Page 49 of 66 FirstFirst ... 3945464748495051525359 ... LastLast
Results 961 to 980 of 1303
    #961
    Good PM po;
    Just had my Hands-on lesson with Sir McGyver kanina umaga ...
    All i can say is nabawasan na ang takot kong 'matirikan' sa kalye ..
    Thank you po Sir Norman for sharing the expertise and being a
    nice person.
    Godbless po and More Power!!!
    Boi
    #962
    Quote Originally Posted by boineksdoor View Post
    Good PM po;
    nice person.
    Boi
    You're welcome, boi.
    You also have a nice ride. With regular maintenance, you're going to enjoy driving without the headaches and fears of stalling.
    Remember: practice makes perfect.......
    Jul 2010
    #963
    Good PM po;
    nice person.
    Boi
    [SIZE=5]Another satisfied VANETTER of MACGYVER!
    [/SIZE]
    Jun 2010
    #964
    Musta na mga ka vanette? may alam po ba kayong mabibilhan ng original thermostat? kasi nawawalan ng power yung engine kailang malakas ang pag tapak sa gas para hindi nanginginig ang engine from stop to 1st gear ito kaya yung cause ng malamig na engine? thanks!.
    OT: sayang di manlang ako nakapunta sa mga EB lalo na ngayon japan muna ako
    #965
    Quote Originally Posted by JoDee425 View Post
    Thank you po...
    Bukas po sana kung pwede Sunday para walang masyado trapik, mga 8am po para maaga kame delikado po kasi abutan ng overheat kapag inabutan ng trapik galing pa kami laguna,hehehe...May number po ba kayo?
    Naku bro.,- so sorry. Short notice,- busy kasi ang weekend namin dahil sa mga bata.... Were you able to visit their shop yesterday?
    How's your van now?
    11.9K:apple:
    #966
    Good PM po;
    nice person.
    Boi
    Quote Originally Posted by macgyver1432000 View Post
    Bros.,- we have to meet up with our colleagues up North, boineksdoor, macgyver and of course vanette747 one of these days....
    11.9K:apple:
    Jan 2011
    #967
    Ok lang, pulangred, as long as DOT3, pwede sya sa clutch.
    maraming salamat uli!
    by the way, may new problem nanman po ako... asan po ba nkalagay ang alternator belt ng vanette? twice ko na kasi pina-charge ang battery ko sa loob ng isang araw, plaging nadidiskarga. battery ba ito or alternator? ...kagabi pauwi ng bahay napansin ko pahina ng pahina ang ilaw sa mga dashboard ko pati ang headlight pawala din ng pawala ang liwanag. battery po ba problem or alternator?
    Thanks po!
    #968
    Quote Originally Posted by pulangred View Post
    Thanks po!
    pulangred,
    ang battery ay para sa starter. meaning, ang battery ay magbibigay ng power sa starter motor para ma-crank ang makina. once na umandar na ang makina, paiikutin na rin ng makina ang alternator.
    ang alternator naman ay nagpo-provide ng electrical power (ignition, lighting, radio, etc) sa buong sasakyan, kasama na rin ang pag charge sa baterya.
    di ba naipu-push start ang sasakyan na may manual transmission kahit patay na ang baterya?
    ang alternator ay matatagpuan sa front passenger side (engine bay)..so trace mo na lang yung belt. baka maluwag lang ito, try to add tension by using thumb pressure, try to judge na halos di na mai-press ng thumb mo yung belt, pero, wag naman masyadong tight...
    Jun 2010
    #969
    Question po bakit kaya malikot ang RPM ng van ko? pero hindi naman sya sobrang likot.
    Jan 2011
    #970
    Quote Originally Posted by aijie28 View Post
    TBI b to or carburetor? nangyayari ba to during idling lng? either way ung idle by-pass valve mo barado subukan u spray ng carburetor cleaner bka madala kung hindi magtatanggal ng throttle body or carburetor pra linisin,
    Jun 2010
    #971
    Quote Originally Posted by 650cc View Post
    yes po during idling lang. and kasama po ba dito yung pag on ng aircon bumababa yung rpm ng 700rpm then pag rev mo tyaka palang siya tumataas ng 900rpm.
    Jul 2010
    #972
    pulangred,
    pulangred,
    Ilang taon na ba battery mo? KUng lampas na ng 3 years baka sira ba battery mo at ayaw ng tumanggap ng charge. Pa-check mo sa battery shop kung oka pa yan.
    Kung OK pa battery, pa check mo output ng alternator mo. Dapat around 13-14 volts and output niya kapag umaandar. If not, undercharge lagi baterry mo.
    Palagay ko isa dito ang problema mo. Good luck BRO.
    Jul 2010
    #973
    Aijie,
    Normal lang na bumaba ang RPM mo kapag nagbukas ka ng aircon kasi meron added load sa engine mo. Kaya dapat kapag nag adjust ka ng idling naka bukas ang aircon!
    Jan 2011
    #974
    Quote Originally Posted by Vanette747 View Post
    pulangred,
    Salamat sir bumili na din ako ng bagong battery para sigurado... then after that, nalaman namin na hindi talaga nagkakarga ang alternator(stays on 12.3 maski tapakan ang gasolina) ...by the way, hirap pala kapain sa ibabaw ng silya mga belts hehehe, talaga po bang sa itaas or dapat sa ilalim diinan kung ok pa ang belt ng alternator? hirap dukutin e hahaha... kailangan ko ba itaas ng jack and unahan? Papatingnan ko din sa electrician bukas kung ok pa ang alternator. Magkano kaya paayos ng alternator? kailangan ko bang bumili ng surplus o kakalikutin lang nila yung alternator nito? Matatapos naman ito maghapon, right?
    haaaay naku, dami ko pa ipapaayos nagkasabay-sabay hehehe... may tagas ng langis sa brake system. tapos sabi ng mekaniko baka klangan ng ibaba ang transmission ...kasi minsan hirap mag-change gear(parang pakiramdam ko tumatama mga ngipin maski sagad na ang tapak sa clutch) ...then hindi ko alam kung battery related yung problem na parang mamamatay ang andar ko minsan(maski todo tapak na sa gasolina ...para bang nasasamhid) haaay naku! sana matapos na soon lahat ng problem ko sa sasakyan hehehe
    Magandang gabi sayo sir. Thanks uli!
    Jan 2011
    #975
    pulangred,
    very well explained... salamat uli sir! magandang araw sayo!
    Jan 2011
    #976
    guys ano bang tamang sukat ng PDC ng vanette? pwede ba tayong mag 16" tapos manipis na goma?
    thanks po
    Jan 2011
    #977
    pahabol pa mga sir... bakit may warning sticker sa ibabaw ng cover ng lagayan ng baterya "dont rotate the battery position, may cause electrical problem" ...may kinalaman ba yung pagkakalagay(position) ng baterya sa electrical system ng vanette? ...tama ba ako to say na oks lang position, basta yung positve nasa positive at yung negative nakakabit negative pole?
    thanks po
    #978
    pulangred,
    di naman ako nakikialam sa mga gastusin, pero, sayang, napabili ka tuloy ng bagong baterya.
    ang belt tensioner para sa alternator ay matatagpuan sa ilalim. kung mataas naman ang ground clearance ng vanette mo, eh, pwede na sigurong humiga ka na lang at palagay ko, madudukot mo naman yun.
    sayang lang..kung malapit ka lang dito sa amin, eh, matutulungan kita sa pag-repair ng alternator, kaso, ikaw ang magbabaklas, ikaw ang magre-repair at ikaw din ang magbabalik (hands-on lang yan)..guide mo lang ako..hehehe...sa opinyon ko, baka carbon brush lang ang papalitan sa alternator sabay linis na rin ng armature. wag ka na lang bumili ng surplus na alternator (pwera lang kung sira na talaga)..labor cost ng repair....siguro 350 yung labor at mga 150 yung pair of carbon brushes....pero kung sa akin...cost lang ng brush ang gagastusin mo..hehehe..
    may nabanggit ka na may tagas ng langis sa brake system mo? san banda?
    at ngayon, sabi ng mekaniko mo na kelangan na bang ibaba ang transmission mo? dahil ba sa hirap mag-shift ng gear? lam mo, may ginagawa akong test para masabi mo kung kelangan na talagang ibaba ang transmission. di naman kasi maja-judge sa hard shifting ng gear..baka naman may problema sa master cylinder na kelangan lang ng repair kit? or di kaya sa secondary cylinder...naku..hangga't maari sana wag muna tayong gumastos...
    #979
    thanks po
    tama ka, pulangred..positive terminal sa positive clamp..and negative terminal sa negative clamp. di mo pwedeng pagbaliktarin ito, dahil maraming masisira sa vanette mo gaya ng starting system, ignition system, car stereo, mga fan & blowers perhaps...kaya may warning sticker dyan sa cover ng battery compartment..
    Jan 2011
    #980
    pulangred,
    Maraming salamat sa concern sir ...oo nga e, mabigat din yung 4k mahigit sa new motolite gold battery ...
    Naku! gustong-gusto ko yang mag "hands-on" ako... minsan isang araw papasyalan tlaga kita dyan sa QC sir. Gusto ko talagang matutunan itong vanette inside out ...ibang-iba kasi sa dati kong "owner type jeep" at "sedan" e (at least yun hindi ako kakabakaba maski san abutin tumirik) ...pero ito naninibago tlaga ako hehehe.
    tagas sa brake system... dun ko nasilip sa front right side na gulong. Tapos tama ka nga, may tagas yung master at secondary cylinder... may napansin din akong pinong talsik ng langis sa fuse box. Maraming salamat tlaga sir sa tip!
    By the way, sana makapasyal na ako sa inyo soon ...novaliches area lang ako. Makabawi naman sa kabutihan mo maski papaano hehehe
    Gud evening uli sayo!
    Thanks
Nissan Vanette [Merged threads]
