Page 139 of 156 FirstFirst ... 3989129135136137138139140141142143149 ... LastLast
Results 2,761 to 2,780 of 5286
    Oct 2007
    Quote Originally Posted by jmpet626 View Post
    Hindi din sir. Matagtag pa din yung Gen2 Fort ko kahit loaded pa ng 7 persons. I can compare this kasi I also drive a Gen 2 Everest and Gen 3 Montero alternately.
    I added spring helpers sa Fort para mabawas yung tagtag na nararamdaman sa flat concrete roads/expansion joints. It made the springs stiffer pero mas naging tolerable.
    Mine doesn't, Ilan ang tire pressure mo? Mine is 28-30psi.
    Sent from my Nexus 7 using Tapatalk
    Sep 2012
    Im using 29 psi, di siya matagtag..
    Ramdam parin siguro talaga ang tagtag, especially since you compared to it to the gen 3 montero, which is known to have a soft suspension. Ang question ko is mas matagtag siya kaysa dun sa gen 2 everest eh that thing has an old leaf spring suspension pero it sounds like mas stiff yung fort para sayo than that one?
    Jan 2008
    Alterra has leaf spring suspension pero ok na ok talaga ang ride. Kahit yung mahiluhin kong mga anak at mga kasambahay, gusting gusto pag Alterra ang gamit naming. Pero nahihilo agad pag sa Tucson.
    Aug 2013
    Each one really has different preference pagdating sa tagtag. But still I wonder why iba-ba eh identical naman lahat suspension ni Forty. Sa mga nagsasabi na "hindi matagtag" ano po usual route & road condition ng dinadaanan nyo? Kasi for me personally matagtag talaga! That's why napilitan kami mag-upgrade to Ridemax. Nabawasan naman tagtag but really not a very significant change that's why sa tingin ko kelangan din lift ng spring which I'm not favor of kasi panget na stance nya pag tumaas pa sa stock height.
    Quote Originally Posted by PATSYS View Post
    In contrast, the 2nd gen monty before had a soft yet floaty ride that gets occupants dizzy after long trips. I don't know for the new gen monty but the mu-x is said to have a ride that is similarly soft also. Kaya the best remedy talaga is to change the stock suspension with a better one that will fix the bumpy ride you are pointing out on it.
    Mar 2005
    Gen 3 Everest pala sir na Titanium with 20" Mags. Yes mas stiff pa din para sakin yung Fortuner na naka 18's vs current gen Everest na naka 20's. Route ko Project 8 QC to Alabang via Edsa and Slex 5 times a week. 33 psi ako sa lahat ng SUVs. Looks like Ridemax shock upgrade ang next ko sa Fort.
    Grabe lahat pala ng top 3 ppvs ngayon eh meron ka. 😱
    Ako nga ni ayaw pa upgrade samin yung vios para sa isa sa mga yan eh. 😂
    Aug 2013
    Stiffness hanap you can rely on Ridemax but not necessarily translates to smoother ride halos ganun pa rin ung tagtag so better isama sa upgrade ang coil spring.
    Jan 2008
    My Fort is almost 1.5 years old na, bihirang-bihira ko lang ginagamit, and if gagamitin ko, pang short trips lang, yung eldest ko na 5'11 ang height dun sumasakay, 3rd row is cramp but again, it's for short trips lang.
    Regarding sa tagtag, if 2 or 3 lang kayo, matagtag ang fortuner, but if 4-5 kayo and heavy weight like my kids, walang tagtag and feeling ko stable pa siya sa highway.
    Sent from my ONEPLUS 5 using Tapatalk
    This makes sense...I felt that its ride with soothed as the load increases...
    Nov 2017
    You should consider after sales support ng casa hirap ba naman masiraan na wala ka mabili replacement. Saka durability kailangan mo din iconsider mahirap din palagi sirain gastos pa naman ngayon magpagawa.
    Sep 2017
    Di ba madali ma pudpod gulong natin guys kung 29-30? As of now kasi 35 all tyre gamit ko.
    Nov 2017
    Quote Originally Posted by PeterGChan View Post
    Hindi naman siguro depende naman sa roaf condition dinadaanan mo
    after some time, the tire wear pattern should show evidence of mal-inflation.
    Nov 2017
    This is true. Last time I had my AUV serviced, I asked the owner of the shop who happens to be the SA before of one of the mitsubishi dealerships as to why my threadwear ay panay sa labas and sa gitna naman ay walang pudpud pa din. I was thinking na may problem sa alignment kaya ganon. After looking at ny front tires, sabi niya kulang sa hangin mga gulong kaya ganon ang kain. I used to have 25-27 psi sa front...now, ginawa ko nang 35 psi front and rear...kahit sa mu-x yun na din ginawa ko upon his advice.
    Sent from my Redmi Note 4 using Tapatalk
    Sep 2012
    Sa gen2 fort 29psi ang factory recommendation. Nasa driver door sticker siya. I have a 3.0 gen1 fort at sinubukan ko 29psi, matagtag pa rin. Unlike sa gen2 fort ang 29 psi hindi siya matagtag.
    Nov 2017
    Quote Originally Posted by sparcom2 View Post
    Alam ko n solution para mawala tagtag at less cost lagay ka memory foam sa upuan mo[emoji106] [emoji111]
    Quote Originally Posted by maxpedition View Post
    putting a sack of rice at the rear...
    Sep 2017
    Parang pick up lang sir may anchor. Hehehe
    Sep 2017
    Effective kaya mga sir yung backjoy ba yun na brand sa mall na parsng lagay sa upoan para sa likod? Medyo masakit kasi likod after long drive. Hehehe
2016 Toyota Fortuner
