Speaking of wood....
I like wood paneled ceiling . And floor to ceiling glass .
Warm...and opens up d space.....
Question lang, ilan psi dapat ang water pressure from the water consessionaire? Malakas ba masyado ang booster pump ko if naka set siya 30psi ON and 50psi OFF?
Sent from my ONEPLUS A6013 using Tapatalk
i do not know.
but i believe it is more of the pipe size and the pump's higop-ing ability, rather than the opening and closing psi...
if your current set-up is not giving problems, ok siguro.
but this is what i have.
i have a volume tank connected to my always-on nawasa, automatically turned off when the tank's float valve is reached by the water level.
then i have a pump that forces water from this volume tank, to my pressure tank. this ensures water in the upper floors of the house.
if nawasa is out, i still have water for some time.
I will probably start next year 2nd half. Short listing ideas and must have's / what to avoid.
Is this the one you're flipping bro? If it's a new build may I suggest getting started on the permits and other prep as early as now. And maybe start construction this year so you can avoid the start of the rainy season come June next year. That way if ever there are delays at least hopefully you'll just be finishing the interior when the rains come.
True ! Rainy season construction is a bummer.
