mo at mas mabibilis ang wear and tear....ung kotse ko ganito ginagawa ko complete drain ng lumang langis then iflush ko siya ng ordinary oil and let idle for 10 min. then drain ko ito then lagay ko na talaga ang gusto kong langis, just my opinion sir...thanks
  15. #11635
    may nakita ako number sa directory 911 2222, autobacs, wala sagot
    eto ba number nila
    bukas ba banawe pag sundays?
    salamat
  16. #11636
    tumawag ako autobacs, wala daw sila nun hehe, ang dami kong tinawagan sa banawe, madalas no answer
    may isang shop na meron 400 pesos daw lens lang. patusin ko na ba un?
    paano palitan lens lang? naka adhesive lang bayun?
    di daw kasama ung bracket para kumabit sa body ng side mirror. lens lang mismo
    salamat!
    ideas on how to DIY if lens lang papalitan?
    Feb 2004
    #11637
    Alam ko may mga shops na bukas pag sundays pero not all. I suggest you call them up first to confirm they are open. You can canvas for prices too.
    Magkano ba resale value ng Innova E ngayon? Model 2005 up. What if medyo mataas na odo reading nya at 70-80K km, malaki ba ang diperensya sa presyo at performance?
  18. #11638
    ^ty bro call mode talaga muna
    Aug 2006
    #11639
    salamat!
    Pag lens lang di yan puede, baka cut-out lang yan. Pag cut-out panigurado flat lens lang at mahirap gamitin. Meron akong cut-out lens naka-adhesive lang, pinalitan ko na rin ng original kasi mahirap gamitin.
    Yung original kasama yung bracket/enclosure at nakaumbok ang lens, ito ang hanapin mo para original pa rin at siguradong maganda ang reflection. Pag original ang nakuha mo, snap-on lang yan, wala ng adhesive.
  20. #11640
    ty dito hanap ako ung orig, lens with bracket,
    dapat pala dalhin ko salamin dun
    swak ba talaga fortuner side mirror sa innova?
Toyota Innova Owners & Discussions [ARCHIVED]
