Page 170 of 251 FirstFirst ... 70120160166167168169170171172173174180220 ... LastLast
Results 3,381 to 3,400 of 5006
    Feb 2007
    #3381
    Quote Originally Posted by zix888
    nice, mukhang finally nagkafree time ka bro. actually kahit hindi na lihahin yan, magasgas din naman sa gamit yan
    Oo nga sir zix, most of the time kasi busy pag nasa bakasyon.
    Got few stocks of the KEYFOB and new SD extension.
    #3382
    pm mo sakin yung keyfob, alok ko sa mga ka officemate ko
    Jul 2012
    #3383
    for those who have bought the non vgt manual variant, did u bought it through bank financing (bank p.o.)? were you prioritized? did you just show the bank p.o. then how long before unit got delivered?
    Jul 2011
    #3384
    Good day sirs, need help regarding oil leak coming from the intercooler hose. It is the rubber thick hose on the right side of engine coming from the intercooler in the front passing near the battery then going to a part near the engine cover. I am not sure what to call the part where the hose connects to but there is a switch with socket wires to its right, plastic black part.
    The oil leak is coming from the clamp of this rubber hose,has anyone experienced this?
    My monty is 4x2 2011 with 8000 km reading.
    Thanks., will try to post some pictures soon.
    #3385
    Quote Originally Posted by pacneil View Post
    normal. install oil catch can to eliminate it
    Sep 2010
    #3386
    Quote Originally Posted by zix888 View Post
    sir zix888 how much did you buy your oil catch can and where? i got my air bag reset through mut im lucky
    they did not charge me. thanks
    May 2007
    #3387
    *zix888, ok lang ba makita ng casa yan? wala ba ma-void na warranty? Thanks!
    Jul 2011
    #3388
    thank you sir zix for your help,
    if possible can you post a bigger pic of the engine so makita ko san nag connect yun oil catch can, not really knowledgeable sa mga ganito.
    thanks again.
    #3389
    thanks again.
    this is the pic without OCC, yung dalawang arrows, dun iconnect yung 2 tubes coming from OCC.
    *srguy
    sir matagal na ako hindi nag cacasa eh so i am not sure whats their stand on this.
    May 2007
    #3390
    Thanks zix for the reply.
    Ano brand ng OCC mo? how much? Ano diameter ng host ginamit mo?
    Sensya na daming tanong :D
    Jul 2011
    #3391
    *srguy
    *zix888
    last question, i noticed merun din oil sa mga inner bolt ng turbo ko, is this normal also? the oil is in between the two silver casings of the turbo dun sa brown/copper part, sa bolt.
    thanks
    #3392
    Quote Originally Posted by SRGuy View Post
    OCC tubings come in 9mm and 16 mm, may option. i used the 16mm, para same ng oem fittings. nabili ko siya sa tate
    *pacneil
    yes sir dun din galing yung oil, approx. 50ml of blowby oil is coming out in my 3000kms use, talagang diyan sa mga fittings maglalatak yan
    Feb 2007
    #3393
    This should be my next project. Mukhang kailangan na rin ni monty ng OCC.
    May 2007
    #3394
    Mukhang important nga yan OCC, bakit kaya di pa sinama yan sa stock engine?
    Gusto ko din magkabit pero baka after ng warrantly period na lang. Or kung madali lang, baklas muna bago pumunta ng casa :D
    Apr 2011
    #3395
    prince777, im interested sa mga ito. baka meron ka pang stock?
    i need 2x of the Keyfob and 1x SD extension.
    thanks...
    Feb 2007
    #3396
    Quote Originally Posted by enigma2036
    thanks...
    Sent you PM sir..
    May 2012
    #3397
    Sir Zix, yung OCC niyo saan niyo mismo minount? Dun ba sa may screw na naghohold nang ABS? Parang walang pwedeng pag mount sa may firewall. SO kailangan din icheck yung fittings kung 16mm? anong mangyayari pag yung smaller fittings, magkakatagas ba?
    *srguy
    #3398
    Quote Originally Posted by Arj_11 View Post
    hindi pwede dun sa abs, delikado galawin yun eh. an "L" mounting screwed thru one of the screws ng air filter box, exact yun
    May 2012
    #3399
    Thanks boss Zix! Mabuti pa nga dun sa screw nang air fiter box. Also anong klaseng tube ginamit niyo? Pang aircon ba yan?
    #3400
    i bought the hose from a nearby hydraulic shop. kelangan pareho diameter ng mga fittings to the of the oem, para direct plug lang yung hose on all ends, mas simple and hindi mo na kelangan adaptor. plus you can still use the oem clamps para oem look yung OCC mo
2011 Mitsubishi Montero Sport [continued]
