Page 116 of 134 FirstFirst ... 1666106112113114115116117118119120126 ... LastLast
Results 2,301 to 2,320 of 2668
    Jul 2015
    Jun 2011
    #2302
    Napapalitan ko na ng fuse, meron pala reserve fuse duon sa takip, thanks.
    Mar 2007
    #2303
    Just come across the thread where some tsikoteers used Baldwin oil filters. Can i use this on the APV, maybe couple with sythethic oil for 10k intervals perhaps?
    #2304
    Quote Originally Posted by straker View Post
    Yes you can, just cross reference the suzuki pn with baldwin pn.
    Nov 2013
    #2305
    Baldwin BT223 swak sa G16 engine.
    Dec 2013
    #2306
    Quote Originally Posted by funkeemunkee View Post
    Sir, any idea san nakakabili ng baldwin filters?
    Dec 2013
    #2307
    Nov 2013
    #2308
    Volmax sa Binondo. Meron din sellers sa olx.
    Mar 2007
    #2309
    Salamat. Tapatan ko ko iridium plugs, ayos!
    Jul 2015
    #2310
    Guys any idea sa fluctuating engine temps? Bumababa ung temperature ng APV minsan.
    Mar 2015
    #2311
    mga sirs, malapit na mag 35k yung apv ko, and mag diy change oil ako using helix hx7, last change oil ko was 31k. sabay ko na rin ng airfilters and spark plugs.
    however, yung last casa ng previous owner at 28k nagpalit ng ATF. i read dito sa thread before na may papalitan pa na part sa A/T during 30k pms and hindi naman nagawa yun nung 28k pms. planning to have the A/T pms done at casa pero yun lang.
    ATF pump ba yung need palitan? am trying to backread pero hindi ko mahanap sa haba ng thread. how much din if ever.
    thanks!
    thanks!
    Mar 2015
    #2312
    nakita ko na, ATF filter replacement pala.
    #2313
    Quote Originally Posted by victorevolution View Post
    good thing naayos, auto din kasi tranny ng amin and pagkakaalam ko bihira bumigay ang ga ito and it would cost a lot just to get it fix
    Mga sir yung apv ko ayaw magstart. Check ko na kuryente ok, yung dustribution ng gas ok din. Spark plug check. Ano kaya sira nito?
    #2314
    #2315
    May redondo? Baka fuel pump.
    #2316
    Meron sir.. ok naman yung linya ng fuel pump sumisirit...
    Jul 2011
    #2317
    *rey752
    Baka tinanggal na yung thermostat or it's stuck open.
    Mar 2015
    #2318
    Kindly double check all connections. Baka battery poles. If still ayaw talaga mag start why not call a mechanic na lang sir.
    #2319
    Paano mo nakita ok ang kuryente? Check mo din ignition coils at crank sensor. Sana hindi ecu ang sira o putol na timing belt.
    May 2008
    #2320
    just click when trying to start? check the battery
Suzuki APV [Merged Threads]
