Page 239 of 265 FirstFirst ... 139189229235236237238239240241242243249 ... LastLast
Results 4,761 to 4,780 of 5286
    Oct 2007
    #4761
    Quote Originally Posted by Shutterbug View Post
    Do we still need to cut out a portion of the tint even if non-metallic naman naka install?
    As what sir heavenlee said, dapat walang tint when you stick the sticker.
    #4762
    Wala po bang cabin air filter na dala yung fortuner at the time of purchase ng brand new? If hindi sya kasama sa purchase, then does it mean hindi sya necessary? How much does it cost sa casa? If outside casa, meron kaya and how much would be the price difference?
    #4763
    in my 2005 innova E, there was no filter.
    but someone sawed a rectangular opening thru the plastic housing of the aircon, in front of the glovebox, allowing me to insert a filter in. i close it using a hard flat plastic or cardboard sheet that i tape into place.
    and seeing just how dirty the filter can get, i believe the filter helps keep the evaporator clean and efficient.
    in my 2014 innova E, there is now a remove-able filter installed by the manufacturer.
    removing the glovebox should allow you to see, if it has a filter or not. google it, po. it may seem impossible, difficult, or frightening the first time, as "something might break". but it can be done, po. kaunting lakas ng bisig at loob. i have done it myself, several times. it gets easier with practice.
    good luck.
    Jun 2005
    #4764
    Quote Originally Posted by attyallanlatras View Post
    Same size nyan ng vios. I think hindi sya standard part dito sa pinas up until 2014. Yung mga released ng 2014 onwards, standard na sya
    Sent from my MI MAX 2 using Tapatalk
    #4765
    Is it advisable to wash then dry the cabin air filter for our fort 2016? sa casa dito sa Cebu, they sell one filter for more than 4,000.00. I saw some air filters sold at lazada really cheap but I do not know which to buy... Pls help...
    #4766
    i gently hand-wash mine for three times, after which i deem it too distorted for re-use.
    it's just an air filter. i believe genuine fakes will do fine, as long as they fit right.
    i just purchased one from the corner auto parts store for 450 bucks. on-line shopping prices should be less.
    #4767
    I used to wash my cabin filters when there were no cheaper alternatives. But I've been replacing the yearly since the cheap replacements became available. I find that the airflow of the washed cabin filters are not as efficient as brand new ones.
    Sent from my SM-T705 using Tapatalk
    #4768
    you can buy replacement at pyeza or kapitan, fleetmax brand, try also cebu parts mall they have original.
    Sent from my SM-A720F using Tapatalk
    #4769
    i believe the fortuner, innova and vios, share the same size ?
    #4770
    The 2006 Innova G already has a removable filter that is accessed by removing the glove box. I've been replacing the filter myself the past several years by buying compatible filters from outside the casa.
    I didnt know that the earlier versions of the E (and probably the J) didnt have the removable filter assembly.
    good luck.
    #4771
    Salamat sa mga nagsagot sa previous query ko. Another question mga bro...I was able to purchase a second hand 2016 Fortuner 2.4L G Diesel A/T and ang sabi ng original owner ay last oil change nya is fully synthetic sa casa and the next oil change is after 10,000km na... I want to continue using that fully synthetic oil, but not in the casa since by its next PMS out of warranty na sya. Question ko lang is ano ba yung oil viscosity ng Fully Synthetic for a diesel engine? What about young semi-synthetic ano ang viscosity? Been checking the manual but I cannot figure out which is the full synthetic from the semi, and from the mineral oil... noob here...
    #4772
    Pasingit lag po
    Just a question. The new fortuner doesnt have an "L" gear but instead has S1-S6... Is S1 equal to L?
    Sep 2012
    #4773
    Ang fully synthetic viscosity dati ng toyota for diesel fortuner ay 5w40. Lately lang nagpalit ang casa ng 5w30. hth
    Sep 2012
    #4774
    OEM cruise control install and activation for fortuner G Gen2 2016 to 2019 Manual and Automatic Transmission. Pm me if interested. TIA
    #4775
    Hay salamat, after 2 year of owning my fortuner, nakuha ko rin plate number ko.
    *vinrem, sir when you got the new plate number, meron bang kasamang bolts to screw in? Nakuha ko na rin just two days ago pero walang mga bolts. Dati kasi sa Innova ko when the new plates were distributed merong kasamang mga bolts.....
    #4776
    just a question. the new fortuner doesnt uave an L gear. Is the s1 the replacement to use instead of the L?
    Oct 2007
    #4777
    Sir, wala pong kasamang bolts and screws, also, nagkataon na PMS ko nung time na yun, pinakabit ko na lang agad sa Toyota.
    Dec 2009
    #4778
    hi sirs,good day.
    i am looking to replace my old 06 fortuner with the new one, but only the G model as the prices are so steep now a days, would like to ask what is the maximum discount for 40% DP and 4 yrs to pay scheme.
    please advise.
    #4779
    Mga bossing, would it be possible to install a tire pressure monitoring system sa Forty natin? If so, how much kaya?
    Mar 2004
2016 Toyota Fortuner
