Results 1,951 to 1,960 of 5286
- Aug 2013
- 262
December 27th, 2016 10:47 AM #1951
December 27th, 2016 01:38 PM #1952
Usually you cannot apply watermark remover sa side mirrors.
Most brands i saw before say it on the bottle. Kindly check on yours.
- Aug 2013
- 262
December 27th, 2016 02:04 PM #1953I did check before applying. It cannot apply in some side mirrors that's why it suggested to test it first in small portion. Which I did, in fact it worked on the driver side but when I applied on the opposite, that's where the dilemma started!
Actually, I don't suppose need to apply on side mirrors nadamay lang talaga since I applied all over why not lahat na. I was so over excited...my mistake hehe
But at least lesson learned http:////cdn.tsikot.com/forums/image...es/biggrin.gif
- Aug 2013
- 262
December 27th, 2016 02:06 PM #1954I did check before applying. It cannot apply in some side mirrors that's why it suggested to test it first in small portion. Which I did, in fact it worked on the driver side but when I applied on the opposite, that's where the dilemma started!
But at least lesson learned...:D
- Jan 2008
- 169
December 27th, 2016 03:38 PM #1955
December 30th, 2016 04:53 PM #1956
Do you guys still turn off the AC before you turn off the engine or no need to turn off the AC na?
Sent from my S7 Egde
December 30th, 2016 10:11 PM #1957
Turn off the aircon ... less load and stress when starting the engine ...
- Jul 2016
- 939
December 30th, 2016 10:37 PM #1958On these all new suvs/cars on the road, ecu is now intelligent enough to disenage a/c compressor when starting/cranking engine.
The real benefit of turning off AC and putting blower to max is that is removes moisture and increases evap temp to ambient. Less prone pamahayan ng molds/bacteria na nagcacause ng mabahong amoy ng ac especially in our hot and humid climate.
December 30th, 2016 11:47 PM #1959
Thanks mga sir for the input, upon reading the owners manual, they didn't mention on how to turn the AC on, I tried pressing the AC button but it didn't turn on, it will just turn on if you press the auto control, unlike on my Mazda 3, you can turn on the ac when you press the AC button but sa fortuner ayaw.
I forgot to mention mine is a 2WD 2.4V pearl white, bought last December 22.
Sent from my Nexus 7 using Tsikot Forums mobile app
January 1st, 2017 08:43 PM #1960
Brought the Fort to Nasugbu Batangas. Passed through Pico de Loro rolling zigzag on the way back to Manila. There is a problem with the clutch, especially on fast downhills. The gears seems to be stuck and remain in high rev at about 2k rpm even without stepping on the gas...have to continually press the brakes to slow down enough for the gears and the revs to go down. Between 80 kph and 40 kph. My transmission was changed before and the recieved the update program for the downshift jerk. Anyone experienced a similar anomaly.
ganda sana, if we can exchange discharged batteries for fully charged ones, the same way we...
All New Toyota Corolla Cross
