Results 41 to 50 of 83
- Jan 2011
- 47
- Jan 2011
- 47
- Jan 2011
- 47
January 8th, 2015 11:50 PM #44
Palyado ba at that rpm? Pa linis mo throttle body tapos rev it for a couple of min. Battery is ok? Dapat pag rev it should smoothly go up and walang hesitation.
- Jan 2011
- 47
January 9th, 2015 12:09 AM #45Di siya palyado sir. Irritating lang kasi minsan nagvivibrate car. The needle is very much steady hindi siya nag up and down yung parang pagpalyado. Ok naman siya. Had throttle body cleaned na din, still the same result. Sabi nung technician baka daw yung idle up ko di nagfufunction. Sa pronto ako nagpunta kanina sir.
January 9th, 2015 12:14 AM #46
^ possibly the idle up (or whatever you call it); this is supposed to compensate for the varying engine load. Try a unit from a good VVTi engine to see if it works before changing?
January 9th, 2015 06:47 AM #47
Try reving it for 2 min on a warm engine. Clean air filter?
High rev up to or near red line. Then let go and repeat rev up then let go.
The 03 Camry i had did that when we replaced the battery.
Then the gas was pumped and pumped for about a couple of min and umayos.Last edited by jasonub; January 9th, 2015 at 06:49 AM.
January 9th, 2015 10:05 AM #48
- Jan 2011
- 47
January 9th, 2015 11:19 PM #49When there is load lang sir dun medyo nag vibrate. Ac and all. Its a 2005 camry.
- Jan 2011
- 47
January 9th, 2015 11:21 PM #50
As long as it's a legit Aisin brand. Pero if it's a major part, IMO, I'd stick with casa parts for...
waterpump area may konting leak
