Page 20 of 251 FirstFirst ... 101617181920212223243070120 ... LastLast
Results 381 to 400 of 5006
    Jul 2004
    #381
    Quote Originally Posted by Slick50 View Post
    Hi GTV owners ever wonder why the output of your HID is so poor as compared to other car manufacturers?
    The projector is made of plastic, LMAO
    FYI the the bulb is OSRAM D2S - I've been trying to ask the different car dealers about the type of bulb our HID system uses but "mums the word" or perhaps ignorance.
    will check mine
    although, i do plan to change my fogs to HID yellow and just leave the headlights untouched
    OT: paging jedi, may yellow HIDs na ba kayo for the monty?
    Jul 2006
    #382
    From my observation the Fogs of the monty are completely useless. It only illuminates 3 to 4 feet of foreground.
    My decision for having my low and high beams retrofited is for maximum illumination and distance.
    May 2011
    #383
    Mga boss, got my GTV and I have a couple of questions, if they have been answered already, sorry for the re-post, can you provide the thread link?
    1 – How to use IPOD connector? The IPOD box is disabled and when I connect my ipod touch / iphone it plays in AUX mode.
    2 – What’s with the blue led for the alarm? Masakit sa mata pag gabi. May meaning ba?
    Overall, I’m still getting used to it. Naninibago compared to fort. And parang hirap when going uphill sa start then ok na siya. Once parang may kadyot pa.
    Jul 2006
    #384
    RE: Blue Led "always on" - you are in valet mode.
    RE: Ipod Cable - you connect the IPOD/USB cable to the USB slot (glove compartment). You connect your ipod/itouch/iphone to the elongated cable.
    Jul 2004
    #385
    Quote Originally Posted by vin81 View Post
    on no. 1 -- make sure the audio jack and usb jack are connected before connecting the other end to your ipod. if the connection is successful, the MIS ipod selector will light up and you are ready to use your ipod. if your ipod is connected but cannot be selected. check the software version of your ipod. make sure it is version 4.2. i had the same problem. the ipod i was using was still on version 2.2 but when i upgraded it to version 4.2, it works. you can also tell if the ipod connection is successful when an alert tone is sounded the moment your ipod is connected
    on no. 2 -- if the blue light is continuous, this means that you are in valet mode. why dont you switch to alarm mode to switch off that blue light
    as for climbing uphill, i did not have that problem when i went to tagaytay. in fact, because of the sport mode and paddle shifters, ascending and overtaking was easy. just takes a little getting used to the paddle shifters but once you get the hang of it, it is very convenient to use. now, i cant keep my fingers off the paddle shifters, herherher
    May 2011
    #386
    [SIZE=2]Thanks 111prez, slick50.[/SIZE]
    [SIZE=2] [/SIZE]
    [SIZE=2]For Ipod, kaya pala may kasamang USB yung IPOD connector, tama ba i-plug yun dun sa usb slot? Iniisip ko pa para san yun. [/SIZE]
    [SIZE=2] [/SIZE]
    [SIZE=2]For alarm, ganon kasi settings nung nakuha ko from casa. Paano po yun gagawing alarm mode?[/SIZE]
    [SIZE=2] [/SIZE]
    [SIZE=2]For uphill, I used D during that time. But will definitely try the spots mode and paddle shifters [/SIZE]
    Jul 2006
    #387
    There are dozens of guides already posted here how to arm and disarm the alarm of the monter sport. Please use the Search function. Tip use Valet Mode Montero sport
    Jul 2004
    #388
    [SIZE=2] [/SIZE]
    [SIZE=2] [/SIZE]
    [SIZE=2] [/SIZE]
    you need to have the usb and audio jack both plugged for the ipod to work
    May 2011
    #389
    Found the old posts,
    1. Press and Hold Red Button
    2. Insert Key
    3. Turn to ACC
    4. 1sec..2sec..5 sec still No beep....
    May mali po ba? How long should I wait for the beep?
    Jul 2006
    #390
    If no beep you should bring your car back to the Casa or bring it to Winterpine at Aurora Blvd. They are the one's who installed the Alarm System.
    Jul 2004
    #391
    2. Insert Key
    3. Turn to ACC
    i do it differently
    i turn on the key to acc or until all the lights in the instrument cluster lights up first
    then i press the button continuously until there is a beep
    if the light is steady, i am in valet mode. if i want to exit the valet mode, i do the same steps above until it beeps and the lights turn off
    works for me
    May 2009
    #392
    good day po,
    has anyone tried fitting a snorkel on the montero sport before or is there any in the market? also what roof box/bag can you suggest...thanks in advance po!
    Apr 2011
    #393
    To late - he started working on my quad setup this morning. lmao.
    hi slick, i hope you wont mind me asking if how much did the retrofit set you back.
    Jul 2006
    #394
    Hi Metslgx,
    The price depends on several components.
    A. Type of Ballast (China, Japan, OEM)
    B. Type of Projector (OEM, FXR, Mini D2s, Mini H1 and etc)
    C. Type of Bulb (Philips +82122, OSRAM, and etc.)
    So the price will vary like ordering set menus at restaurant. I recommend you do your research first at theretrofitsource.com and hidplanet.com Figure out what you want then message Garyq. He will send you a quotation.
    May 2004
    #395
    2. Insert Key
    3. Turn to ACC
    3. turn the key to 'ON' position
    that should work
    Jul 2004
    #396
    Quote Originally Posted by don View Post
    that should work
    turning key to "ON" position should be step 1
    Feb 2011
    #397
    mga sir sakto ba yung fit ng 3m nomad car mat sa monty?
    Sep 2010
    #398
    found out to have a faulty arbimeter (MID can not read distance travelled)
    winterpine change it with a new one. Solve the no data values on the left side of the MID screen.
    Jul 2004
    #399
    Quote Originally Posted by pogy_uy View Post
    that's the best, a brand new MIS
    May 2011
    #400
    got the beep. thanks!
2011 Mitsubishi Montero Sport [continued]
