Results 181 to 190 of 5235
February 12th, 2006 12:36 AM #181
Originally Posted by garyq
February 24th, 2006 09:34 AM #182
hi,
pls advise the correct size/lenght of front "Kyb Gas adjust shocks" for the dmax.
been going around auto supply stores and they still do not know the correct kyb shocks unless you provide a sample.
but since im in a hurry, gusto ko dala ko na correct shocks then pakabit ko nalang sa servitek or similar. and i do not want to visit the casa for this kind of job.
for those aftermarket shocks like OME and Ranchos, wht size/lenght do they use for the dmax, front shocks only.
thanks
- Jan 2006
- 191
February 27th, 2006 03:12 PM #183cardo..i like your set up ah..san mo nakuha ung grill mo???ung mags and tires mo anong specs???sakto eh..
- Feb 2006
- 1
February 28th, 2006 10:54 AM #184vibration on steering wheel column at 1k rpm idling. any experience like this?
February 28th, 2006 12:05 PM #185
Originally Posted by 2tc
maybe its normal coming from the vibration of the engine, if you still have doubts have it checkd at isuzu dealer, maybe you have something loose in that area.
but your idling speed is too high, mine; with aircon 850rpm, without aircon 750rpm. basta both a couple og "guhits" from 1k on the tachometer.
February 28th, 2006 02:46 PM #186
Originally Posted by vanleano
and I had it painted sa dealer as well. Yun mags 16's sya AR(american racing), got it somewhere in evangelista. tires are same size as stock. they are dunlop grandtek at's.
- Jan 2006
- 191
March 2nd, 2006 01:17 AM #187thanks. simple lang sya hehehe. dealer ko nakuha yun grill and I had it painted sa dealer as well. Yun mags 16's sya AR(american racing), got it somewhere in evangelista. tires are same size as stock. they are dunlop grandtek at's.
March 10th, 2006 10:00 PM #188
the grill here in cebu roughly costs around 5 to 6k. maganda sana mak 20 or 22's sa dmax natin, kaso lang ung ride natin. parang wala nang shocks at 10 na ung leafspring natin instead of 7. hehe
- Feb 2006
- 12
March 11th, 2006 06:10 PM #189mga sir, ano po ba ang ideal na tire pressure (using stock tires) for the dmax?
March 12th, 2006 04:51 AM #190
meron naka-dikit sa driver side door panel, di ko ako sure kung 29 psi(front), 31 psi (rear)
check mo na lang.
Some other dcts, like dun sa 1.6 na hyundai & kia crdis, nagka-issue rin bt. Not sure lang if...
2022 Hyundai Creta
