Mda, thanks for the info.. I'll stay away from Concept Ones if that's the case. Mag ROTA na nga lang ako then. Will drop by Banawe (spel) sometime this week to check on the shops. I heard it's great over there.
make an offer sir, I still have my GT-A rims with me. I might consider selling it then. BTW, wala na yung tires sir.
I'd stay away from Concept One myself, too heavy! (in the pocket & in actual weight)
check => www.rotawheels.com
18's go for as low as 21k depending on the design, I can hook you up with a ROTA supplier myself.![]()
Since the GT-A came with a stock HID, I didn't bother changing the color as it would affect visibility (on my part). Stock kelvin temperature is 4300k.
getting the bluish hue is at least 8000k
white hue 6000k
what I did was, change the park light bulb to LED Super whites and changed the bulb of my foglamps to HID 6000k.
There are cheap HID's out there that could go as low as 2.5k.
Hope to help sir!
*Nautilus:
I've been browsing the ROTA link you posted... Sorry I'm such a newbie, but what are the specs that would make a specific model compatible with the Lancer EX?
Kapag 19" ata, masyadong harsh ride na sa EX? Saka I'm wondering how much (for 4 wheels na) ang entry level sa mga 19", for example ng ROTA? How about the 18", malayong mas mura kaya?
Dunno kung baguhan lang sa ganito, magkano ang usual na total budget dapat, at minimum, including the tires na.
Thanks!
Nautilus,
Do point me too to the right direction. Hook me up with ROTA Suppliers... My understanding is since limited pa ang info ko, ang ROTA Mags lang diba? Walang wheels?
widest rim you can use for the EX is 8.5 (ideally an 18x8.5 size; pwede din naman 19 but i would not recommend it)
offset should be from +44 to +48
tire size usually 235/40/18
Coming from Edsa, Ortigas while going south, after Magallanes Flyover, turn right * Evangelista (McDonalds & Jolibee landmarks) While in Evangelista look for Petron Gas Station (assuming you came from Edsa) it's on your left side. Then you will see WHEELHAUS look for Jo and mention my name "Macky" that I referred you.
All 2008 & up models
Lug pattern is 5x114.3
Lug nut thread/pitch - 12 x 1.5
Offset is 46mm.
Center hub is 67mm.
GT-A & GT
Stock tire size is 215/45/18
Stock tire is Advan Sport (forgot the model)
Wheel is 18x7
Weight of stock wheel/tire - 48 lbs.
Weight of stock wheel - 23 lbs.
MX, GLS & GLX
Stock tire size is 205/60/16
Wheel is 16x6.5
this being said, our lug pattern is 5x114.3, thus 4x100 lug patterns won't fit ours.
lowest offset for our EX is * +40
highest offset for our EX is * +48
19's would definitely fit (as I use 19's for my EX as well) yes it would be harsh, specially those road bumps, potholes, etc, you would definitely feel them. BUT with the right aftermarket suspension, you could definitely lessen the harshness of using 19's (what I did was order myself an aftermarket adjustable height & damping coilover to give my car a lower look without compensating for comfort)
to everyone inquiring about ROTA prices
18's = Php 25k - 33k
17's = Php 18k - 23k
19's no idea about rota price
VOLK Racing = 100k+++
Work Emotion = 100k+++
and many others
a set of 18's assuming * 25k +
cheapest tires * 18's (nankang) 5.5k each
ready yourself for about 45-50k with tires budget
The tires are A310. Pretty good tires, those.
Question/survey lang po: Yung mga lumalabas na bagong Lancer EX ngayon, meron na bang Auto-Up yung driver window? Sa akin kasi Auto-Down lang, medyo hindi ko lang ma-justify sa sarili ko bakit ganu't di pa nila nagawang Auto-Up... ganun ba kahirap gawin yun? Hehe.
mga sir, totoo po ba ang promo ng lancer ex gt-a? 100k down payment
http://www.mitsubishi-motors.com.ph/..._EOP_Flyer.pdf
kase nung tumawag kami sa citimotors, wala daw silang ganyan promo, sayang naman, balak pa namin kumuha this month
Regarding sa sound ng EX, I like it. Nothing horrendous or unpleasant, in fact I think it's more of a sporty-type.
Can't wait to upgrade my wheels and other mods. What price do you guys think would the stock 16 on the EX pitch? I'm planning just to trade them in for 18's in Roadstar Alabang.
Diamond Motors ung may ganyang promo... its a steal actually... when i checked upon computation if you avail a GLS variant for 85k dp, lalabas 200k lang lugi mo sa interest spread over 4 years. Free LTO, CM, Insurance pa... not sure kung acts of god... Kudos to Diamond Motors for this promo...
