Page 14 of 124 FirstFirst ... 41011121314151617182464114 ... LastLast
Results 261 to 280 of 5006
    Mar 2011
    The 5-speed AT will have better fuel consumption. LSD is useful when driving on mud and wet or slippery roads.
    OK great! thanks.
    For the GTV owners po, what's your average consumption (km/l) ?
    Quote Originally Posted by renn114 View Post
    OK great! thanks.
    10.5-11 km/l
    Jul 2004
    OK great! thanks.
    during pure city driving at an average speed of between 10-15 km/h, i am getting between 6-6.5 km/l
    on last top up however using manual computation i got 8 km/l
    Hi ms owners! Recently got a montero gtv.. Need help. Im looking for lowering springs for my dad's montero. Its difficult for him to ride the car especially when riding in the middle row..Which is better between the two? Eibach or H&R's? Eibachs 1.5 inch drop then h&R's are 2 inch drop. Any of you have tried or had experiences with these springs in terms of the drop, ride and comfort.. Thank you.
    Quote Originally Posted by ulym View Post
    H&r
    -Ride comfort compromised
    -Front Rubber stoppers need to be trimmed down to give the suspension some play
    -modifications on the shocks mounting needed for front camber corrections
    Quote Originally Posted by zix888 View Post
    H&r
    Sir malayo ride ng h&r from stock springs? More information please. Thanks.
    Malayo sir ang difference ng ride. One more thing, your dad is going to be riding it, i dont think maappreciate niya ang ride with lowering springs. porma lang talaga sir.
    Apr 2011
    Sir sfm san pablo meron available gtv. Look for ms. rowena braga. Tel her refer ka ni john fom lucena. Sa kanya ako kuha glsv
    Finally makakapag-update na din ako ng map, got my sd card extension cable. Next time na may update, dont have to open up the panel again
    Just finished installing my sd card extension. Diy lang, mas may tiwala naman ako sa hands ko kaysa sa technicians nila, may lambing na kasama siyempre kaya all clips in perfect conditions. Navi working just fine
    Mar 2011
    Well done sir Zix. Congratulations!!
    Any tips in "properly" removing the cover without causing damage on the clips?
    All the clips are mounted horizontally, so horizontal motion of pull is a must, never upward. Start from the small opening on the lower portion between the cover and lcd screen, literally your fingernails touching the lcd screen for a start
    Mar 2011
    Noted sir Zix... thanks a lot.
    I hope with the new GTV, I would not be doing so much "tinkering".
    May 2005
    finally saw this post. looking forward to getting mine from sir prince. sir zix, the extension is just floating in the glove compartment or you used a double sided tape?
    Need help on setting up my reverse camera. Anyone who knows if there is a setting needed to be done to activate the camera? Tried to connect the reverse cam directly to the video jack just to test if its working, before laying out the wiring, and the camera sign didnt illuminate and rear cam didnt work. Tested my rear camera on my home tv and its working. I know it has something to do with the setting, style para maobligate ako magpagawa sa casa/winterpine, so if anybody there na may idea, it would really be appreciated. Wanna do the wiring myself para malinis sana. TIA.*
    Jan 2011
    You need to connect the HU reverse cable, pink color ata yun (pero meron yun label) sa reverse light supply to make it work. Suggest also to have the camera supply cable connected sa reverse light supply para hindi maginit. Pwede kang mag tap sa reverse light sa ilalim ng dash sa driver side, yun panel cover sa tabi ng footrest. Need to have a tester to know which cable to tap to habang naka reverse yun shift knob.
    Will connect the SD card extension sa Monday. Will let you know the wire color kung san ka mag tap, in case hindi mo pa nakita by then. The camera will work work during reversing, it will not work via the HU control, Hindi daw yun ready sabi ng AVT.
    Quote Originally Posted by tuazon7 View Post
    Okay thanks, will wait for your update, ayaw ko na magtrial and error, at least sigurado na ko kasi maginstall ka din pala ng extension cable, hintayin ko na lang info mo sir. Pasuyo na lang sir how they're connected. Thanks a lot sir
    Jan 2011
    mga sirs! saan nakakabili ng sd card extension cable?
    regarding the reverse cam you can ask tsikot shop how they did mine.
    Quote Originally Posted by md_alcapone View Post
    I got mine from china, taobao.com ( thats like ebay in china )
    *md
    Sir you use google translation din daw, medyo matrabaho nga lang
2011 Mitsubishi Montero Sport [continued]
