Good day po mga sir..newly acquired montero pa lng po kya wla pa po ako masyado alam regarding mods..sir zix mag inquire po sana ako regarding optitron, occ and egr blanking..TIA po
Maybe you need an adapter or the unit does not support rear camera input.
sir zix please txt me your shop adress and and phone. 0917-5879046
montero- egr blanking-optitron-cabin filter-oil catch can
Solution sa mga nag ha hanap Ng battery na 2354 Ang size for the steering control, expensive and hard to find Ang 2354 battery. Just use cr 2032 and stick 25cents na coin para maging makapal sya , presto May replacement na Mura ka na
Need your help guys..
Anyone can help me to locate where is the detect light wire (reverse gear signal) for montero stock AVT 6923 HU? TIA.
Back of HU.
Back of HU.
Good morning sirs, would like to seek your advice, i have a 2011 montero sport v, current odo reading is 140T, lately napansin ko na gas consumption ko lumas to 7.7 km. wherein in the past 9.5 to 10 ( combination slex and city driving), i have had the egr cleaned, gumaang ang takbo pero the diesel consumption malakas pa din, ano po kaya problema at bakit nagkaganito? kailangan ba pa calibrate na ? thanks for any advice mga bossing
linisan mo rin yung suction control valve kasi yan ang responsible sa pagkontrol ng fuel pressure. kapag malinis, better ang fuel delivery. linisan din ang air filter at MAF sensor para maganda ang higop ng hangin, mas maraming mahigop na hangin mas efficient ang combustion. subukan mo magpalit ng air filter like K&N para mas maluwag higop ng hangin. ipa-blank mo din EGR mo, makakatulong din yan sa combustion kasi kapag mas malamig yung hangin na papasok sa intake manifold, mas efficient ang combustion. you might want also to install bigger intercooler para makatulong din na lalong mapalamig yung intake air bago pumasok sa intake manifold. since 140k kms na unit mo, malamang saturated na ng oil yung stock intercooler mo so hindi na rin niya mapalamig masyado yung intake air. kapag maganda ang higop ng hangin at mas malamig yung hangin na papasok sa manifold, mas maganda pagsunog ng krudo kaya mas tipid sa kunsumo![]()
Sir zix88 pa pm naman cost ng change ng ATF para sa GLS V, K&N filter saka location ng shop?
Sir Zix,
Don't forget the fan belt, which sunny was able to notice at first glance. Napakingan lang din niya alam na ano problema.
Really felt the difference after your reccomendations. Looking forward to my next visit to have ball joints and timing belt changed.
