Page 167 of 662 FirstFirst ... 67117157163164165166167168169170171177217267 ... LastLast
Results 3,321 to 3,340 of 13229
    #3321
    Quote Originally Posted by jimaroquai
    bongliza, ano brand, magkano at saan mo nabili yung dvd mo?
    generic lang and non-motorized pero it can kick like the branded ones. So far ok naman ang performance. Sa HK ko nabili. Meyrong 2x LCD Monitor sa headrest din with clamps. Mga P22,000.00 yata yun excl. yung dalawang monitor. See pics.
    Oct 2004
    #3322
    pips, tanong lang po kung saan pwede magpapalit ng busted tail light (isang taon pa lang busted na agad ang bulb) aside sa casa (might be expensive kasi) at magpa-check ng alarm. may times kasi na nag-alarm ang unit namin kahit na walang gumagalaw dito (di naman ganoon ka-sensitive alarm ng innova). last month twice na nangyari ito sa amin and its been going every month. TIA.
    #3323
    hi to all
    mine is d4d 3700 na nag odo. january 2006 ko lang kasi nakuha to. ask ko lang sa kung nababawasan ba ung coolant na pink sa reservoir? kasi ung sa akin umabot na sa minimum. nag add na uli . pero nabawasn uli. konti lang naman. wala naman akong makitang leak, ung sa inyo ba nababawasan din?
    Oct 2005
    #3324
    Yang coolant ng radiator di dapat nababawasan kng nababawasan at wala kang leak sa radiator or sa mga hose possible yan humalo sa Engine oil,galing sa cylinder gasket or water jacket . Just always monitor your engine oil level. Ang check the color of engine oil.Make sure na di tumaas ang level ng yng engine oil also check your tail pipe make sure wala kang usok na puti.okey Good Luck....
    Jun 2005
    #3325
    Quote Originally Posted by rav7118
    pips, tanong lang po kung saan pwede magpapalit ng busted tail light (isang taon pa lang busted na agad ang bulb) aside sa casa (might be expensive kasi) . . . . . TIA.
    Your unit is still under warranty so free-of-charge yan. Just bring it to your casa - just tell them premature parts failure. They should replace it for free. Pa check mo na rin yun alarm mo.
    Jun 2005
    #3326
    Quote Originally Posted by bongliza
    Sabi ko na nga ba ikaw yun bumili sa hongkong eh. Ang lupit ng set up mo. Entertainment system na! kulang na lang popcorn!
    Feb 2005
    #3327
    Quote Originally Posted by jaeger
    AFAIK, di kasali sa warranty ang mga bulbs ata....
    BR,
    epic
    Oct 2004
    #3328
    Quote Originally Posted by Innova_Boy
    BR,
    epic
    kung di libre ang bulb eh di may bayad din ang pagpapalit nito sa casa? saan kaya sa banawe pwedeng bumili ng ganitong bulb at magpapalit. pa-post naman po ng pangalan ng refutable shop at contact numbers. may experience na po kasi ako sa dating ride na di maganda ang pagbabalik ng lights sa banawe kaya nag-moist. thanks pips for the comments.
    Jun 2003
    #3329
    hey guys.... May ABS/EBD at ilang airbags ang G version? thanks!!!!
    May 2005
    #3330
    No ABS, Airbag driver's side lang. EBD diko alam. what is EBD?
    May 2005
    #3331
    Quote Originally Posted by larshell
    [SIZE=4]E[/SIZE]lectronic [SIZE=4]B[/SIZE]rake-force [SIZE=4]D[/SIZE]istribution.
    Apr 2005
    #3332
    Quote Originally Posted by lexus
    talagang when you reach 100 an increase of noise level will be observed because of turbo kick off. not sure with the excessive vibration
    It could also mean one or more tires needs to be re-balanced. Worse, one of the tires might no longer be round.
    May 2005
    #3333
    Quote Originally Posted by number001
    Thanks for the Info. Dun sa tanong ni cardo walang EBD ang Innova G
    #3334
    Ung busted tail light, DIY lang ok na, just bought an osram bulb 12V,21/5W or equal with same rating. had it replaced by myself while going to province once (better have stock head lights & tail lights bulbs when going out of town). basta meron ka lang socket wrench na 10mm matatanggal mo na yung tail light assembly, ung bulb naka socket lang kaya madaling tanggalin at palitan.
    Ung alarm try mo pa check sa kasa baka my maluwag na connection lang. or pa adjust mo sensitivity.
    benchride
    Sep 2005
    #3335
    kelan ang E B ?> :lurk:
    Mar 2005
    #3336
    Quote Originally Posted by Takumi
    Mganda i set natin ang EB natin sa Clark Air Base. Ano kayang say ni Innova_Boy?
    Last year nagkita kami ni Beeper sa may salakot.
    Jul 2005
    #3337
    Quote Originally Posted by busy road
    sir,
    kailan ang EB ng grupo, malapit lang ako sa Clark,
    Mar 2005
    #3338
    Quote Originally Posted by rcl_inno
    sir,
    Tamang-tama malapit din ako at madaling makapunta.
    Hintayin nating mag-response ang mga fellow innova tsikoters natin. This time siguro puro busy ang mga iyan dahil Holy Week. One time nag set si Innova_Boy pero hindi natuloy. My last day here still on May 8, 2006. So, malaking chance na matuloy at maki EB ako. Keep posting para mai-finalize natin.
    May 2005
    #3339
    Ok ako sa Clark, kaya lang baka konti lang maka-attend.
    Mar 2005
    #3340
    I'll contact Innova_Boy para mai-set natin. Any suggestion kung kailan natin gagawin? Sigurado masaya ito.
Toyota Innova Owners & Discussions [ARCHIVED]
