Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 83
    Mar 2015
    #71
    Hi guys wanna ask if anyone knows kung sino yung marerecommend nyo to fix my power windows sa passenger 2 saka dun sa katabi ng driver seat. Camry 2005 3.0v and baka meron na rin kayo marerecommend na magaling na gumagawa ng body works along las piñas area
    Jun 2015
    #72
    gud am sirs, im having problem with my 2.4 2007 projector headlight, the one on the left keeps flickering and sometimes turn off by itself, when i turn off then turn on the lights again, it will turn on... any advice? salamat po
    #73
    Quote Originally Posted by tangkad88 View Post
    Ballast or loose wire? Best to check with your suking electrical shop. You can try Reys Electrical in Marikina or Cubao if that's close to you.
    Jun 2015
    #74
    will do that sir, salamat ulit
    Oct 2015
    #75
    Hello Guys Newbie here...Where can i buy Right Side Mirror (complete with housing) OEM color Black for 2010 Camry 2.4 G inquired a new one too expensive PHP 18k
    #76
    Quote Originally Posted by explorerpulag View Post
    Try calling Toyorama. It will still be pricey given it is not a common part but probably cheaper than the CASA.
    Mar 2005
    #77
    check eBay sa us then have it shipped to johnny air cargo who will ship it here good luck.
    side view mirror Toyota Camry 2010 in Exterior | eBay
    http://www.ebay.com/sch/Exterior-/33637/i.html?_sac=1&_from=R40&mvsub=1&_mcatda=true&selfi l=2%2C3%2C1&selvel=Toyota%7ECamry%7E2010%7E-%7E-&_nkw=side%20view%20mirror%20Toyota%20Camry%202 010
    Oct 2015
    #78
    Thanks Vinj called toyorama they have no stock.
    Thanks Jasonub will check ebay...
    Oct 2015
    #80
    Share ko lang, nag loosethread din yun sa 2.4 ko. Car overheated once only 2 years ago pa and was using it fine until recently, napansin ko na nag ooverflow yun sa water reservoir but not overheating and no change in performance. Brought to speedyfix, diagnosis was head gasket and found out na loose thread na nga yun sa block. Cost of rethread was 3k per hole x 6holes while overhauling kit/gasket 10k, then labor 15k plus other items (oil, etc.) Total cost is around 50k but quality of work is A1.
    I bring my cars to other shops when problem is minor lang but when complicated, kay Speedyfix.
    Btw, dinala ko rin sa Toyota Pasig and the service advisor told me "sir, mabuti pa ibenta mo na yan". Hehe.
toyota camry 2.4 inquiries
