Page 147 of 251 FirstFirst ... 4797137143144145146147148149150151157197247 ... LastLast
Results 2,921 to 2,940 of 5006
    Feb 2011
    #2921
    Quote Originally Posted by tuazon7 View Post
    sir si master zix yung nag post sa youtube on how to remove yung LCD cover. as for the disassembly ng center dashboard, medyo madami need baklasin sir, just need to be extra careful para hindi masira yung mga clips.
    need first sir to remove yung lower dash cover sa driver side and the glove box pati na din yun cover sa likod, be careful on the airbag connector sir. after that, need to remove again the LCD cover kasi meron 2x screw sa tabi ng LCD mismo. then remove the 2x screw naman sa ilalim na portion ng center dash. after that remove din yun cover ng down light muna before removing yung cover kasama ng cigar lighter. after all these, remove the 2x cables sa likod/ilalim connecting the A/C vent and temp controls. you can then carefully pull-out the center dash sir...
    Thank you very much sir! Will try to follow your instruction and hopefully makita ko ung kumakalampag at wag madagdagan pagkatapos ko gawin hehehe!
    Jan 2012
    #2922
    i just had a problem with my HU ... when i plug my iphone and play movies it has a sound but there is no display"BLAcK lang ung color" on HU can someone helped me?
    #2923
    bro got my OS updated today sa 41, it is V 3.1.65 na...replaced also my 1DIN, my DVD/Disc player is now okay again, back to full color...Will get back nga lang next week ulit for the steering remote, need pa daw nila order, requested for the 2012 version na, hehehe...
    Alright good. Update me on the audio remote bro, kasi wired yan, if bolt on, okay, pero kung may need pa na another piyesa from clockspring going to the back of the HU, okay na ako sa diy audio remote ko, so far its okay naman. Wala na din naman battery , mas malakas nga lang yung illumination compared sa cruise control
    #2924
    Had a tagaytay trip using unioil diesel, okay din wala din smoke plus smooth din ang engine. Good na dumadami na stations na pwede ko pag top up. Thanks for the info bro tuazon7
    #2925
    Quote Originally Posted by Seeyah14 View Post
    Sir okay na ba HU mo? Usually nagkakaganyan when from accesory tapos mag start ka ng engine, so nag rerestart din yung MIS, minsan ganyan din yung sakin, all working kaya lang blank screen. On off lang tapos okay na siya ulit. Kaya what i did naglagay ako ng capacitor, just enough na kahit mag start ka ng engine, hindi naiistorbo yung pinapanood mo or pinapakinggan mo na music
    Jan 2012
    #2926
    Quote Originally Posted by zix888 View Post
    ung pag off ng HU natin hold ko lang ung sa volume control? or may iba pa na pedeng pindutin? thx
    Sep 2010
    #2927
    sir Zix888 ok lang ba ask ko lang pano nyo ginawa yung pag lagay ng capasitor sa HU natin salamat po.
    #2928
    Quote Originally Posted by iceman777 View Post
    i was looking for a 10000Mf 16V capacitor from my "baol", but found a 10000Mf 50V, pwede din naman kaya lang if you are going to buy, mas mura yung 16V. anyway, just connect the wires (parallel), + to the battery supply on MIS, - to the ground of MIS, mas malapit sa MIS socket, mas maganda, para sigurado walang voltage drop on start-up ng engine.
    Oct 2003
    #2929
    good job for using heat-shrink tubing. clean!
    #2930
    Quote Originally Posted by smooth View Post
    Thanks bro, all my diys ginamitan ko ng shrinkable tubes para oem look
    #2931
    sana ganito din ang attendance pagnag EB tayo
    Jun 2007
    #2932
    Ayos ah. Saan yan, zix888?
    Sep 2010
    #2933
    Thanks sir zix888 sa quick reply. i will install one on mine also maraming salamat po.
    #2934
    Quote Originally Posted by EuroFD View Post
    Sa Thailand sir
    Dec 2010
    #2935
    mga Sir's question lang. Is it true that by next month another 15k price increase nanaman daw sa MS. ?
    Jul 2004
    #2936
    pag mag fun run ang MSCP, kayang kaya yung ginawa sa thailand
    Feb 2007
    #2937
    Nangyari na yan atty during the 1st anniversary in tagaytay..
    *borrowed from MSCP forum.
    More shots at MSCP events thread atty:
    Jul 2004
    #2938
    oo nga ano
    pero puede pang damihan yan pag may general assembly/fun run na
    Feb 2007
    #2939
    Batch 1 lang yan Atty out of 3! :twak:
    Mar 2012
    #2940
    hello to all members quick inquiry lang po regarding sa rv meter ng montero. has anyone have an idea if i can have it installed sa 2007 strada glx?if yes any info on how where and what do i need to have just to get this installed would be appreciated.thanks po
2011 Mitsubishi Montero Sport [continued]
