Originally Posted by
eppie5
mga tol hndi ba hihina ang 7k pag nilagyan ng muffler
at ung 7k ko masyadong malakas ang pagconsume ng gasolina kaysa ka2lad ng 7k ung sakin 500 pesos pang 4 or 5 kilometer lng or 2 lng ata ung 500 pesos pang 1 day gasoline sa 7k ko un anu po ba solusyon dyan?
anong hihina baka lalakas pa kamo ang makina pag-naka muffs...
Depending on the design, mufflers can also have a performance advantage. Stock mufflers are usually fairly restrictive and are frequently replaced with performance mufflers to allow increased airflow as spent exhaust gases exit the motor. High performance mufflers, which are usually made out of stainless steel, feature an internal design that is less restrictive as air and soundwaves pass through it, resulting in more power from the motor and a louder exhaust note. sa mga 4cylinder higher pitched ang tunog (baZZZZZZ). A performance muffler is typically used in concert with a larger-diameter performance exhaust for the best effect. Since a free-flow muffler helps an engine run more efficiently, it can also result in slightly improved fuel economy.
