Page 8 of 13 FirstFirst ... 456789101112 ... LastLast
Results 71 to 80 of 124
    Mar 2004
    #71
    My personal rule kung di kaya magpalit ng 4...
    2 muna and lagay sa harap... Luma sa likod.
    Place the tires with more grip at the rear ...
    Mar 2004
    #72
    Oh no, baligtad yata paniwala ko all this time. I always put older tires at the rear. I've always thought Mas may tendency mag flip over yung car if pumutok yung harapan. Guess I need wheel rotation soon.
    You shouldn't even be using those tires if you are concerned they might blow up ...
    #73
    I try to rotate my tires regularly so that they will all need replacing at the same time. If I need to replace only 2, I put them up front, just personal preference. I find that they scrub in faster up front. But I drive as though it were a new car with brakes that haven't been broken in.
    If I suspect I may have misalignment up front I put them in the rear.
    #74
    I also rotate my tires so that they wear evenly and eventually I replace all 4 at the same time.
    My Kumhos are now at 35,000 km travelled and I'll probably replace them in the next 2 months. Eyeing the GT SX2 or Yoko Advan V701 - I want something grippy, I need something that lasts long.
    Feb 2015
    #75
    But on a tire blowout scenario, which is more survivable?
    Blown front tire or back tire?
    #76
    Quote Originally Posted by makelovenotwar View Post
    Front. You still have your steering to get the car back in control.
    A rear blowout is prone to oversteer which most people don't know how to react to.
    Feb 2015
    #77
    I see, thanks.
    Then new tires should always be on the rear.
    Jul 2013
    #78
    I disagree...
    Kapag likod ma-flat, mas madali icontrol yung car.
    Sa harap, biglang kakabig yung car sa direction ng flat tire.
    Wag ka lang biglang mag-brakes...
    i'd put the thicker tires in front
    #80
    Thicker tires should be in the front if ever the tires are for replacement already.
When Do You Replace Tires?
