Page 120 of 251 FirstFirst ... 2070110116117118119120121122123124130170220 ... LastLast
Results 2,381 to 2,400 of 5006
    Jul 2011
    #2381
    sir ano po bang okay na pampalit sa halogen bulbs natin? ayaw ko na ng hid eh. gusto ko halogen pero malakas ang output.
    Apr 2011
    #2382
    mukang okay yan sir Zix ahh, I just read some info of this from their official website...
    Let us know kung okay or same din FC mo after mo install nyan..
    [QUOTE=zix888;1850799]Dumating din yung sprintbooster at last, maikakabit ko na din together with the turbo timer, same area lang kasi yung location ng pag-iinstall-an kaya gusto ko sabay na ikabit. The sprint booster will be left of rear a/c switch and the turbo timer will be right of the cigarette lighter
    #2383
    [QUOTE=dhinster;1850833]mukang okay yan sir Zix ahh, I just read some info of this from their official website...
    Alright sir will do that
    Quote Originally Posted by zix888 View Post
    Nov 2011
    #2384
    Good day sir zix di ba on the fieldmaster meron po rear aircon filter,sa ms po kaya meron din?thanks
    Jul 2004
    #2385
    just updated my map to v1.9a and so far the gps does not hang when you press menu>destination>POI>P>A as reported earlier
    Apr 2011
    #2386
    hi sir prez, that's a nice update then... have to sched my map update too.. did you do upgrade yourself or thru winterpine?
    Jul 2004
    #2387
    Quote Originally Posted by dhinster View Post
    i had the map updated by the winterpine technician
    Oct 2011
    #2388
    Sir, how often or what is the interval in updating map?
    #2389
    Every 3 months mayroon map update, kaya talagang its a must ang sd card extension cable
    Jul 2004
    #2390
    next update is indicated in the gps itself (menu>settings>about, if i am not mistaken)
    it is in january 2012
    #2391
    Finished installing my sprint booster
    Jul 2011
    #2392
    Quote Originally Posted by KC Montero View Post
    its smooth, maganda hagod and quiet. when its quiet, means walang friction and walang gasgas. dito ko lang din nalaman about aerotwin blade. thanks to the nice gentlemen of the forum. for sure you'll like it. a lot better than original wiper blade, way a lot better...
    got my aerotwin wipers! astig nga.
    #2393
    As far as responsiveness is concerned, "malupit"!!! Still have to check on my fuel comsumption next top-up, well see what happens.
    Jul 2004
    #2394
    is that the same as the race chip pro and other performance/engine enhancing after market modules out there?
    #2395
    zix, programmed for montero sport na ba talaga siya? and do you have a picture of your turbo timer?
    #2396
    This is in addition pa sa race chip or common rail box. This is attached sa accelerator pedal, while race chips and common rail box naman are attached sa rail pressure sensor. Kung sa old school na may accelerator cable, di ba kelangan laging walang slack yun para walang delay sa acceleration, eto yung modern counterpart niya through accelerator pedal signal alteration para walang delay
    #2397
    so magandang upgrade pala ito sa lahat ng sasakyan na drive by wire na. whether gas or diesel engine.
    #2398
    Yup designed siya for montero and strada.
    Eto yung turbo timer ko,
    Pero hindi ko pa na-install, kinulang oras kahapon eh
    #2399
    Definitely sir CB, i strongly recommend sa mga drive by wire, whether gas or diesel. It has settings pa, pwede naka-off, medium, max.
    Apr 2011
    #2400
    Hello ulit sir Zix,
    Confirm ko lang kung ano yung size ng SD card ng unit natin? miniSD, microSD, or regular SD card?
    thanks again in advance.
2011 Mitsubishi Montero Sport [continued]
