Page 112 of 134 FirstFirst ... 1262102108109110111112113114115116122 ... LastLast
Results 2,221 to 2,240 of 2668
    Jun 2014
    #2221
    Hi Guys,
    I'm planning on getting new tires for my sgx AT. i was being offered 8 ply tires for light trucks made in china. this is what they have 185r14c
    need your input.....
    pros and cons?
    thanks in advance!
    Mar 2015
    #2222
    Quote Originally Posted by apvboy View Post
    Hi Guys,
    pros and cons?
    thanks in advance!
    In my opinion sir better stay away sa mga china made tires. Hindi pa kasi ganun kaganda quality.Sayang pera. Your tires are the only contact between your car and the road please don't go cheap on them as you and your family's life will depend on it.
    #2223
    Ok. Made my first trip to Tagaytay and I'm impressed by the performance of the APV. Fully loaded at di lang humahatak, humahataw pa. My family were so happy that they felt comfortable during the whole trip, except me though. Being that my body is of the heavy set, my tailbone got sore due to the lack of padding in the driver seat. Plus sort of new with the pedal layout, my knee and calf got sore after driving it nearly 4 hours straight.
    Again, got few more questions. How can I install the auto lock feature on the APV? I kind of like the remote and central locking feature of the APV. I just need to auto lock it when its moving. Also a back up camera would be nice as well but without changing the headset.
    Jul 2015
    #2224
    Guys,How much ung air con belt tensioner bearing ng APV? Can't find sa labas.how much din pala LTO registration natin? Thanks!
    Jul 2011
    #2225
    Quote Originally Posted by rey752 View Post
    No idea sa belt tensioner but sa LTO registration almost 4k including the fee for the new plate.
    #2226
    P86 bili ko ng tensioneer bearing NSK6301DDUCM. Pwede iba brands basta waterproof seals dapat. Palitan mo narin fanbelt 4PK1060. Backread lang po may pinost ako abt bearing replacement some2yrs ago.
    Jul 2015
    #2227
    Bearing lang ba pinapalitan 12vdc? Parang mura kase ang P86?
    Jul 2015
    #2228
    Mag kano pala ang parehistro ng APV?
    #2229
    Yes po, mura ang generic bearing.
    http://tsikot.com/forums/suzuki-cars-talk-82/suzuki-apv-[merged-threads]-19450/index155.html
    You won't be able to buy the pulley alone because they are sold as assembly with the comp bracket. Maybe you could source it from some autoshop but make sure it has the same offset as the OEM.
    Also correction for the serpentine belt, it should be 4PK1050, I used 1060 because shops around that time don't have a stock of 1060 mm.
    Registration is about P4k as what sir rapidfire_28 have said.
    Mar 2007
    #2230
    Servitek are offering buy 3, get 1 free tire. Some offer a dashcam. Take advantage of those promos. Goodyear is still a good brand.
    Jul 2015
    #2231
    Boss 12vdc,I can't send you a pm.
    #2232
    Quote Originally Posted by Mguy View Post
    I have auto lock/alarm installed in Suzuki Pasig.
    #2233
    Quote Originally Posted by sep_seph View Post
    Sir yun alarm ba will use the existing key fob ng APV or will it have a separate remote?
    Jul 2015
    #2234
    Thanks for those who answer my questions, I ask kung mag kano pa register ng apv kase papalakad ko lang.
    #2235
    Separate one
    Jul 2015
    #2236
    Sir 12vdc,I went to power parts banawe(formerly Links Motors) and they don't have a stock of those belts.nakalimutan ko naman mag tanong what specific belt or belt size etc yung pang compressor and alternator? Dalawang belt po sya diba?regarding sa tensioner sir,why does power parts requiring me to buy the assembly which is around 1,600 bucks?
    #2237
    Yup, just what i told you they wont sell per piece of oem, based on the picture its an assembly. I wont change an assembly not unless the tensioneer bolts are stripped. P1600 vs P86 savings is like hitting a jackpot[emoji14]
    May previous post na rin abt those belts, search na lang. To reiterate, and if i were you id buy the parts sa labas.
    AC/PS belt - 4PK1050
    Water pump/Alternator belt - 4PK815
    Tensioner pulley bearing - NSK 6301DU2 or equivalent.
    Jul 2015
    #2238
    Thank You sir 12vdc!
    Jul 2011
    #2239
    Mga sir,
    Good day. what is the best possible option to have an aux for our stock audio? Old style pa kasi yung radio ko which is my casette pa without USB. Yung boss ko nag palit ng 4din radio which hindi naman daw nag match sa housing ng dashboard.
    TIA
    Mga sir,
    TIA
    Jul 2015
    #2240
    For old cassette HU sir,meron nabibili na pang aux ung cassette na may wire na 3.5mm ung dulo,what APV po ba kayo? I or II? Type II ako my HU is a 2din 7" Touch Screen.
Suzuki APV [Merged Threads]
