Page 32 of 35 FirstFirst ... 222829303132333435 LastLast
Results 621 to 640 of 691
    Jul 2010
    #621
    Quote Originally Posted by baker123 View Post
    hi kenn. radiator hose with holes doesnt mean theres more problem with the engine. it could just mean the hose is already weak or just punctured.
    replace your hose as soon as possible. the water in the engine is very important to avoid overheating and doing damage or more damage in the engine.
    as for the check engine light. after filling up the radiator with water. try removing the ecu fuse for a minute or more. or remove the batter ground or positive for more than that. then attach again. it should reset the check engine light. but, if it still lights up after. you may have more problems than just missing radiator water. hth.
    hi sir. thanks for the input. verify ko lang po. yung hose kasi is at the back side of the hood. closer to the windshield side than the grill. tama po ba na yun yung radiator hose? TIA!
    Jul 2010
    #622
    Quote Originally Posted by kenn.garcia View Post
    Hello again,
    Been trying to find the website link I saw here before sa tsikot na may complete reference to Vitara JLX parts. Tried to read back on this thread pero di ko na po makita. You might have bookmarked it on your PC's. Pa share naman po. Thanks!
    up ko lang po! baka meron din po kayo ibang website references. please share
    Sep 2011
    #623
    gud am. ask ko lang po best battery for my vitara, ngayon lang ako magpapalit. ano advisable, ok lang ba 2sm?
    Jan 2003
    #624
    think the hose that leaked is the hose coming from the block going to the fire wall. it's the a hose about 1/2" diameter. it goes into the cabin, it circulates hot water from the engine block to the aircon heater. mine is already bypassed. made the a/c cooler, as even if you don't use the heater it will still radiate heat and affect temp. also did it to my sister's gen 1 crv.
    Jan 2003
    #625
    1SMF po ang orig ng vitara sir Vitbox. just replaced mine last month, delkor ginamit ko. the motolite green it replaced lasted 2 years 2 months.
    Jan 2003
    #626
    Jan 2003
    #627
    tsikot thread of the suzuki parts dealers
    http://tsikot.com/forums/suzuki-cars...6/#post1399710
    Mar 2004
    #628
    hi kenn. check out impulz's post. if yun yung sinsabi mo. thats still important to be sealed. or replaced. any leak of water or oil from the engine is bad actually.
    Jul 2012
    #629
    Magaganda mga Vitaras mga sir, hindi nakaka-panghinayang. Highly recommended, lalo na mga Suzuki Grand Vitara. Nagkataon lang na parang hindi gaanong tinatangkilik ng Pinoy ang Suzuki, and we don't know what we're missing.
    Nakakuha ako dito sa Australia ng 2.7-litre V6 VVT all-time 4-mode 4WD, 2nd hand, for PhP740,000 equivalent. May kasama na itong Diamond Parts and Labour Warranty of up to 225,000 km. Odometer niya nang kinuha ko ay 60,000 km.
    http://i1143.photobucket.com/albums/...Untitled-2.jpg
    http://i1143.photobucket.com/albums/...012023_a-1.jpg
    http://i1143.photobucket.com/albums/...Untitled-5.jpg
    http://i1143.photobucket.com/albums/...Untitled-6.jpg
    Laki ng paghanga ko sa Suzuki magmula ng naka-test drive ako at lalo na ngayon na Grand Vitara gamit ko. Samantala dati hindi ko man napapansin mga ito sa Pinas. Ngunit ng dahil sa mga nakita ko sa Suzuki dito, lalo na sa Grand Vitara at SX4 na 4x4, mas pinili ko si GV kaysa kay Subaru Forester 2.5 XT.
    Jul 2010
    #630
    Quote Originally Posted by impulzz View Post
    Thanks sir impulzz. Downloaded the SQ416, SQ420 and SQ625 collection of manuals from the same site. Lotta help!
    Jul 2010
    #631
    sige sir kunan ko din ng picture. di ko ma recall but it seems to be bigger than half an inch in diameter. although kung passage nga to ng hot water, possibleng eto din yung tinutukoy nyo kasi nung na puncture siya ay malakas yung sirit ng steam from the hose.
    #632
    mga sirs, makihingi lang ng konting information (sa mga owners) about vitara 2006 model. balak kasi namin ni misis kumuha ng mas malaking sasakyan and may nag-alok kasi sakin nito, pero gusto ko muna sana malaman yung mga issue/s ng modelo na 'to (kung meron) and kung anu-ano usually mga nagiging problema. wala kasi ako masyado alam sa model na 'to. na-test drive ko na 'to, yung handling nya e ok naman and kumportable naman ako.
    tia mga sirs!
    Jul 2010
    #633
    Sir Impulzz may nakita po akong engine diagram. same po ba ito dun sa warm air hose? Based po kasi sa diagram parang close match dun yung nasira kong hose.
    Jan 2003
    #634
    anong page dun sa manual? post mo yung diagram dito if you can
    Jun 2008
    #635
    Mga ser pa OT lang po baka interested kayo suzuki gen 1 vitara snorkel po =)
    FS: Fabricated Vitara Gen1 (Local) Snorkel (made of Fiber Glass Material) for G16B engine.
    Price: 4.8k (installation, screws, brackets are not included but i can provide details on how it can be done)
    Contact: 09175901220
    For additional details and pictures just ping me your email add. Thank you po.
    Aug 2012
    #636
    Good day, question lang po, meron kami vitara 96 model automatic transmission. last week pinalitan na ung crankshaft pulley since pasira na sya then yesterday napansin ko na after ng cold start then warmup ng 5 mins, kapag mag drive na hinde umaakyat ng gear laging nasa 1st gear lang sya, after ng ilang minuto sya aakyat ng gear. May naka experience na kayo na ganitong scenario 2nd hand ung sasakyan hinde namin alam kung may napalitan na sa transmission.
    Thanks!
    Aug 2012
    #637
    Quote Originally Posted by Ramil Baytion View Post
    Thanks!
    Transmission slip ata ang tawag dito?
    Jan 2003
    #638
    try changing your a/t fluid and if your mechanic can pull down the a/t oil pan to clean the filter inside. mine sometimes on cold start won't engage reverse. but after a changing a/t fluid it did not happen again.
    Apr 2005
    #639
    Does anybody know where I can buy a brand new radiator for a 96 Vitara aside from the casa?
    Mine has a leak and the radiator shop said its beyond repair and all they sell are surplus radiators. The one in my vitara is also a surplus one from the previous owner. I prefer copper/brass radiators, but i am willing to get a plastic or aluminum one as well if the price is right.
    Nov 2004
    #640
    Quote Originally Posted by Jo A. View Post
    Try mo sir sa Fronte (Banawe), Goodgear (Pasay). Relatives may ari nyan, dealer sila suzuki parts. Kung wala readily available pakiusap mo by order, mabilis naman, nung may pinakiusap ako pyesa for Jimny 4days lang ako naghintay.
GEN I Suzuki Vitara 88-up [merged]
