*keno - sir sila sana nag accelerate para narinig mo mismo na sa differential galing
yung ugong. mahirap kasi na ikaw ang nasa manibela at sila lang makakarinig. baka
kasi hindi doon galing yung tunog.
kumpara kasi sa nangyari last month sa sasakyan ko(apv) at sa sasakyan ng kuya
ko (space gear):
yung sa apv ko me tumutunog sa ilalim (tokotok lang) ang pinalitan yung
stabilizer linkage.
habang sa kuya ko ang lakas ng tunog (krak, blag hehehe) hanggang likod
ang pinanggagalingan ng tunog. kahit malayo naririnig. pinacheck lahat ng
shocks at bushing pero ang sira pala parehas lang kami. stabilizer bushing din
pero nagtataka kami kung bakit me tunog hanggang sa likod ng sasakyan.
sana ma solve mo na rin yang mga gusto mong ipaayos sa sasakyan mo
para worry free na....
I had it change this October 13, 2012 and the oil was colored brown when it was drained out.
This is a second hand car and it has 67,000 km on it already when I bought it this October.
Thank you sir for the info. After seeing how many and complicated the parts are in the assembly, I will not
let just anyone disassemble the transmission. By the way, I followed up at the shop and they send the rear
axle to the machine shop today. Because they said that the axle bearings was making the sound. I hope
they are right because the mechanic at Wheeler did not found anything wrong with it. Still keeping my
fingers crossed if this is the only problem and if not, will just keep on using the car until I can find a surplus
transmission and a specialist.
I came to a conclusion that it better to buy a new automatic transmission car or a second hand that run
only 30,000 km so that we can have it PMS and prevent any problems in the future because we don't know
if the previous owner do this PMS. Unless he can show you the PMS of the car then you can be sure it's
in good running condition.
Just my opinion, thank you.![]()
Yes sir, I made a mistake of not going to the rear of the car to listen where
the sound is coming from because I want to make sure the sound is there
when I accelerate the car.
Anyway, I hope the mechanic is correct that the sound came from the axle
bearings. If not, will try . . . . . .and try to find what is wrong again.
Thank you sir for the advice and nice sound set up you have in your car.
( Maybe it's better to buy a manual second hand car if it is already more than five years old? )
planning to replace my interior door panels for a better design.. and more comfortable of course.. since I have a GA model. its only a marine wood wrapped with vinyl...
around magkano kaya sa CASA ang interior door panels? or maybe pa-sadya sa mga gumagawa for interiors?
sana meron sa banawe or evangelista shops na surplus.. hehhee.... para kumpleto pati handles..etc..
You are welcome sir.
Just want to share this video:
Suzuki cars Philippines 2012 - YouTube
Hope you guys like this.
I also inquired about the financing rate of the apv's:
Maybe next year, I will buy a new one?![]()
No sir, the 603K Php is dual AC.
My apv is still at the shop and my kids are asking where it is?
The shop said on Friday, they need to buy the original bearing for the axle
for it was hard to look for a replacement and will be installing it on Saturday.
I hope it's finish by Monday.
so 1 more week pa sir? hopefully this will be the last for the issues..
lupet sir ng parts manual nyo sir. even my parts manual dosent have the differential breakdown for the APV! i was searching for it few days back!
sir 12vdc, im assuming you have a Vitara? or APV? we have a funrun coming up this saturday to Momarco Report in Tanay, Rizal for the Club Suzuki Philippines' 6th year anniversary.
Thank you sir for the info, the differential gear assembly is much less
complicated than the automatic transmission assembly.
I called the shop this Monday and they have to open and check the
bearings inside the differential gear housing despite having replaced
the axle bearings because their was still a sound when they test run
the car. I ask if they are sure that the sound was coming from the diff
and not the transmission? They said yes and they got it opened, only
today because they have to buy the socket to open it ?
They said that they have to replace four bearings in the carrier after
already replacing two in the axle. It's almost a week now and I hope
they are right.
Oli, 2008 yong APV ko GA type 1 pero FC ko di talaga umabot ng 8/L, 6 to 7 /L lang talaga ang kaya niyang itipid sa gas,
kahit binago kuna driving habit ko, kahit pinapa drive ko na sa iba yong di mabigat ang paa, considering good driver same road condition ganon parin,
KULANG KAYA SA TUNE UP? PMS ko sinusonod ko lahat.
Any avdice mga BRO kon ano gawin.
hmmmm.. may i ask for some details so we can research for the cause..
Oil viscosity?
Traffic situation?
how do you estimate/calculate fuel consumption?
spark plugs?
air filter?
also how many kilometers traveled?
thanks.
BOSS OLI, ??????
1. oil viscocity = casa recommended as per manual
2.traffic situation= mixed moderate 20% traffic, 80% highway
3.spark plugs= regularly change as per manual, every 10,000T kilometer Minsan 5,000T
4. 85km / 12.5L ( full tank on departure two clicks & full tank on arrival same two clicks of the gasoline station nozzle)
using premiun gas.
please note : hindi pa ito napaayos or repair outside sa casa/ in short casa maintain siya.
normal passenger onboard 5 to 6 include driver, 50 to 60kgs
May problema kaya makina ko?...doubt lang kc,,,ANY ADVICE.... THANKS IN ADVANCE..
