Page 206 of 265 FirstFirst ... 106156196202203204205206207208209210216256 ... LastLast
Results 4,101 to 4,120 of 5286
    #4101
    can anyone direct me how to remove the front grill? video tutorial would be great.
    top part has 2 screws, and 4(?) plastic fasteners/clips(?)? i'm having trouble with the bottom part of the grill, can't really see where it's attached.
    thanks!
    Oct 2007
    #4102
    Quote Originally Posted by jasonrey View Post
    thanks!
    Sir, there are 2 plastic clips or is it called fasteners at the bottom that you need to push or unlock outward from the inside para matagal yung front grill, just got mine installed yesterday kaya alam ko, if you have the front grill na your planning to install, makikita mo yan, be careful lng at baka maputol yung sa original.
    10k PMS fort V
    Sep 2017
    #4104
    10k PMS fort V
    Sir ask ko lang, fully synthetic ba ang oil mo nung 1,000 pms mo? At sa ika 3rd pms mo na yan tama?
    Kasi ako 1,000 pms ko fully synthetic, so nung 2nd pms ko dagdag oil lang ginawa. Baka sa 3rd pms ko this march palit na oil ako siguro?
    Yes po. Change oil for fully synthetic
    Quote Originally Posted by PeterGChan View Post
    Sep 2017
    #4106
    Thank you sir! Buti na yung mapag handaan.
    Oct 2007
    #4107
    10k PMS fort V
    Sir, how many months before you reached 10k?
    Oct 2014
    #4108
    For barely like a month am hitting like 1k mileage, so just 2days ago I had my first pms for my forty.
    I chose for synthetic oil instead over a mineral for obvious reasons and the damage is supposedly around 6k petwot but then they offered me for a rust proofing which really emptied my pocket to nothing worth around 9k (all over)....so at the end of the day 16k in total chip out from my savings...diem.!.
    #4109
    10k PMS fort V
    mura twwf, sandpaper and rags bill nyo..!
    i was charged 50% more for these, for my smaller car.
    but i was't charged for gloves.
    and i like their notes about the brake friction pads and rotor.
    Oct 2007
    #4110
    Wala ba talaga settings or hacks on how to unlock all the car door when you turn off the engine???
    Sent from my ONEPLUS 5 using Tapatalk
    #4111
    your car doesn't do that, automatically? unlock all doors when engine is turned off?
    Oct 2007
    #4112
    Yes sir, I need to unlock it manually sa door panel switch, mine is the V variant.
    Sep 2017
    #4113
    Kahit sa G na variant sir ganon din sa amin.
    #4114
    yours does not automatically unlock with engine off, also?
    Sep 2017
    #4115
    Di rin po sir. Same sa Honda namin kahit off na engine di rin auto unlock. Unlike sa Crosswind dati, pagka off ng engine unlock na agad. Original central lock galing casa din yung sa Crosswind. Baka iba2x ang features ng mga central lock. I know yung mga alarm/central lock na 3rd party yun sure ako auto unlock yun after engine off kasi nakapakabit ako dati sa Revo pa yun.
    Oct 2007
    #4116
    Also, di rin nag auto lock after a few seconds or minutes, kaya, you need to double or triple check if na lock mo talaga or hindi, eh ako pa naman na makakalimutin, hay, unlike sa mazda ko, it locks after a minute or two.
    Sep 2017
    #4117
    Sir ma iba ako, may tanong lang ako medyo technical. Yun bang fuel tank natin naka kabit sa chassis or body? Sana ma gets niyo tanong ko. Hehehe. I mean kung sa chassis lang ba siya nakasalalay, or connect din sa body ng kotse?
    Oct 2007
    #4118
    Hahaha di ko alam, sorry, baka yung iba dito alam.
    Sep 2017
    #4119
    Hahahaha. Kasi kanina nag linis ako sa ilalim ng kotse, medyo nagulohan din ako kung nakasabit lang ba sa chassis or sa mismong body
    BTW sir, yung kulang lang talaga sa central lock natin is yung mag beep once pag nilock mo, tapos 2 beep pag unlock. Nasanay kasi ako na di tingnan ang ilaw or check kung open pa ang kotse after lock.
    #4120
    errr... why is it important, sir?
    what does it matter if the tank is bolted to the chassis, or to the body sheet metal?
2016 Toyota Fortuner
