Page 115 of 134 FirstFirst ... 1565105111112113114115116117118119125 ... LastLast
Results 2,281 to 2,300 of 2668
    #2281
    Tsikoters! Ask ko lang kung ano mas ok sa tingin nyo na engine oil for APV?
    Shell HELIX or Castrol Magnatec? and why? Very much appreciated sa comparison. TIA!
    I'm on my 70k PMS na i guess next week, ipa-CASA ko na ba or sa Shell Service nalang? May 21 point check up din sila dun e.
    Mga na-raramdaman ko na:
    - Hirap umarangkada
    - May play after changing gear
    - Natigas yung shifting gear knob
    - FC (well very typical naman)
    - May humming sound pag nagtturn ako ng steering wheel
    Jul 2011
    #2282
    Try Havoline SF 20W-40 5000km interval.
    For the shifting problem change transmission oil.
    Jul 2015
    #2283
    Sir hindi po kaya sobrang makapal ang 20w-40? Manual recommend to use 5w-30 or 10w-30.regarding hard shifting, di kaya kulang na sa adjust ung clutch?
    #2284
    Yung castrol magnatec kasi 10w-30 or 40 ata yun.. then yung Shell Helix HX7 semi-syn ata.. Ano ba mas okay na brand?
    About sa hard shifting papatingin ko din yung clutch disc baka kailangan na palitan sa 8 years ba naman e.
    Jul 2015
    #2285
    To check the clutch disc sir,put the transmission of 5th gear then rev the engine upto 2k or 2.5rpm if the engine died you still have a good disc.Na try ko dati sa Innova ung hx5 ata yon ung fully synthetic nila.mas OK ung engine sound feeling ko mas smooth.baka same effect sa APV try mo hehe.
    Jul 2015
    #2286
    Sir 12vdc,na kapag palit kana ng water pump? The mechanic think na ung knocking or tsug tsug tsug sound ko is coming from the water pump.I have a very low rumbling and a very low grinding sound sometimes.I'm thinking of replacing the spark plug for the second time hehe,I find the spark plug color quite brown or reddish?is it normal?baka kase fuel or detonation knock sya? Bago na rin po pala air filter element ko,OEM filter,bagong oil change din po ako.
    #2287
    Napalitan narin driven pulley bearings? Hindi pa ako nagpapalit ng waterpump but one way to isolate the sound is by removing fan belt. Baka sa fan motor lang yan, had mine replaced dahil intermittent yung grinding sound then one day it sounded like a dying animal then seized, buti na anticipate ko may spare fan motor ako nka ready.
    Btw normal lang yung reddish sparkplug, check mosa ngk site may reference color sila doon.
    Jul 2015
    #2288
    Sir ano po ung driven pulley bearing? Ung bearing ng AC compressor and other accessories? Or ung tensioner bearing ng AC and power steering? Sa engine bay talaga galing sir wala po sa harap na area,OK lang kaya sir kase pag tinaggal ko ung belt ng water Pump and Alternator dikaya mag over heat kahit sandali lang?pero nakakapag taka parin kase pag naka stop ako or naka park pag AC off tas ni rev ko upto 2k RPM mahina lang ung tsug tsug tsug or knocking pero pag binuksan ko ung Ac mas lumalakas ung tsug tsug or knocking. One thing pa po pala sir kaya na pin point si water pump.,routine ko na na kahit Diesel or gas ung kotse before ako umalis start ko muna then I let it idle until it reach ung operating temperature nya.one time malamig ung weather before I leave our garage normal operating temp na sya tas mga 100 meters na naandar ko I turn the AC on maya maya bumaba ung temperature nya tas mga 5mins bumalik na uli sa normal temp? I guess due to cold weather tas pag on ng AC bumukas ung rad fan kaya lumamig?
    #2289
    Pwede naman tanggalin yung belts kung short distance para lang ma isolate yung source ng sound, pero diskarte parin ng mekaniko. Lumalabas yung sound kung may load sa a/c baka pulley bearings or clutch problem. Mahirap mag guess kung walapa ginagawa kahit isa, elimination method ang procedure ng troubleshooting and do the obvious source of problem muna.
    #2290
    Pwede rin remove the thermostat to check if waterpump is working. Saglit lang din baklasin waterpump kaya lang ready ka na ng sealant at new gasket, mas ok parin check mo muna yung pinaka madali. Normal yung bagsak temp sa first start kung malamig ambient air, importante maintained nya sa operating temp.
    Jul 2015
    #2291
    Naka pag pa palit nako sir ng tensioner bearing,ac pulley bearing saka ung dalawang belt,pano ba sir sound ng engine knock or ung detonation knock? Di kaya engine knock sya? Kase pag loaded ung engine saka lumalakas?
    Jul 2015
    #2292
    Kailangan pa ba sir tanggalin ung timing belt to remove the water pump?
    Jun 2011
    #2293
    Kainis meron ako nabiling pang linis, sinasaksak ito sa cigarette lighter. Biglang namatay stereo ko at pati cigarette lighter ayaw na magbigay ng power.
    Saan ako pwede magpagawa etong sinira nitong item na ito? Hindi na din ako makapag charge sa ipad ko kase nga ayaw na mag bigay ng power yung cigarette lighter.
    Jul 2011
    #2294
    ^ Just check all the fuse.
    #2295
    There
    Jun 2012
    #2296
    ^fuse yan for sure
    #2297
    Quote Originally Posted by rey752 View Post
    I don't think so. Its one of the driven components with the alternator? Kindly check the manual.
    Jul 2011
    #2298
    Ito kagandahan s apv external yung water pump unlike my other car, timing belt ang nag papaikot sa water pump.
    Jul 2015
    #2299
    Sir I got this from the net. Re: water pump location.
    Jul 2015
    #2300
Suzuki APV [Merged Threads]
