Page 134 of 251 FirstFirst ... 3484124130131132133134135136137138144184234 ... LastLast
Results 2,661 to 2,680 of 5006
    Aug 2003
    #2661
    lupit mo sir zix!
    Feb 2007
    #2662
    Quote Originally Posted by ek2jayvee
    lupit mo sir zix!
    Parang laruan lang Doc! Matyaga magbutingting;)
    Kung ganyan ba naman lagi ko kasama si Monty..baka napasubo rin sa mga DIY..
    #2663
    Quote Originally Posted by ek2jayvee View Post
    lupit mo sir zix!
    Mahilig lang talaga magbutingting sir ek2jayvee
    Apr 2011
    #2664
    husay pati kumuha ng Picture! :D hehe
    Quote Originally Posted by zix888 View Post
    Nov 2011
    #2665
    Finally my gps has been updated to latest 1.9a version ata.hehe grabe tagal kong inintay maayos naisip ko kasi isabay sa next pms hehe tyempo naman last saturday napadaan kami ng wife ko sa citimotors alabang,buti nalang andun ang technician ng winterpine.pinalitan ng memory card and antenna free of charge ang bilis hehe ginawa nya while we were inside the car hehe kaawa yung console binaklas.sabi niya ang cause daw ng hanging eh unang version pa ata yung naka install dati tapos yung antenna naman na bend maige yung wire kaya di maka kuha ng signal.
    Dec 2009
    #2666
    Just finished a diy, this is sir tuazon7's idea. Thanks bro
    Sir zix888 and sir tuazon7, pa pm naman po yung step by step procedure at kung ano ang mga kailangan. Gusto ko yung mga ganitong project. Thanks sir!
    Jan 2011
    #2667
    Quote Originally Posted by rjsc-mmc View Post
    sir rjsc-mmc, need mo gumawa ng circuit out of a 2N2222A transistor. tapos yun output/collector, connect mo sa Pin52 (red-yellow) wire ng connector C219 (gray) sa ETACS. Will PM you the circuit...
    Dec 2009
    #2668
    Thanks sir tuazon7! Basta magtatanong na lang ako ulit bro pag may hindi ako makuha. Pwede rin po ba pailawin yung astc? kahit always on basta nakailaw.
    #2669
    Fitted a switch with illumination(medyo madilim kasi masyado yung area ng side mirror buttons)Â*made a little adjustment on the position of the alarm led, plus replaced it with a red one to match the security warning lamp . Â* Â*So may naka-waiting nako switch, for next diy, hehehe
    #2670
    Mga bro check ninyo mga battery water levels ninyo, mine dropped its level a liittle over an inch (11mos old). So ibinalik ko sa dating level niya, almost one bottle din ng tubig ng battery ang naisalin ko. Sayang din kasi lifespan ng battery kung mapabayaan eh.
    Jan 2011
    #2671
    Have not look at that yet but doubt kung meron naka-abang na bulb/LED. Same sa rear fog lamp, had activated the feature (OEM setup thru the stalk switch) but there is no available indicator sa combination meter. Need to solder an LED to the meter's board pa to have it lit up...
    Feb 2007
    #2672
    Sir Zix di ba maintenance-free yung battery nyo? Haven't check mine yet...
    #2673
    Mas gusto ko yung hindi maintenance free, kasi makakadiskarte ka ng dagdag tubig eh, unlike pagsealed, walang choice
    #2674
    I think this is a better position of an alarm led, right there at the back of the HU cover. Mas visible kahit malayo, better give them 2nd thought right away habang malayo pa sila. Its like oem bk pajero alarm led. Synchro siya sa built in led Â*and "security" warning lamp.
    Jul 2004
    #2675
    galing talaga mag DIY ang mga montyneers dito
    kudos to you guys
    Aug 2003
    #2676
    Oo nga maraming magaling mag DIY. Ako Destroy-It-Yourself lagi.
    Feb 2007
    #2677
    Doc practice lang daw para ma perfect! ;) sabagay iba kasi practice nyo eh..pero marami naman po kayong DIY eh, di yung destroy ah...
    Jul 2004
    #2678
    yep, tama yan
    practice makes perfect
    kaya lang baka sa sobrang practice wala ka ng ma perfect kasi nasira na lahat
    hehehehe
    #2679
    Double post
    #2680
    Try this, cruising 100kpH, paddle + , you are now in no. 5, step on the accel.pedal as if you want to gain more speed without changing gear, let me know what your engine/tranny will do. TIA
2011 Mitsubishi Montero Sport [continued]
