Page 155 of 193 FirstFirst ... 55105145151152153154155156157158159165 ... LastLast
Results 3,081 to 3,100 of 3844
    Oct 2009
    #3081
    Next project naman is electricals, aircon and cable ng gas tank kasi ayaw bumukas from the lever sa driver side. Nag drain na din ang mekaniko ng gas tank at puro putik na ang laman sa loob kaya naging barado na ang primary na fuel filter. Hopefully i could restore the van to top shape. Medyo may tumutunog sa ilalim pag nag engage ako ng first gear but not that noticeable pa naman. My wifey loves the van kasi malaki and the kids need the extra space.
    #3082
    Quote Originally Posted by bluwave View Post
    Good PM mga sirs, just finished having the van fixed. Change belt, water pump, filters, glowplug and oil. ALthough 1 click andar na siya now, ang problem is ayaw naman mag shut off ang engine so i had to put it to first gear at pakawalan ang clutch para patayin ang makina. Ano kaya mga sirs ang problema nito mga sirs. And another thing na i noticed is after some time na umaandar ang van, biglang umaandar ang glowplug light.
    This just happened to me. Nahugot yung isang vacuum hose near the injection pump that shuts the engine off. Baka mas ma-explain nila sir Glenn ng mas maigi. Hindi ko na po napicturan kasi ang bilis lang naibalik then lagay ng zip tie at konting pandikit para hindi na mahubo.
    Glowplug lamp while driving means one of the glow plugs is not functioning. Either the glow plug itself is broken or just some loose wiring.
    Oct 2009
    #3083
    Sir Glen,, paging sir Glenn... need your expert advise..
    ANother problem pa is scouting for a new wiper motor. Anu mga sirs ang pwede na replacement na wiper motor sa mb natin? Pwede kaya ang pang sportage? ang sabi sakin ng mekaniko L300 daw pa convert. Need your expert advise
    Jul 2003
    #3084
    meron bang equivalent ng K & N Filter para sa MB100 natin?
    na try nyo na ba yung TOP 1 Oil for MB100?
    Jun 2011
    #3085
    Quote Originally Posted by acenie View Post
    NA try ko na... next best motor oil ive tried para sa mb100...
    next lang sya sa Zic power....
    Jun 2011
    #3086
    sir.. wala pa akong alam na nag convert ng wiper motor ng mb100...
    go for surplus Original nalang po....
    try nyo awons... call them baka nag ship sila.... look for paul (09198217978) sya yung bodegero...
    #3087
    Yes sir go for orig ssangyong/mercedes parts. Its worth the effort po. Try jun mac in calumpit if they ship. The photos are some pages back.
    Jun 2009
    #3088
    mga ka MB question lang po 1st time ko lang po kasi gagamit ng Tensioner pulley na Korea malimit ang malimit ko po gamit kasi eh Germany... ask ko lang sana po kung matibay din ba ang Korea na Tensioer pulley at gaano po itinatagal nito? kinakabahan kasi ako baka mamaya bigla mabaak yung Pulley please advise TIA....
    Jun 2011
    #3089
    tumutonog sa ilalim pag nag engage ka ng gear... sir baka po engine support.... more or less 150 each lang yan sa fronte..
    dalawa ang kailangan.....
    Jun 2011
    #3090
    Quote Originally Posted by jjj_in1056954 View Post
    pareho lang sir tumatagal... ang nasisira sa tensioner lever eh yung nasa loob nagagasgas... hangang sa tumabingi na.... kaya dapat nilalagyan ng grasa... at dapat din po yun cover nyo sa may hood para sumalo ng tubig eh nasa ayos para hindi basta basta nababasa.... yung sakin tumagal siguro ng more than 3years...
    Oct 2009
    #3091
    ok sir glenn. Thanks very much talaga. dami nag discourage sa akin about mb100 pero ang pagkakaalam ko e bullet proof engine ng mga van natin at depende lang sa pag mentain ng owner.
    Jun 2011
    #3092
    PAG DATING sa engine Bullet proof talaga....
    dati nagtanong kami sa fronte kung anong part ang hindi mabenta sa mb100 ang sabi engine parts daw... halos wala daw talaga bumibile...
    then ask ko naman kung ano ang pinaka mabenta.. ang sabi pare pareho na lang daw....
    Dec 2012
    #3093
    mga sir magkanu po engine support.. sabi kc skin dto sa baguio 1000 daw ung dalawa? tama po ba ito?
    Jan 2013
    #3094
    Hello po mga fellow MB100 users, may itatanong lang po ako, pag nagcocoldstart ako sa umaga, pagmagstastart na ako ng engine, magliclick lang then balik ko sa on ulit, then sa 2nd attempt, parang may delay na 1.5 seconds tapos saka magstart ang engine.
    Nagtry na akong magpalit ng battery and naglinis ng terminals lalo na sa positive and negative wires, ganun pa rin.
    Dati naman eh 1 click (1 second) start naman dati. Bigla na lang siyang nagkaganun. Ano po kaya ang problem po?
    (maintenance-free pala yung battery na gamit-used)
    Thanks in advance for the inputs.
    Jun 2011
    #3095
    Quote Originally Posted by eojan View Post
    last time na bumile ako 150 each!!! grabe naman 1k dalawa... try mo contakin fronte baka pwede sila mag ship...
    Jun 2011
    #3096
    Quote Originally Posted by webieforums View Post
    sa susian na po ang problema nun... kalumaan na po siguro
    ganun din sakin... may time ganun ang nangyayari....
    try mo palitan nalang ng push start button... si sir hapigolaki. ang nag palit po ata ng push start button....
    yung sakin po taon nang ganun...
    Jan 2013
    #3097
    Ganun ba sir Glenn, ang problema lang kasi is nandito ako sa region 1. 2nd owner pa lang kami nitong van.
    Kung sakali pong mapapalitan ng push button start, assembly ba siyang bibilhin?
    Thanks po in advance
    Jun 2011
    #3098
    sir si hapigolaki po ask natin dyan... at sya po ang nagpalit... parang nasa 2k ata ang bile nya sa sulit.....
    sir mag back read kayo ang daming na post na dito na pwedeng bilhan ng parts ng mb natin try nyo contakin at baka pwede silang mag ship... actually pag pupunta ako sa fronte pwede ko naman kayo buy din then ship ko sa inyo...
    Jun 2009
    #3099
    Grabe ang mahal talga ng Gulong ngayon dati ang bile ko lang sa Yokohama Geolandar H/T-S ko na 215/70R16 ay Php.4,000 year 2011 ngayon Php.5,172 na meron inoffer sakin na Sailun brand na Tires 8PR 215/70R16 Php.3,800 ask ko lang sana kung matibay kaya yoon SAILUN or tama ba ang choice ko na mag yokohama parin ako kahit 6PR lang siya...
    Dec 2012
    #3100
    sir mag back read kayo ang daming na post na dito na pwedeng bilhan ng parts ng mb natin try nyo contakin at baka pwede silang mag ship... actually pag pupunta ako sa fronte pwede ko naman kayo buy din then ship ko sa inyo...[/QUOTE]
    sir glenn kelan ka punta ng florante??? pabili sna ako ng engine support kc pag ky fronte bka ayaw i ship kc worth 300 lng bibilhin ko bka kung pwede sau nlng sir..tnx
MB100, Ssangyong/Daewoo Istana [continued]
