Maintenance free battery siguro for G &/or E variants only. My battery for J-variant is not maintenance free. I think it's Oriental 2SM Turbo - not sure. I-check ko rin mamaya.Originally Posted by Innova_Boy
Varta maybe the best. But, the local batteries are as durable as the imported one. Before, I used Delco (twice) and they both lasted for more than 2 years. The last that I used for my Corolla was Oriental maintenance free - more than 2 years din ang inabot. So ang ni-replace ko is another Oriental maintenance free - battery (free delivery pa sa bahay). Pinagkaiba lang ng Delco & Oriental ay ang warranty period, 2 years for the former and 13 or 15 months for the latter.Originally Posted by busy road
So that's good. At least 10Amps ang fuse niyan.Originally Posted by Innova_Boy
About the battery, sealed type pala ang naka-installed. I don't have to bring my hydrometer anymore. That's the only problem with sealed type. We can't measure the state of charge using hydometer for all 6-cells. So, the only way is to measure the total voltage accross the terminals while disconnected.
For all who are interested, these are the values that represents the condition of our battery:
- Condition--Sp. Gravity---Total Voltage
---100%----------1.265-------------12.7
----75%----------1.225-------------12.4
----50%----------1.190-------------12.2
----25%----------1.155-------------12.0
--Discharge-------1.120-------------11.9
2-years in service OK na iyan. That's the normal lifespan of the car batteries.Originally Posted by geebunny
Do you know that the life span can be increased to 3 to 4 years? Yes, it's possible.
Normally when we replaced battery, we directly installed without proper charging. We just rely on our alternator...Right? First battery charging is VERY IMPORTANT. Parang eggplant na kapag hindi tama ang pagkaluto, tumitigas iyan. Then, kahit anong gawin mung luto after, sira na iyan. Same with our batteries. So, be sure to charge your battery using portable charger.
If you are using constant current charger, try this:
Example:
1. Battery is 50Ampere-Hour. Charge it with constant 5 amperes until the voltage reached 14.4V. Then decrease the charging current to 2.5 amperes. Complete charge battery can be noticed when the voltage reached a voltage of 15.6 to 16.2 without further increase for the next 2 hours. Additional information can be achieved if your battery is flooded type were you can measure the specific gravity of all cells at maximum 1.265 to 1.270.
2. Once every month, charge your battery using portable charger at 13.8 volts overnight even it is known to be good.
3. (For flooded type battery)Never let your plates exposed to air. Always add distilled or deionized water to top up to maximum.
I can assure you, following the above tips will lengthen the life of you batteries.
Re: thermocooler..
just want to ask kung how low temp ( say 15 degree celsius ba ) ang kaya niya i-maintain inside the cooler?? so how effective is this to properly cooll your drinks or whatever..
SO ibig sabihin, dapat frozen na coke in cans mo bago mo ilagay dun sa thermocooler??
WBR,
Innova boy, When I first got this thermocooler I pluged it in and tested it right away. Was also eager to find out the lowest temp it can attain and so I put in my clock thermometer inside and after 15 mins check the temp and it is 5ºC . The manual says it can lower the temp 20ºC from ambient temp. If you will be on a short trip it is best to place cold drinks but not necessarily frozen. But the way i use it in my room as a refrigerator I just put in even room temp drinks and enjoy it after 2 hrs thereafter. You can check out thermoelectric cooler at google and find interesting topics about it.Originally Posted by Innova_Boy
Hello once again fellow INNOVA fans! just want to know if any of you had their sound system upgraded na... para kasing napaka plain naman ng HU natin , any head unit na pwede dun or pwede din kaya yung 1 dinna pioneer? how about the speakers? how about AMPs and SubS? thanks!
about car batteries, i had this good experience of buying this obscure battery brand about 3 and a half years ago for my old car. the brand is incoe. bought it somewhere in paco, manila. it is 2SM in size and packaged in translucent white plastic casing, kind of you can see the electrolyte level . when i bought it i was surprised to see it has no electrolyte yet in it. the store owner told me he would fill it w/ electrolyte and have it electrically charged for at least 30minutes. so there it went. It was installed in my car and I paid something like PHP1,300 back then. The thing is THAT BATTERY is still working up to now, going on its 4th straight year!!! I can't believe that obscure and rather inexpensive battery can outlast my previous car batteries which cost way above !!! in the past 3.5 years i just topped it up w/ distilled water whenever i see the electrolyte level slightly dip from the prescribed level. I recommend you try it. or at least find a battery and battery store where they only pour the electrolyte upon purchase. I guess that partly explains the long life of the battery.
Originally Posted by accs
gusto ko din pa upgrade ng sounds. But seems that nowhere to put a bigger subs. I've got a 12" subs lying at home. Dati gamit ko to sa Adventure ko. The only space for the subs that I can see is at the rear.
Bro, perfect ang battery mo. Kainggit ka. That's right, if you maintain it the way I've mentioned, you can still increase the lifetime.Originally Posted by eric
Normally kasi, buffer operation ang function ng mga car battery. Meaning, the maximum current rating of the alternator is exceeded by up to 20% when additional load like power booster amplifier ( increasing the sound power output) & most of the time night time driving habbit with AC working. These are just the basic loads example that 20% power from the battery is being taken.
This is a good explanation for long life span batteries.
If we can lessen the loads in which the alternator can do the job alone without asking additional power from the battery, for sure the maximum lifespan of the battery can be achieved.
About battery charger's price, I don't know the price now. The last thing I still remember when I first left, US$ 1.00 = PhP 7.00, hehe.
Mga Bro, if you are interested with the charger, you can do it youself. These are the basic parts:
110-220 / 12V-0-12VA Transformer - at least 5 amperes rating at the secondary
2 pcs. diodes rated 10 amps connected full wave.
That's all, no need capacitor. You don't need regulated charger as this is used for overnight only. Most probably di mauubos ang PhP 500.00
Take note: this charger can't be used for totally discharged battery. It will be used only for equalizing charge for your battery. But if you want more powerful charger, replace your tranformer to a higher rating, say 20amps ang higher diode rating.
The one I am using right now is only 5 amperes.
Bro, the basic requirement for good quality sounds is how you can reproduce the sound frequencies from 20 hertz to 20 kilohertz. This will start from your player up to your speakers. Both player & speakers should be matched for a clear & crispy sound. The higher the power, the better. I can give you tip on how to design your speakers. ( Copied from my thread in car electronics)Originally Posted by bongliza
Ported Box vs. Closed Box
Ported box is a type of bass speaker enclosure that the desired resonance frequency can be tuned. Port is usually in the form of PVC tube that the length & diameter are to be considered. Diameter has to be determined to prevent undesirable noise due to air pressure. The length however, shorter makes the frequency high & vice versa.
Closed box is a fixed enclosure that can't vary the desired frequency once it has built. For this reason, speaker parameters have to be considered in designing enclosure. These are: Fs = free air resonance frequency, Qt = magnification factor & Vas = equivalent air volume. It needs a lot of computations to calculate the optimum box enclosure based on the actual speaker parameters.
Generally, speakers with good quality magnets are designed for small enclosure. Locally made speakers' Qt are high which requires high volume to achieve desired bass frequency.
Additional pointers in choosing your speakers:
1. Look for higher coil diameters. These are usually designed for bass.
2. Select with high density or big magnet for lesser volume of your box.
Example Computation:
Given Parameters
Fs = 53 Hz
Qt = 0.452
Vas = 1.23 cu.ft.
Box Volume = 15(Qt)^2.87 x (Vas) = 15(0.452)^2.87x1.23 = 1.889 cu.ft
Box Frequency = (Vas/Box Vol.)^0.32xFs = (1.23/1.889)^0.32x53 = 46.2 Hz.
Conclusion: The optimum box volume is 1.889 cu.ft with resonance frequency = 46.2 hz.
Yang bang thermocooler puede ring maging heater instead of cooler??
Cause mine has this label instruction when you invert the plug connection eh magiging heater siya though havent tested it yet only the cooler..
WBR,
Puwede din food warmer or heater, sabi sa specs (65ºC) switch lang sa kabilang side.Originally Posted by Innova_Boy
With the rear seat in place, how much space does the Innova still have from the seat to the rear door? Sana lampas pa ng 12" para kasya thermocooler ko![]()
ung mga thermocoolers n warmers take a LOOOOONG time to actually cool or warm anything inside. binyahe ng kapatid ko sa V nya more than 2 hours halos walang kwenta. i tried leaving it on for 4-5 hours ayun lumamig na pero seriously u want to leave it on for 5 hours on ur car? baka di na magstart yan hehe
You cannot expect it to make things cold that fast like a refrigerator or heat it like an oven. Sabi nga sa specs, it is advisable to place cold drinks na before magbiyahe ka. Kung food warmer naman eh it will not boil or cook food just keep it warm.
mine is 10" width and can fit naman sa likod ng third row seats.. tinesting ko kahapon... if 12" i think will do also for sure....but problem you need to buy extension cord cause yung cord included is only 5 ft long.. so di abot sa likod dahil sa baba ng dashboard ang outlet or cig lighter natin...Originally Posted by beeper0358
WBR,
Thanks Innova boy, I think it will work! The cooler comes with a 6ft cord, plus what you describe 5ft cord provided. Puwede ko nang iuwi ang cooler ko he he he.Originally Posted by Innova_Boy
Problema lang eh sana dumating na unit ko, sabi ng agent one week lang after reservation nandiyan na eh mag two weeks na wala pa daw![]()
Puwede kaya i pullout reservation fee ko lipat ako kung saan may available, malamang umiyak ang agent
