Sir 12vdc,I left the car to our neighboring auto repair shop but they don't know how to loosen the tensioner?sabi nya di daw nya alam kung Saan iikutin? Para lumuwag.
Nakow, bukas na bukas din kunin mo na yung sasakyan. Hindi ako mekaniko at first time ko pa lang nahawakan yung makina noon alamko na kung panu luwagan, baka hindi mekaniko yung napag habilinan mo? You need to loosen the center nut of the pulley, then nasa bracket yung pang loosen ng belt mahabang tornilyo. Sa waterpump naman yung alternator bracket ang niluluwagan.
Pakita mo yung pic ng pulley assembly pinost ko, nandoon yung bolt na mahaba. Eto manual makakatulong din ma visualize ang belt orientation at deflection.
Wala lang torque setting pero prehas lang ng Vitara G16A engine.
Thank You sir! I will let the the nearest dealership do the job,I also found out that the labor they charging me is bit higher compare to the dealership, they charging me 900 bucks,450/ea belt tas bonus na daw ang bearing replacement.
Saan kayo bumili ng floor mattings ninyo? Maipis kasi yun naka installed ngayon. May binebenta ba buo na o kailangan customized pa?
^ copycat 3m nomad, sa divi 999 at 168 o sa tapat ng LCTM-american vinyl, P350 per yard kuha ko for the van and minivan. Sa goldrich banawe P2.5k/set yta last inquire ko pero hinang ang sidings kaya mas ok. Yung sa driver side ang impt original para hindi kaagad makalbo tapat ng pedals.
Sir 12vdc do you have a copy of the repair manual for our AC and clutch?ung same print screen that you have posted last time?salamat!
AC airconditioning? The last one i posted was the user manual w/c is included in the vehicle. The parts catalog is available for dL-its too big arnd 1.8gb iso img file. I dont have service manual for APV, but im using JX/JLX since it has the same/similar engine/drivetrain, its available for dL arnd the net. iL try to send you the dL link for the img and vitara SM if its still there.
2-DIN lang pala yan, got mixed up with EIA rack unit which is equivalent to 4U. [emoji16]
JonJon,
Sa Speedyfix ako. Bring your regular replacement parts such as air and oil filters, spark plugs and others.
Did'nt have much much time looking for good shops in the Antipolo-Marikina area
