Page 4 of 7 FirstFirst 1234567 LastLast
Results 61 to 80 of 124
    #61
    Quote Originally Posted by kabute13 View Post
    my personal practice is to replace tires on the third year after it was installed, kahit makapal pa. And i always replace in pair.
    whypo replace them on year three??
    Apr 2006
    #62
    Peace of mind.
    And nakasanayan na din, kasi where i lived before (about 2km away from blumentritt, manila) you can easily trade your used tires for brand new tires at very reasonable price.
    #63
    Peace of mind.
    tanong ko.. magkano ang trade in value ng used tires ninyo?
    Sep 2006
    #64
    Quote Originally Posted by mda View Post
    Old tires should always be in front, sir.
    Losing a control of / or a front tire is easier to control than losing control of the rear...
    Oh no, baligtad yata paniwala ko all this time. I always put older tires at the rear. I've always thought Mas may tendency mag flip over yung car if pumutok yung harapan. Guess I need wheel rotation soon.
    Jan 2009
    #65
    If you always drive at highway speeds and/or on twisting roads, new tires goes to the REAR.
    If you predominantly drive in Metro Manila, new tires in FRONT.
    The assumption here is that, in either cases, the old tires are still road-worthy.
    Mar 2004
    #66
    I know someone from Melbourne (I have a lot of stories from this guy since wais sya sa buhay... better term is magulang)
    He bought a tire from a reputable service centre with warranty... Before the warranty ends, I-run flat nya konti yung tire para mag karoon ng side wall damage...
    Tire gets replaced and the new tire will have a warranty again, same procedure later...
    This is being wise in a negative sense ... it's taking advantage of goodwill ...
    Mar 2004
    #67
    hindi kasi sinisita.
    thread. tread.
    customer. costumer.
    brake. break.
    loose. lose.
    Because people would start saying that you're a grammar police ... tried making a thread about this ...
    Mar 2004
    #68
    Quote Originally Posted by Vodka View Post
    yep i know 10yrs is pushing it. but if car is mostly in covered garage away from sunlight and there's absolutely no damage or cracking (even just micro-cracking), up to 10yrs should be ok. that's michelin's recommendation anyway
    Do I need new tires? | When to change tires | Michelin US
    This is correct ... 6 years is for the average person who doesn't really take care of their vehicle ... it's same concept as change oil every 10,000 kms or 12 months ...
    Mar 2004
    #69
    that's the definition of sloppiness. pinoys can't be world-class if we're sloppy. this culture is so pervasive that's why everything pinoy is sloppy, just look around
    anyway, for top quality tires like michelin i'd feel comfortable using them up to 10yrs from manufacturing date, as long as there's absolutely no damage
    You should see how people in the U.S. can't even spell ...
    Mar 2004
    #70
    male pala spilling ko. pasentia na. 🤡🤡🤡
    It's mali, not male ... espiling not spilling ... pasensha not pasentia ...
    aren't you even a bit concerned that 95% can't spell tread correctly???
    why are we even having this discussion
    Maybe because you sort of put a negative tone into the topic ...
    Mar 2004
    #71
    My personal rule kung di kaya magpalit ng 4...
    2 muna and lagay sa harap... Luma sa likod.
    Place the tires with more grip at the rear ...
    Mar 2004
    #72
    You shouldn't even be using those tires if you are concerned they might blow up ...
    #73
    I try to rotate my tires regularly so that they will all need replacing at the same time. If I need to replace only 2, I put them up front, just personal preference. I find that they scrub in faster up front. But I drive as though it were a new car with brakes that haven't been broken in.
    If I suspect I may have misalignment up front I put them in the rear.
    #74
    I also rotate my tires so that they wear evenly and eventually I replace all 4 at the same time.
    My Kumhos are now at 35,000 km travelled and I'll probably replace them in the next 2 months. Eyeing the GT SX2 or Yoko Advan V701 - I want something grippy, I need something that lasts long.
    Feb 2015
    #75
    But on a tire blowout scenario, which is more survivable?
    Blown front tire or back tire?
    #76
    Quote Originally Posted by makelovenotwar View Post
    Front. You still have your steering to get the car back in control.
    A rear blowout is prone to oversteer which most people don't know how to react to.
    Feb 2015
    #77
    I see, thanks.
    Then new tires should always be on the rear.
    Jul 2013
    #78
    I disagree...
    Kapag likod ma-flat, mas madali icontrol yung car.
    Sa harap, biglang kakabig yung car sa direction ng flat tire.
    Wag ka lang biglang mag-brakes...
    i'd put the thicker tires in front
    Thicker tires should be in the front if ever the tires are for replacement already.
When Do You Replace Tires?
