Results 2,301 to 2,310 of 3575
June 3rd, 2014 02:33 PM #2301
- Nov 2010
- 369
June 3rd, 2014 04:39 PM #2302
June 3rd, 2014 06:46 PM #2303
I don't know what Toyota Shaw did but the sound has decreased significantly. I still get creaking sounds though when i brake while the suspension is going through a hump, dip or bump. I plan to experiment by changing the caliper pins when i have the time.
- Jun 2014
- 3
June 10th, 2014 09:55 PM #2304thank God for this forum and thread.
anyway brief background lang kasi baka it might seem na noob yung ibang questions ko. well, for most of my 10 years, ae92 and ae101 trueno ang gamit ko. then my mom in law, sold me her 10th gen altis A/T for couple hundred grand as wedding gift na rin sa amin ng fiance ko. which is on december by the way. so there, kaya medyo di ko kabisado ang modelo.
anyway it has 40,000+ kms now. just last march, i started using the car more often. i felt na medyo mabagal siya compared dati (kasi dina-drive ko rin naman ito before). as in pag binaon mo yung gas, ambagal talaga niya pumick up as in. hindi naman siya palyado, wala naman tope, smooth idle, and it can reach naman 100km/hr speed as ive tried it. but the acceleration, significantly decreased talaga. pero once it picks up, ok naman, pretty much normal.
anyway, i had its oil changed since then. since sobrang dami na ng air filter element, i instead put in a cone type filter without replacing the tubes.
i reset the ECU. i even cleaned the MAF using contact cleaner. still the same. acceleration is really slow.
ano pa ba posibleng culprit nito?
-plugs di ko pa napapaltan pero i cant even spark plugs causing this significant loss in acceleration
-may mga dapat ba akong papaltan since over 40.000kms na siya? fluids, parts and all?
-tuneup? basically, ano ba ginagawa sa tuneup ng ganitong oto? at saan ok?
kasi sa ae92 ko, tuneup means adjust timing, adjust camgears (adjustble). pihit distributor etc. eh how about sa altis?
again sorry for making such a long post. like i said, sa mundo ng altis, baguhan po ako.
PS: years ago pina-camber align yung oto, since then hindi na bumabalik mag isa yung manibela. pero magaan and all. ano kaya culprit nito? or is this normal?
- Jun 2014
- 3
June 10th, 2014 09:55 PM #2305thank God for this forum and thread.
- Mar 2008
- 54,281
June 10th, 2014 11:13 PM #2306how's the automatic transmission fluid status po?
and i'd still check the sparking plugs, just for completion of check-up.
- Nov 2013
- 4
June 11th, 2014 12:47 PM #2307Hello everyone. I apologize if this problem has been posted somewhere else, but I really need help.
I recently got a secondhand 2009 Toyota Altis. I have been noticing a crayon smell. I have checked and sniffed every surface and it seems to be concentrated on the passenger-side carpet. I have removed the mats on both driver-side and passenger-side and the bottom side reeked of the crayon smell. The thing is, the driver-side carpet doesn't smell like crayons, only the passenger-side carpet does. No smell on the seats, the dashboard, the steering wheel and the gear shift (just sweat smell), and the rear carpet.
I have sifted through the internet and asked a few car cleaning business and have found the following possible reasons:
- freon leak (from a cleaning business)
- "That particular smell is quite consistent with the Altis." (a different cleaning business)
- wax used to glue the interior
- mold in the vents
Any input will be appreciated.
- Jun 2013
- 179
June 11th, 2014 05:06 PM #2308Mga Sir sorry kung off topic, gusto ko lang sana humingi ng advise about my 2009 Altis. Balak ko po sya ibenta hindi ko lang po alam kung how much. Bale 2009 Altis MT 1.6G, 24K kms pa lang po, mods po eh head unit, spring and tire and mags.
Salamat po.
- Mar 2008
- 54,281
June 11th, 2014 05:14 PM #2309
- Jun 2013
- 179
June 11th, 2014 05:24 PM #2310na check na po ako gusto ko rin lang kumuha ng inputs dito kasi mas may tiwala ako dito sa forum.
thanks anyway Sir.
Thread was made nung 2018 pa po sir.
Montero Sports hot starting problem
