Page 237 of 251 FirstFirst ... 137187227233234235236237238239240241247 ... LastLast
Results 4,721 to 4,740 of 5006
    Feb 2007
    #4721
    Dito sa bansa ng Langis sir!
    Sent from my Nokia 5110 using Tsikot Forums
    #4722
    Quote Originally Posted by zix888 View Post
    sakin 3plus liters nung nagddrain lang ng pan. sinusukat ko yung actual na na-drain, yun din ang amount na nilalagay ko
    Bos Zixx,
    Is it easy to replace the Tranny filter? I'm assuming there's only a single strainer filter? for the 4AT GLS-V.
    Thanks
    #4723
    Quote Originally Posted by petixs View Post
    Bos Zixx,
    Thanks
    yan ang ayaw ko gawin sir, kasi walang plug and play na gasket para sa pan. allergic ako sa gasket maker
    Sep 2011
    #4724
    Theres an fb mitsubishi nontero sport. Black yung montero niya. He/she posted pictures wherein they brought down the pan. Hinahanap ko din saan nakalagay filter e. Does it need to be changed every 40k din ba?
    Onga around 3+ liters for pan drain. Still have the containers here haha.
    Posted via Tsikot Mobile App
    Feb 2007
    #4725
    Post mo picture nya dito sir.
    Incase magbaba kayo ng oil pan:
    Sent from my Nokia5110i-VgT using Tsikot Forums
    bos saan niyo nakukuha iyong illustrations na iyan? may service manual kayo ng monty? pa-share naman ng link pls
    Feb 2007
    #4727
    Posted yung link sa PMS thread sir.
    Sep 2011
    #4728
    Link nalang sa fb niya sir. Naka mobile lang ako e
    https://m.facebook.com/profile.php?id=111752392198163
    Apr 2011
    #4729
    1st cycle (dark atf on the transparent tube)
    last(3rd)(new atfs are flowing out, same color as the new atfs , 3 cycles is enough)
    sir zixx, ano pagkaiba nito sa dialysis style ng pagpalit ng atf? mine is already 40k milage and planning of replacing atf for the first time.
    Sep 2011
    #4730
    Sir zixx, kapag hinugot mo yung atf cooler hose and inistart mo makina on N, automatic na lalabas na yung old atf? Since binangit dun na 3.5L, babantayan ko pa ba yun or kapag 3.5L na yung lumabas, wala nang mag flow?
    Sana magets mo sir haha )
    Balak ko kasi is kung free flowing ang daloy ng atf dun sa cooler, e ididischarge ko nalang lahat dun while naglalagay ng new one sa filler tube. Kapag iba na kulay yung lumalabas, off na ng engine tapos measure nalang.
    #4731
    Quote Originally Posted by babynos01 View Post
    nope! kasi yung level ng lines going to/from cooler sa tranny side is not same level sa bottom part niya. kaya hindi lahat madrain kahit paandarin siya. you really need to remove the drain plug. no short cut bro
    #4732
    yaiks..
    Madugo pala. kaya pala nung sinabi ko sa casa nung 40k na pati screen filter paltan, sinabihan ako na hinde pa advisable.
    Thanks Master.
    Feb 2007
    #4733
    Bro zix, i got the MD050317 instead for the DP GASKET. ;)
    #4734
    nice find!!!
    Feb 2007
    #4735
    Just found out that aside from adding to engine oil, this can also be used for transmission oils.
    Sep 2011
    #4736
    May I know why sir? Nababa na panu yung pan ko, yung "gasket" nya parang paste lng di kagaya nung sa EGR na bakal. Kailangan i strip yung nakadikit na gasket then may linagay na high temp silicone gasket ata
    #4737
    Quote Originally Posted by butchyboy View Post
    hindi ko lang sir type yung gasket maker, if may oem na gasket lang sana, sigurado ibaba ko din yan pag nagchange atf ako.
    my axles, feeling happy
    rear axle * 40k kms
    front axle * 50k kms
    transfer case * 50k kms
    #4738
    ^bro ok ba yung Top1 gear oil?
    Sent from my Nexus 7 using Tapatalk 2
    #4739
    sa transfer case ko ginamit. 50k kms tinakbo, okay naman
    Sep 2005
    #4740
2011 Mitsubishi Montero Sport [continued]
