Page 137 of 251 FirstFirst ... 3787127133134135136137138139140141147187237 ... LastLast
Results 2,721 to 2,740 of 5006
    #2721
    Quote Originally Posted by tuazon7 View Post
    nice bro! anong klase yun seatbelt switch na inorder mo? and where you able na to open yun seatbelt mismo? check ko parang medyo mahirap buksan yun seatbelt lock without having scracthes...TIA.
    Bro itatabi ko na lang yung oem anchor lock, nagcheck ako mga spare parts ko and i found this, it came out from 2nd row seats of a fieldmaster(oem). It fits perfectly. A little mods lang, installation of switch and mounting. Mas madali buksan kaysa sa oem natin eh.
    #2722
    Sir zix paano po ba hanapin yung part numbers sa SMV?
    Sir sinubukan ko yung part no. Sa mitsuparts.com, not found, mukhang hindi yata part no. Yung makikita sa circuit diagram history(bottom) nung smv. Tried this seat belt switch MU801673, wala daw eh
    Feb 2007
    #2723
    Quote Originally Posted by zix888
    Yes sir, yun yata yung diagram reference number. The only part numbers i found so far are those for the special tools. ;)
    Parang there still some exe file that need to be installed para makuha yung part numbers.
    #2724
    Pwede din daw na ipabasa sa tech ng mitsu para makuha yung part No.
    Feb 2007
    #2725
    Quote Originally Posted by zix888 View Post
    I don't know if this can help..
    Auto Parts mitsubishi- parts directory
    This might be helpful if something can't be read. :-)
    http://translate.google.com/#
    Sep 2011
    #2726
    Sirs goodafternoon po, off topic lang.
    Bumili ako ng DRL, DIY ko po sana yung pagkabit. Gusto ko po sana, pag naka ON ang engine, on din siya. If OFF ang engine, off din siya. Saan ko po ba itatap yung device para ganon ang operation niya? hindi ko na lalagyan ng switch para less hassle.
    Thank you po.
    #2727
    better nga bro kung integrated na lang sa opened-door warning buzzer. pa share naman bro nung part number ng seatbelt switch. TIA.
    Plan B bro, sa reverse warning buzzer na lang, hindi pwede sa opened-door buzzer, nag turn on yung warning lamp ng opened-door tsaka since it is connected din to the speed sensor, kelangan pa magmove bago mag alarm
    #2728
    Negative Din sa reverse buzzer, 5 volts lang yung kelangan supply ng buzzer, mas madali kung separate na lang na buzzer. Okay na yung anchor switch, mounting na lang
    Jul 2004
    #2729
    kailangan talagang makita ang lahat nang na DIY nyo, i.e. steering wheel remote backlights, security light, side mirror led arrow lights, seatbelt indicator lights, atbp
    galing!
    Dec 2009
    #2730
    Sir zix pashare naman kung paano gagawin yung seatbelt lights at buzzer pati na rin yung parts na kailangan. Thanks!
    Jul 2004
    #2731
    puede nang mag co-author is zix at tuazon ng montero sport owners DIY manual
    #2732
    Kung magfit mga schedules natin with sir tuazon, pwede naman masilip yung mga diys
    #2733
    Quote Originally Posted by rjsc-mmc View Post
    Sure! Pm me your email ad
    Jan 2011
    #2734
    basta okay mga schedules, why not. but yung mga DIY ni boss zix ang the best to look into, dami na natapos
    Jan 2011
    #2735
    bro pa PM na din paano mo ginawa. still looking into sa OEM na anchor na meron ng switch, sa FM mo ba, same ang itsura ng anchor sa MS at meron ng built-in switch? planning to do this muna bago yung cruise control at paddle shifter...padating pa lang parts from TH
    Jul 2004
    #2736
    agree ako dito
    o sir zix, kailan ka puedeng dalawin dyan?
    hehehehe
    #2737
    agree ako dito
    hehehehe
    Schedule natin, tapusin ko lang itong seatbelt buzzer, naumpisahan na eh. Meet up na lang kasi kung sa place ko baka pati mga monty ninyo ma-idiy ko pagnangati kamay ko, hehehe
    Jul 2004
    #2738
    yan ang inaasahan ko, woootttt!
    my wishlist:
    1. backlit steering wheel remote controls
    2. led arrow indicator for side mirrors
    3. remote steering control power supply connected to the car's battery
    4. security light indicator on dashboard panel with corresponding blinking blue security light enabled
    yun lang naman
    hehehehe
    Jan 2011
    #2739
    bagong map update, pa-download na lang if you want it DIY instead sa 41 pa...
    www.inav.ph/download/MONT20.exe
    #2740
    Bro natry mo na yung file download? File corrupted yung unang nadownload ko, pero i-download ko na lang ulit para matry. Yung seatbelt anchor natin madali lang tanggalin yung plastic cover, ang mahirap lang eh kelangan tanggal yung seat before mo matanggal yung assembly, sasayad sa center console pag pinilit
2011 Mitsubishi Montero Sport [continued]
