Page 205 of 265 FirstFirst ... 105155195201202203204205206207208209215255 ... LastLast
Results 4,081 to 4,100 of 5286
    Sep 2017
    #4081
    I wait till the system check is finished and the srs airbag test is finished, by then the system ready for that crank.
    Yes sir ganyan naman ang ritual ko sa pag start, minsan lang talaga may times na nagmadali ako makalimutan ko. Akala ko ang Honda gamit ko, kaya yun diretso andar. Hehe. Salamat sa input sir!
    #4082
    Quote Originally Posted by PeterGChan View Post
    Okay lang ba minsan di ko ma intay ang heater, at diretso na start ang kotse? Minsan kasi makalimutan ko diretso na ako start eh. Though sobrang bilis naman talaga ng indicator ng heater, halos di ko makita sa sobrang bilis mawala. Hehe
    Ok lang yan it just shows ok pa battery mo. Same on my 3.2 monty wala pa 1 sec ready na. Nasanay din ako sa Crosswind na direcho bec walang glowpugs.
    Sep 2017
    #4083
    Ako din sir, nasanay din before sa Crosswind ko. Haha. Thanks!
    #4084
    crdi na kasi to, mas mataas pressure ng rail then mas fine ang spray ng injectors kaya mas mabilis paandarin kahit minimal lang ang heater
    Sent from my SM-A720F using Tsikot Forums mobile app
    #4085
    what wheel specs do I need if I want to use the stock 17 a/t tires of my 2017 Fortuner G? what are recommend brands po? mga 40k/set po yun budget.
    yung black rhino sidewinder, meron ba ibang color? bronze pala color ng unit ko. as much as possible, ayaw ko yung all black.
    thanks po!
    #4086
    Ive been seeing several fortuners that have rear disc brakes. Some dont have. What models come equipped with rear discs?
    Oct 2007
    #4087
    2018 model sir.
    Sent from my Nexus 7 using Tsikot Forums mobile app
    #4088
    All latest models already come with rear disc brakes.
    #4089
    Quote Originally Posted by jasonrey View Post
    thanks po!
    Dapat 17", 6 lug and with the right offset...
    Nov 2017
    #4090
    Mar 2005
    #4091
    Installed a set of spring cushions for the front and rear in the hopes na mabawasan yung tagtag and ma correct yung sag sa rear. Surprisingly nabawasan yung tagtag na na experience ko while driving on flat concrete roads.
    Aug 2009
    #4092
    Quote Originally Posted by jmpet626 View Post
    Source and brand?
    Feb 2013
    #4093
    Quote Originally Posted by mcoy123 View Post
    Pwede po hb3 sir?
    Hir2/9012 kasi nakalagay sa atin. . . Wala ako mahanap na extreme vision at nb laser
    Mga sirs pwede lang mag pa clarify? I also need to improve the lighting of my '18 Fort G kasi medyo mahina talaga ilaw. All the info I find on HB3 or Hir2/9012 indicate single filament only. Pati wattage naka specify lang 60W unlike H4 bulbs which state 55/60 and clearly contain two filaments, one for low beam and one for high. So has anyone here replaced their bulbs and what brand/model/size did they replace it with? Thanks for any assistance.
    Jan 2017
    #4094
    Quote Originally Posted by timsam View Post
    Single filament lang talaga ang hir2. . . The bulb doesn't change intensity when you flick on your highbeams . . . Instead meron flapper/aperture(or something to that effect) na mago-open wider para magbago yun focus ng ilaw
    Dec 2017
    #4095
    Bulb lang ba pinagkaiba sa foglamps ng earlier 2016/17 units sa 2018 units (led) ?
    Feb 2013
    #4096
    Thanks mcoy123 for the clarification. Not too many options pala for G owners?
    I'm looking at the Sylvania 9012 SilverStar Ultra Headlight Bulb (BRIGHTEST Downroad Headlight, ULTRA NightVision - SYLVANIA 912 SilverStar Ultra | SYLVANIA Automotive) but still trying to figure out where to get it.
    Anyone out there try any of those plug-n-play (daw) na LED replacements?
    #4097
    Any way to get the AVT Fort HU to play video via digital input? (Not DVD)
    Quote Originally Posted by mda View Post
    USB only... but the playback is only up to 480 resolution.
    #4099
    Sayang. Mirroring sounds interesting. Saw a youtube easily searchable pero andaming cables required. Something like Phone --> HDMI --> RCA --> 3.5mm
    Oct 2009
    #4100
    Hello po. Baka po meron kayo pdf copy ng fort manual? Baka po pwede makishare... hirap basahin ng hard copy eh... hehe
    TIA
2016 Toyota Fortuner
