Results 21 to 30 of 560
February 19th, 2010 05:41 PM #21
When you say escaping, ibig sabihin ay palabas. ang observation ko ay nag vacuum. pumasok ang hangin.
- Jun 2006
- 1,139
February 19th, 2010 06:51 PM #22vacuum means no air... kaya nagcollapsse kasi sipsip ang fuel pump tapos walang breather hole to equalize the negative pressure created by the fuel pump
- Jun 2009
- 185
February 19th, 2010 07:31 PM #23damn it toyota! this is what you give us after years of patronizing your brand. legendary reliability my ass!
we have a 10 innova d4d, how do we know if ours is faulty as well? i have heard metal popping sounds a couple of times from under the right side 2nd row seat; is that where the tank is located? omg!
February 22nd, 2010 09:41 AM #24
February 22nd, 2010 10:01 AM #25
- Jul 2009
- 11
June 2nd, 2010 05:33 PM #26
- Jul 2009
- 11
June 2nd, 2010 05:36 PM #27
- Jun 2010
- 31
June 17th, 2010 09:58 AM #28Hello Mile2,
We're having the same issue sa '07 Innova G vvti namin. Biglang nag leak yung gas tank last Monday, 6/14. Dahil closed ang Toyota that day due to holiday, niremedyohan muna sa Sheill Station using epoxy. The next day, dinala na namin sa Toyota kasi meron din syang 100,000 pms. Sabi it's going to cost 20k para sa gas tank and they don't do repairs. Yun butas ng tank is in front of the support strap under the driver seat area.
Outside na rin ng warranty period yung sasakyan last Dec 09. Bale 6mos na sya outside warranty. Kinausap muna namin yung sa warranty department kung pwede pa mai-cover dahil ang lapit lang sa expiration. We're waiting for their answer bago papalitan. Nung nandun kame meron possibility na 30% daw ng cost babayaran namin according sa warranty clerk pero itatanong pa daw nya sa planta. So ngayon nagiintay pa kami ng sagot.
Ok ang history ng innova namin. Lahat ng service intervals and recommendations ng service advisor ay nasusunod. Nung nagsearch ako kung factory defect ang gas tank ng innova dito sa tsikot, lo and behold pareho ang issue natin and naka sticky pa. Nung nakita ko madumi yung filler cap mo na madumi, tinignan ko this morning yung filler cap namin and malinis sya. Sa tingin mo, nilinis nila yon habang nagpa 100k pms kami? There was also a one time na hindi nag automatic shut off yung pump sa shell wasting 15 liters of gasoline. Hindi ko alam kung related ito or sira lang pump sa Shell.
Sana mabigyan nyo ko ng advice on how to handle this with Toyota. Sobrang lake kasi ng 20k kung factory defect naman.
Thank you in advance,
Ed
June 17th, 2010 10:45 AM #29
*efive99
Besides the gas tank assembly, you should also have the Charcoal Canister and Filler Cap replaced...otherwise it will recur as per my experience. Twice I had this problem,. and I know how you felt it right now.
If they won't take it as warranty, you can actually have the tank repair at "talyer" but you would still need to buy the replacement Charcoal Canister and Filler Cap.
But if I were you! I will fight for "Factory Defect" claims. Bring a laptop with WiFi and show this thread and pictures to the dealers Custormer Relation Officer and Service Manager and for sure those pictures here would prove that the defect do exist! And I am 100% sure that the dent and crack/leak location is also 100% identical to your gas tank.
BANNED BANNED BANNED
- Jul 2003
- 2,267
June 17th, 2010 11:00 AM #30dapat nga palabas ang hangin pag open ng filler cap.
gasoline is relatively volatile substance. vaporized gas is supposed to created positive pressure inside the tank.
Service ito Ng nephew in law ko itong leaf sa Japan. He's had no complaints Naman.
2021 Nissan Leaf
