Page 15 of 251 FirstFirst ... 51112131415161718192565115 ... LastLast
Results 281 to 300 of 5006
    Jul 2006
    #281
    I just got off the phone with Inav.ph, the reason why there is no option to download 2011 Montero Sport Navigation update 1.7a is because of the issue with accessing the SD card under the panel. They recommend to bring the car to your local car dealer or Inav office at Aurora Blvd Q.C.
    I'd really like to upload the new 17.a, but I am not very mechanically inclined I am fear I might break the clips. Sorry
    Jul 2004
    #282
    Quote Originally Posted by Slick50 View Post
    i would much rather have winterpine/iNav/mitsu dealer do the update so that if anything breaks, it is under warranty and will be repaired/rectified immediately
    when my original touch screen conked out, ayun it was replaced with a new touch screen. when the video playback acted up, a winterpine/41 technician did home service on my unit. ngayon everything is working fine
    May 2011
    #283
    Oww thank you Slick for going through the trouble of calling them. Your images are more than enough! Unfortunately, I'm here in Butuan City in Mindanao. Cheers!
    Jul 2006
    #284
    double post
    Jul 2006
    #285
    The image provide below is for reference only. Remove your panel at your own risk. As someone has mentioned it is better to bring your MS 2011 to a dealer or Inav for update.
    The 4 arrows indicate the location of the lock tabs.
    May 2011
    #286
    Here is my small contribution:
    The reverse cam inside a plate protector. This could somehow prevent theft. Downside with a cut-out cover is dust and water can go inside so had to drill holes under to serve as drains.
    Taken with an iPhone 4.
    #287
    Awesome pics slick.
    Medyo nakakatakot I-DIY, I'm sure mahal yung cover pag nasira.
    Question sa mga nag set-up na
    1. Pag nag attach ng Back up cam, san kinakabit sa LCD monitor o sa source HU sa baba?
    2. Pag nag attach ng headrest monitor, san nilalagay yung unique cables? sa LCD monitor o sa source HU sa baba?
    3. Pag nag set-up ng amp/processor, san ikakabit yung RCA's sa LCD monitor o sa source HU sa baba?
    Thanks,
    Jan 2011
    #288
    Quote Originally Posted by petixs View Post
    Awesome pics slick.
    Thanks,
    boss petixs, lahat ng external connections sa LCD nakalagay. more on sa volumen controller and DVD reader lang talaga function ng HU.
    Sa mga naglagay na ng rear cam, na try nyo na ba activate yun cam using the LCD menu? there is an option there for the camera, right? Mine is not working using that function, the camera button is always grayed out. Pag naka reverse lang talaga working. Had called AVT na and they are still checking this along with the no video output on the headrest monitors using USB as input. Sabi most likely meron software upgrade for the system to address these...
    #289
    Quote Originally Posted by MSviolet901 View Post
    Good day po.
    Ask ko po sana kung meron na sa inyo kumuha ng MS unit nyo from Union Motors?
    Any feedbacks po from this dealer?
    TIA
    We got our Montero VGT from Union Motors Paco last February10. Helpful naman yung agent (PJ Nubla) who assisted us. HTH.
    #290
    Quote Originally Posted by jayteecie View Post
    Quote Originally Posted by tuazon7 View Post
    *Tuazon7,
    Thanks sa reply, dun pala sa LCD part lahat, kaya balak ko, isang trabaho na lang paglalagay ng AMP/Processor, back up cam, headrest monitors...etc.
    Regarding sa USB problem mo, is it an isolated case o lahat tayo ganyan?
    BTW, any knows if we can add a TV tuner? any TV tuner would work , or ta has to be AVT?
    May 2011
    #291
    What USB problem, the fast forward? There's a slider which you can slide to the part you want to view.
    *Tuazon, same here, camera on screen always grayed out. The cam automatically works only on reverse.
    May 2011
    #292
    Quote Originally Posted by Sinoda View Post
    Thank you sir Sinoda for the feedback. Same din po ba yun sa UM, Caloocan?
    Jan 2011
    #293
    Pag sa USB nag play ng movie/video, walang video output sa headrest monitors, sa main touch-screen LCD lang meron. But okay siya pag sa DVD HU and iPOD. Mukhang lahat ganito as nag simulate na ang AVT and confirmed nila complain ko. Software upgrade daw but still on development...
    Jan 2011
    #294
    *Tuazon7,
    already inquired din po for a TV tuner but still waiting pa daw for the special cable na naman...need the cable for A/V input sa MID...
    Dec 2010
    #295
    Got my GTV from UM Kalookan. Am very satisfied with the deal. My SA drives a monty himself kaya lahat ng questions mo about MS kayang sagutin. I can PM you his number if you like.
    #296
    Mga sirs, I'm a newbie in this forum but has been a lurker for quite a while. Thanks po dami ko natutunan helped me a lot to create checklist prior delivery of unit. We checked for white smoke, complete sets of manual etc. Unfortunately I did not check for scratches on the car. This is our second car, we did not have trouble in the first.
    Hingi lang po ako ng opinion. My husband and I just had our GLS V gemstone gray the other day. Late na namin nakuha around 7pm. The next morning I noticed minor hairline scratches on drivers door, second row door and on the hood. Did anybody experienced this? What did you do?
    Some scratches are not noticeable, some i need to really ask my husband to look closely so he can see them, but some are noticeable whatever angle we look at it . Baka OC lng po ako or is it because ngayon lng kami nagka dark colored car na really visible yung scratches kahit very minor lng. Hay... Please help kung ok lang po ang ganyan? And what to do?
    Jul 2006
    #297
    Hi 07city.
    When I first got a car wash, I notice right above the GTV emblem I have a orange stain that looks like a number 7 (about 5 inches long going on a diagonal). I immediately called my dealer, they said they fix it during my 1K service. The tint job was also very bad, I also requested that they redo all the windows with multiple bubbles and folds.
    Regarding your scratch door. You might try to wash your car and see if it comes out. I washed my car this evening and I notice several lines that look like scratches, but will a little bit of elbow grease, I got them out.
    If however, they are real scratches you should ask your dealer to rectify it for you. You should bring your car as soon as possible back to the casa. They might say you were the ones that caused the scratches.
    Apr 2011
    #298
    Had OEM Montero back-up camera installed by CASA, cost is 6K... pricey but no worries with regards to warranty.
    Apr 2011
    #299
    Anyway, for those with GLS-V, CASA was offering me if I want to install the TPMS found in the GTV.... sabi sakin 15K daw, what do you guys think?
    Apr 2011
    #300
    dyan ako nagpa quote nuon last december, hindi sakin sinabi na meron lalabas na vgt model.....pilit binibigay sakin ung 2010 old model na montero with only a regular 10k discount...i am so very thankful for this thread and napag alaman ko na feb lalabas na un vgt model and lucky i got mine last march 18 with a 20k discount and free lto and other freebies (salamat sa citimotors alabang) someone here gave the SA's number and within a week release agad.
2011 Mitsubishi Montero Sport [continued]
