Page 59 of 66 FirstFirst ... 949555657585960616263 ... LastLast
Results 1,161 to 1,180 of 1303
    Jul 2010
    #1161
    Wala abala sa akin Bro.CVT..Lahat sa VCP welcome dito sa bahay...Thanks for dropping by.
    *Mac PAsyal ka rin dito anytime...Miss ko na si 747!
    #1162
    Quote Originally Posted by Vanette747 View Post
    Oopppssss, ano iyang nami-miss mo na si 747?
    May nakita akong bagong "747" sa garahe mo, ha bro.?....
    14.6K:dj:
    #1163
    14.6K:dj:
    dapat sa place ni bro v747 tayo eb! Makita naman ung bagong boeing ni v747..set n ulit yan.
    #1164
    *V747,
    I know how you missed 747. He's with you for 15 years and served you a lot. But 747 gets more
    pampering with me, hehehe..don't worry..he's in good hands, and he will still perform what he was
    15 years ago.
    #1165
    Bros,- It looks like we have a lot of catching up to do....
    EB na ito!....
    14.6K:dj:
    Jan 2011
    #1166
    Mga Boss binubuo ko vanette ko 1997 model. baka po my alam kayo mabibilan ng goma ng salamin sa pinto saka ung sa sliding..
    Jan 2011
    #1167
    and baka sir my ma rereffer kayo na pwede mag buo ng vanette ko. kinalas kc lahat dahil piniturahan loob at labas.
    Feb 2012
    #1168
    Mga sir,
    Im just a newbie sa thread na ito and im very lucky to find this vanette club.
    I have a 96 model vanette na di ko na masyado nagagamit kasi po laging palyado.
    One thing i have noticed is that whenever na gumamit ako ng headlights bumabagsak ang menor
    hanggang sa gusto ng mamatay ng makina? Already replaced the contact point, sparkplugs ganoon pa rin.
    any suggestions po mga sir? thanks in advance.
    #1169
    Quote Originally Posted by filmor01 View Post
    Mga sir,
    Have you checked your alternator, bro.?.....
    There are voltmeters that you can buy from Concorde(LED lights-more cost effective- around P250-P300) or Tru Value (digital- more expensive- around P900) that you can insert in your cigarette lighter socket. You can now monitor the level of charging of your battery. Very useful....
    14.8K:cow:
    #1170
    Quote Originally Posted by jusper21 View Post
    Bro.,- original pa rin kasi ang mga goma sa salamin at pinto (pati sa sliding) ng aking 98Vanette.
    Maybe bro.shauskie can help you.
    However, I am almost certain that you can find these in Evangelista St, in Pasay... Diyan kasi ako nakakuha ng tail lights a couple of years ago.... :grin;
    14.8K:cow:
    #1171
    14.8K:cow:
    CVT's right. Your alternator is not giving enough current to your lighting system. Your alternator is or is not working, One way to check if it's working is that while engine is running at idle, remove the positive battery clamp from the battery. If the engine still runs, alternator's OK, but if engine dies, alternator's not giving current. If your alternator is OK, but problem persists, it means it's not giving enough current to your lighting system. Try to look for alternators with 90 or 100 ampere rating.
    Oh, before I forget, before checking the alternator, did you check the belt tension to your alternator? It may be loose.
    Good luck...
    #1172
    Quote Originally Posted by macgyver1432000 View Post
    Good luck...
    Ayun,- lumabas na ang isang jedi master (from the north), si bro.macgyver1432000...
    Kahit ano'ng klaseng tirik ng sasakyan,- kaya niyang paandarin at maiuwi.....
    Huwag lang flat (na gulong) na walang reserba....
    Kailan na (at saan) ang EB natin, mga bros?....
    14.8K:cow:
    #1173
    14.8K:cow:
    nagsuggest ako sa vcp site kung alin sa mga weekends this feb....
    #1174
    Good luck...
    *bro filmor01 add lang konti kay bro macg..dont rev your engine while battery is disconneted...baka mag over voltage naman if gumagana yung alty mo..it might damage some of your electronic stuff and accessories na nakaplug sa vanette baby mo...other technique you may opt to do is..
    1. start your engine then turn on your headlight to high beam. idle only...medyo baba ng mga approx 50 rpm idling mo dahil nagkaroon ka na ng load sa alternator.
    2. have someone or you to observe the headlight in front of vehicle.
    3. try to shut off the engine while headlight on.
    4. if headlight intensity drops or lessen it means your alty is working otherwise kulang nga ang current rating ng alty mo.
    to confirm bring your ride sa pinaka malapit or trusted car battery dealer to have your charging system checked.
    sa akin upgraded na rin sa 100 amp ang alty ko..good luck bro.
    Feb 2012
    #1175
    thanks sa lahat ng nagreply. i will do all of your advise this wikend. i am working kasi dito sa makati and every wikend lang po ako nakakauwi sa amin. sana nga po maayos na yung problem sa vanette ko.
    ill update you guys soonest.
    Jan 2011
    #1176
    Badly need help mga boss baka my kilala kayo or ma re refer na mekaniko mandaluyong area sa my p. cruz. ayaw kc humigop ng fuel pump ko. pero nung kinalas ko sya at nirekta sa battery gumagana naman.
    #1177
    Vanette Guru's & Chief's,
    Forgive me for interrupting, i'm not a Vanette owner yet but am considering of buying one. I would like to ask your expertise if owning a diesel Vanette (local, LD20 engine converted only) would be a good choice as a family vehicle. I once started a thread about changing my existing car to a van and one of our kind member suggested the Vanette diesel. I was amazed by his experiences and points given to the diesel Vanette. Also, given the low cost and good aesthetics of the "For Sale" Vanettes, I'm really interested. So, would like to know if its reliable, easy to maintain, abundant spare parts, etc. By the way, I live in Biņan, Laguna, and would greatly appreciate if you can mention if spare parts would not be a problem within my proximity.
    Thank you so much!
    #1178
    Sorry bro.,- sa grupo ng Vanette Club of the Philippines (VCP), wala kaming naka-convert sa diesel engine na nakausap na namin....
    15.0K:smoke:
    #1179
    Thanks Sir CVT!
    Feb 2012
    #1180
    ilan po top speed ng vannette
Nissan Vanette [Merged threads]
