Results 31 to 40 of 83
- Oct 2014
- 6
January 7th, 2015 02:45 PM #31
- Jan 2011
- 47
January 7th, 2015 05:52 PM #32
- Oct 2014
- 6
January 8th, 2015 12:10 PM #33Kung purely underchassis papagawa mo kay Cruven ka nalang, may option ka pa whether to repair your existing suspension parts or replace with new ones. Magaling talaga sila sa pang ilalim lalo na sa troubleshooting.
If you opt to replace the parts with new ones I would suggest that you buy the parts yourself lalo na kung orig gusto mo. Grabe managa Cruven sa price nang bagong parts.
January 8th, 2015 12:36 PM #34
Per experience, i'd prefer to buy new parts for suspension repairs then go for refurbishing. Reasonable naman yung replacement parts for the Camry (555 brand, KYB). Pag control arms (w/ ball joints and bushings), go for OEM. We bought all our parts from Toyorama.
- Jan 2011
- 47
January 8th, 2015 06:14 PM #35
- Jan 2011
- 47
January 8th, 2015 06:17 PM #36
- Jan 2011
- 47
January 8th, 2015 06:21 PM #37[QUOTE=enerodesais;1443711]hi rhino,
i have owned different camrys for 10 yers now and i must say the best models came out from 1997-2000. Ironically, these were the CBUs that came from Japan. The quality and build of the newer model camrys that come from Thailand and Indonesia or RP are subpar.
Sir may i ask how didi you solve the idle vibration....thats what i have with my 2.4v right now. Does it have something to do with your idle up?
The first thing tht will go wrong with the 2.4 camry is the idle vibration. parng naka diesel ka. A million peso cr wwith a diesel ride!
Toyota knows about this problem but have kept it under wraps just like the sudden acceleration problem caused by the drive by wire throttle system
I must say Toyota has been a victim of its success.
Read up on the various USA toyota forums and search vibration at idle.
Hope its not too late.
Toyota now is sucky brand[/QUOTE
January 8th, 2015 06:56 PM #38
Clean throttle body with carb cleaner. Make sure you have a clean filter. Make sure your. Idle control valve is clean or new.
To test it remove it and shake pag walang tunog its clogged. Buy new one.
Check battery if ok ang power go to motolite service center and check the charging system.
Also check plugs replace with oem plugs.
Fuel should also be clean baka luma na ang in tank fuel filter or madumi na.
Mine was a dirty throttle body that and when i replaced the battery bumaba idle. The computer has to relearn the throttle body opening. Pag madumi it compensates.
Never had major problems with the camry s i had and have.
January 8th, 2015 06:57 PM #39
Vibration also might indicate damaged engine supports and or transmission support. Mura lang yan kahit replacement basta japan
- Jan 2011
- 47
January 8th, 2015 08:08 PM #40
Hindi nga maganda track record ng AC Motors sa long term ownership. Para sa price range, sa...
China cars
