Page 233 of 358 FirstFirst ... 133183223229230231232233234235236237243283333 ... LastLast
Results 2,321 to 2,330 of 3575
    #2321
    Guys,
    Here's a bit of an odd request, perhaps.
    How do you lift a Gen 10 Corolla?
    Doing some research for my Mom. Who loves her Gen 9 to bits, and who has a Gen 10 but is having difficulty with the lower stance.
    Medyo mababa kasi ang stance ng Gen 10, which is perfect IMO for bigger wheels and skinnier tires. Nga lang since it's my Mom's ride, we need the opposite of lowered.
    Any ideas on how to increase the ride height? By about half an inch? Has anyone tried spacers perhaps?
    TIA
    #2322
    What are good replacement tires for out 10th gen? My car turned 4 yrs old na and I need to have the tires replaced na. Do I really need to replace all 4
    #2323
    ^Cat, kumho ecsta. Bang for the buck tire. From the reviews i get, it has good grip.
    Sent from my Nexus 7 using Tapatalk 2
    #2324
    We chose the Bridgestone Turanza for reduced noise and comfort. Huge difference from the stock Dunlops, specially in SLEX. A little expensive at P 6k+ each. Had to replace all 4 because we rotated tires so the wear was even on all 4, used it for 35k+ kms. First time to ride in the highway already made the purchase worth it!
    Jun 2010
    #2325
    Hi Guys, it's good to be back and I will be needing your help as well. I still have this clunking sound on the front end of the car and it's getting worse. I already replaced ball joints, stabilizer link, and the tie rod ends but the noise remains.. I can hear it from both sides. Then nowadays, I can already feel bump steers. For example in edsa,when I go over bumpy portions, the steering wheel veers left. What could be the culprit of this? I've done my research, and my suspects are sway bar bushings and control arm bushings.. Then maybe I might need good alignment. Any ideas??
    Btw, I can notice from afar that my altis seems "lowered" on the driver side (maybe because most of the time, I drive alone and all the weight is on my side). How can I get this back to normal height? Replace coil springs?
    #2326
    Where can I buy this?
    Quote Originally Posted by loverlionus View Post
    Where did you buy yours?
    I heard goodyear is not good na daw? Hehe
    Posted via Tsikot Mobile App
    #2327
    Quote Originally Posted by kafph2000 View Post
    my suspect? your front shocks and/or the rubber bushings/donuts, need replacement.
    #2328
    do the tread wear patterns suggest all four tires need be replaced? kuripot ako, and i will use all means to extend my usage of yon tires.. but i always replace worn tires, in pairs.
    however, i am not sure just how many years for the rubber to turn brittle...
    Jun 2010
    #2329
    Thanks sir for the reply. I forgot to mention that I first replaced my struts. It was two years ago. Which rubber bushings/donuts were you referring to?
    #2330
    the ones atop the shocks..
    but since you say they are only 2 years old...
    when my CV rubber boot sprung a leak and i lost lubrication, i started hearing an intermittrent metal-to-metal toktok sound.. replacement of the boot and adding lubrication, solved the problem.
Toyota Corolla 10th Generation Altis Owners [continued]
