Originally Posted by
first_light
Hi to all,
I noticed that after my 20T KM check-up with the Toyota Service Center, my radiator's coolant is not full. Can anyone tell me if it is just ok or not? As per my service billing which cost me Php 9,535.65, below are the description of works done in the check up. Thanks for your input/s.
1. Inspected the ff:
- Drive Belts
- Engine Coolant
- Exhaust Pipes and Mountings
- Battery
- Air Filter
- PVC Valves, Ventilation Hoses & Connections
- Brake Pedal & Parking Brakes
- Brake Pads & Discs
- Brake & Clutch Fluids
- Brake Line Pipes & Hoses
- Power Steering Fluid
- Steering Wheel & Linkage
- Drive Shaft Boots
- Ball Joints & Dust Covers
- Transaxle / Transmission Oil
- Front & Rear Suspension
- Tires & Inflation Pressure
- Lights, Horns, Wipers, & Washer
- Air Conditioning
- Water Sedimenter
2. Cleaned & Adjusted Brake Lining and Drums
3. Lubricated Propeller Shaft Grease Lubrication For IMV
4. Tightened Bolts & Nuts on Chassis & Body
5. Repacked Wheel Bearing
6. Replaced Engine Oil & Filter
7. Road Test
