Page 165 of 193 FirstFirst ... 65115155161162163164165166167168169175 ... LastLast
Results 3,281 to 3,300 of 3844
    Mar 2013
    #3281
    The valve cover gasket is just the superficial gasket that runs around the top of the valve cover. Here it is, newly replaced (with white seal) on my unit:
    Sa aircon, normal po na unang masira ang #1 because it is the one with the highest resistance. The resistor is working hard to lower the speed. When you run the fan at high speed, the resistor just lets all the current pass through. Repairable po iyan sa aircon shop.
    If front a/c is colder than rear a/c, the expansion valve might need replacement at the next a/c cleaning session.[/QUOTE]
    Thanx po Doc Otep sa reply... Magkano po gastos nyo sa pagpapaplit po ng valve cover gasket kasi iyong van po namin may leak po ng oil sa may parang half moon po nya.. Saan po kaya maganda magpaayos ng a.c. Magkano po kaya aabutin repair ng resistor block, expansion valve, at pati nrin po cleaning saan po kaya maayos magpagawa Sampaloc, Manila po ako saan po mejo maka tipid po ng konti kasi mejo kulng po kasi budget natin eh.. Pahabol po maingay narin po fan ng Rad. Yun po ba ang (clutch fan) may trrrrrrrrraaaaaaakkkkkk sound po sya para mas malakas pa po tunog nya kesa andar ng makina... Thanx po uli.... Pa-share naman po ng mga idea nyo mga sir para po marestore sa dati van namin sensya na po bago lng po kasi sa amin ito...ty
    Apr 2012
    #3282
    nagbabawas po pero dahil lumalabas sa spout sa sobrang init na ata. Di ko na maalala kung anu ung stock eh kasi napalitan na rin ung last. .9 lng ung luma. Pag barado po ba, ok lang ba yung overhaul ng rad? or mas maganda kung bumili ng bago?
    #3283
    Mas advisable na bago nalang. Hindi naman yata sobrang mahal. Napost ni doc otep dito dati na nagpalit siya. Few pages back palang yun
    #3284
    Nasa 5k ang srp ng new rad nowadays, mas mura daw sa tindahan ng evercool sa Benitez? That's in Chinatown, right?
    Low speed/climbing overheat is a circulation problem. Baka po water pump or radiator na barado.
    Clutch fan meron sa banawe nun. But if you buy the new fan, you have to buy the new fan blade also. Sa apic banawe po expert sila sa mb100, dun nagpapagawa yung mga namamasada at school bus. Sa Dr. G's car clinic po ako nagpapagawa kasi sila gumagawa ng Toyota ko. Pero hindi sila mb experts.
    Yung switch ata ng aircon si e.d.s. car aircon nakagawa. Yung recommended shop ni sir glenn manikis. Ok dun.
    #3285
    Benavidez doc. Nakikita ko signage nila. Malapit sa corner of recto
    Apr 2012
    #3286
    Thank you po sa advice ninyo. Taga davao po ako eh. Try ko mag canvass muna dito kung magkano.
    Mas ok po ba ung evercool? Anu po magandang brand ng clutch fan? Kung pa rad overhaul ko muna, pangit parin ba ang kalalabasan? Feel ko bumara ang radiator dahil nag lagay ng stop leak ung lumang driver namin eh after flush ng radiator. Parang bleed lng ng hangin un kaya nagbawas. thanks ulit
    #3287
    Quote Originally Posted by semajpay07 View Post
    They say Evercool is ok. But I used Three Star brand from Korea which was what we could find in Banawe. Evercool was being sold at Php10k in Banawe so I passed. Three Star didn't have the thicker radiator that the MB100 uses locally, all they had was the standard thickness radiator. But Three Star is a reputable company so I got it anyway.
    Clutch fan of the MB100 is now a viscous fluid type manufactured by GMB. The old bearing type clutch fan was made by BEHR. If you change clutch fan, you need to change the fan blades as the BEHR used a different hub from the GMB.
    Yes, stop leak will kill your radiator. After my new radiator, no more overheat problems running at top speed with lights and sirens.
    Old radiator. Notice how much thicker it is. All local (CMC) units used this kind of radiator:
    Updated fan clutch by GMB. It came in the OEM Ssangyong packaging:
    Mar 2013
    #3288
    Thanx po uli sir OTEP.. Sanpo ba banda shop ni e.d.s car aircon sir po post naman po if meron kyo...thanx po...
    #3289
    Mwss village po sa mindanao avenue iyon. Here is their cell number po. Medyo may smaller street kasi na dadaanan. 09223241498
    Mar 2013
    #3290
    Thanx po uli sir more power sana po wag kyo magsawa sa pag reply sa mga katanungan namin...
    Mar 2013
    #3291
    Mga sir help naman po yung mb 100 po kasi namin may kain po sa inner part po ng gulong magkabilaan po wala naman po kabig kaliwa man po or kanan.. Ano po kaya posible case nya bakit ganun po ang kain ng gulong... Pa share naman po ng mga ideas nyo at kung saan po pwedeng ipaayos...thanx po sa lahat ng ka-MB....
    Apr 2012
    #3292
    How much does the three star cost? Last time I checked, fluid type ung clutch fan and i think ok pa naman. Just refilled it with silicon oil eh. ipapa check ko ulit sa shop ung radiator ko. Thank you sa mga nag reply
    #3293
    4k ata srp nung radiator. Pasensya na hindi ko maalala exact price. Sinabay ko lang kasi pagbili ng ibang parts that time.
    Jun 2008
    #3294
    Quote Originally Posted by pungdol View Post
    Pa check nyo po ang camber. Yung ball joint ng suspension isama na rin..
    Mar 2013
    #3295
    Quote Originally Posted by weisshorn View Post
    Thanx po sa reply sir weisshorn.. San po kaya pwede magpacheck ng camber at nasa magkano po kaya aabutin sir?
    Jun 2011
    #3296
    kung hindi na makaya sa camber.... check nyo din suspension bushing po.... baka need na din palitan... mura lang isa nun nasa 150 each.... 4pcs yun each side... need ng machine shop para masalpak ng mabuti.... at wag nyo po papagawa basta basta sa hindi kabisado mag palit ng suspension bushing natin at kung hindi... sisirain lang nila yung bushing nyo... then you might need na din po palitan (90%) ang camber bolt... pati din yung bolt sa upper bushing.... dont forget din po na lagyan nyo ng grasa.... then before nyo ikabit na yung arm tadtarin nyo ng grasa yung suspension bushing para hindi basta basta pasukin ng dirt...at para hindi din agad magkaron ng ik ik sound....
    Mar 2013
    #3297
    Maraming salamat po sir glenn manikis...san po kaya mas avisable na ipagawa sir sa banawe po kina or sagoddgear sa pasay? Thanx po uli..
    Jun 2011
    #3298
    better sa goodgear....
    wala kasi ako tiwala dun kay apic eh... pero magaling din sila gumawa....
    Mar 2013
    #3299
    Thanx po uli sir glen... Sir magkno po kaya papalit expansion valve at palinis narin po ng a.c dun sa e.d.s po ba yun nirerecommend nyo sir?
    Jan 2012
    #3300
    mga ka mb ano po ba price ng thermostat ng mb natin sira na ata tong thermo ko wala na sa normal operating temperature ang needle
    taas lang ng unang guhit.. gusto ko malaman yong price para malalaman magkano budget?
MB100, Ssangyong/Daewoo Istana [continued]
