Results 1,851 to 1,860 of 2560
- Jan 2013
- 38
September 26th, 2013 12:07 AM #1851Good day po. Ano po size ng gulong nyo and series nya? Rim 14/Series 60(?) po kasi ang default. Habang lumalaki diameter nung gulong mo, liliit naman ang series nya. Sa akin ay Rim 15/Series 55. And kung loaded naman ay hindi sya sumasayad kasi umiilalim sya sa fender edges habang lumalapit ung gulong. Kung weak na yung springs dahil sa katandaan, palitan mo nlng. No need na mag-lift ka kasi malambot pa rin ung springs--kahit bali-baliktarin mo man yan.
- Aug 2013
- 4
October 5th, 2013 06:38 PM #1852Good evening to all. May problema po and Lancer itlog GLI ko. Unstable po ang idle kahit off ang aircon.Bouncing po ang meter sa rpm gauge. Naka bypass na po ang servo for my aircon at okay po ang rpm kapag on ang AC. Ano po kaya ang sira at dapat kong palitan?
October 7th, 2013 12:13 PM #1853
October 7th, 2013 12:21 PM #1854
- Jun 2012
- 13
October 13th, 2013 11:39 PM #1855Hello po...newbie hir and first ever post q dito...lancer 96el owner po kakakuha q ln kahapon...pasali d2 para matuto...ala pa q knowledge maxado sa kotse...gang motor ln alam...tnx
- Apr 2010
- 268
October 14th, 2013 12:58 AM #1856
- Jun 2012
- 13
October 14th, 2013 12:25 PM #1857Tnx po sir...hehe...unang question ko po anu po magandang brand ng coolant s radiator...prang kulay green kc nkikita ko n nkalagay s akin...sv ng dating may ari mas maganda dw gamitin ung kulay pink...d nia din alam ung brand...cenxa n po la tlga alam s kotse...tia sa sasagot...
October 14th, 2013 01:33 PM #1858
- Oct 2010
- 240
October 14th, 2013 02:12 PM #1859sir kurt, for light vehicles, any coolant/color will do, but don't mix them together, stick to one color only. flush your radiator thoroughly including the overflow reservoir before using a new coolant. you can also choose the cheapest brand basta pasok sa specs and follow the instructions written on the container.
kung medyo oc, use mitsu's coolant sold at el dorado.
- Jan 2013
- 38
October 21st, 2013 01:12 PM #1860Prestone coolant lang din sa akin. Pre-mixed kasi tamad ako tantsahan ng 60/40 sa radiator. Hahaha.
Coolant...
