Originally Posted by
bluwave
AFter many tries, i tried to trace up kung saan nagkaroon ng ground and it seems that yung paglipat ko ng halogen bulb from left to right kasi thinking na pundido ang right headlight was the culprit sa pag xmas lights ng instrument panel ko. So resorted to transfering the bulb on the left side again and have an electrician check the wiring ng right headlight.
I have a question mga sirs, tiningnan ko ang mg vacuum hoses running along the left side of the engine. Ang vacuum hose coming from the rear of the engine is going to the area under the steering wheel and is not connected to anything. Is this normal. There are 3 hoses coming into the steering wheel but only 2 hoses are connected. Need your advise mga sirs where it should be connected kasi i cannot turn the engine off through the switch. Before nagalaw ng mekaniko who changed the belt ng van, i cannot shut off the engine via susian.
