Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 83
    Jan 2011
    #41
    Quote Originally Posted by jasonub View Post
    Vibration also might indicate damaged engine supports and or transmission support. Mura lang yan kahit replacement basta japan
    My idling with aircon on....
    Jan 2011
    #42
    My idling with aircon...
    Jan 2011
    #43
    Quote Originally Posted by 105.1 crossover View Post
    Mar 2005
    #44
    Palyado ba at that rpm? Pa linis mo throttle body tapos rev it for a couple of min. Battery is ok? Dapat pag rev it should smoothly go up and walang hesitation.
    Jan 2011
    #45
    Di siya palyado sir. Irritating lang kasi minsan nagvivibrate car. The needle is very much steady hindi siya nag up and down yung parang pagpalyado. Ok naman siya. Had throttle body cleaned na din, still the same result. Sabi nung technician baka daw yung idle up ko di nagfufunction. Sa pronto ako nagpunta kanina sir.
    #46
    ^ possibly the idle up (or whatever you call it); this is supposed to compensate for the varying engine load. Try a unit from a good VVTi engine to see if it works before changing?
    Mar 2005
    #47
    Try reving it for 2 min on a warm engine. Clean air filter?
    High rev up to or near red line. Then let go and repeat rev up then let go.
    The 03 Camry i had did that when we replaced the battery.
    Then the gas was pumped and pumped for about a couple of min and umayos.
    Sep 2013
    #48
    paggamit ang A/C saka malakas ba ang vibrate nito pero kung switch off ok naman ba? how old is your car BTW?
    Jan 2011
    #49
    When there is load lang sir dun medyo nag vibrate. Ac and all. Its a 2005 camry.
    Jan 2011
    #50
    Sir had this done also with the mechanic but to no avail hehe. Nakahanap na ako ng temporary solution...buksan ang radio and listen
    to good music para di maramdaman ang pagvibrate paminsan
toyota camry 2.4 inquiries
