Page 51 of 71 FirstFirst ... 4147484950515253545561 ... LastLast
Results 1,001 to 1,020 of 1411
    Mar 2004
    #1001
    Grout perhaps? ...
    #1002
    Bai is there a sealant preferably in a spray can that I can use to seal this concrete? Our sink is sandwiched between a concrete slab and granite top and there seems to be a gap that lets water through from the edges.
    Sent from my SM-A605G using Tapatalk
    There should be a gap between top & concrete....use nothing less than Polyurethane Seal(not silicone). Preparation is key. Area should be clean of grease/dirt & dry prior to application. Sika, Bostik, even Pioneer now have em. Cure time must properly be observed. Liquid, i.e. Thompson's, won't likely work.
    How much would it cost to change a pivoting door with a sliding door? Is this allowed in condos?
    #1004
    you should best check with condo administration, on what you may do and may not do, to your own unit.
    cost: i do not know. sorry.
    Mar 2004
    #1005
    *travs
    Are you a building contractor?
    Mar 2013
    #1006
    Yeah same question.... and where r u based
    #1007
    *travs
    That sounds generically large. Just part of a small team of tech/craftspeople who still share that sense of foolish idealism, sir. Today's industry bar has been set more towards commerce than Standards like it should've always remained....A rarity to see builders build like it were their own now.
    Hope this helps to be understood better why I still shy away from CVTs.[emoji4]
    Bisdak country, sir.[emoji120]
    Hope this helps to be understood better why I still shy away from CVTs.[emoji4]Bisdak country, sir.[emoji120]
    One of the most entertaining tiktoks is from this Certified Professional Inspector - Inspector AJ
    Vast knowledge 🤯🤯🤯
    #1009
    Well. Was against my principles but we matched the highest offer and since the seller's SPA and broker is my good friend, they will sell to us.
    Money will never grow talaga in the bank. And you need nerves of steel to play stocks nowadays. So am biting the bullet and will pay their price.
    Build and sell for the first time for me and my wife. Usually i just focus on rentables for capital gain and some cashflow. This will be the 1st one that i am buying just to flip. Its a 400sqm property beside my village. Will try to build a duplex.
    Gonna keep my eyes glued on this thread for ideas.
    It won't depreciate bro...
    Jun 2015
    #1010
    Ano tawag sa ganitong turnilyo? Natanggal sa harang ng bunk bed. Papalitan ko sana ng mas malaki dahil nahugot na sa butas.
    Sent from my Nokia 6.1 using Tapatalk
    Jun 2015
    #1011
    Self-drilling or self-tapping ang other term. Tek screw I suppose is a brand name.
    #1012
    wally is right.
    self-drilling screw.
    but if you can use an ordinary nut and bolt...
    use washers if you have to...
    Walangdyo buhay ito hahahahahah
    #1014
    Magaling ka dapat tumala....😂😎😉
    #1015
    Is that for real or photoshopped? Parang yung sa Parasite but worse. Paano uupo dyan e nakadikit sa wall at nasan ang flush?
    #1016
    the shadows suggest that the image is real.
    but sometimes,
    things are not what they seem.
    sometimes,
    non-fecal wastes are more easily and effectively rid off by flushing them down the toilet.
    perhaps that toilet is not for the "usual human use".
    so kags,
    what is the label of the picture where you got it from?
    Jan 2016
    #1017
    Commonly known as tek screw nga sa construction workers at hardware
    Jan 2016
    #1018
    Tulo naman problema ngayon tag-ulan, ung lower roof ko halos walang incline, I know na hindi ito pwede sa asphalt shingles but I gambled kasi hirap makiusap dito sa developer to use other roofing materials. But I used bituminous membrane instead of felt paper, thing is, the contractor tinipid ako, binaon sa wall ung bitumen like a flashing tapos pinahiran ng plexibond. I would like to make wall flashing na yero as a last resort, i was thinking of sealing the corner between the concrete wall and the shingles with something like vulcaseal or better. But they say vulcaseal cracks eventually. Here are the seals I found at the local home depot.img_20201012_100000.jpgimg_20201012_100817.jpgimg-4bd9ec3ba4af750474de0e895983dcfc-v.jpgimg-d07d43bed297ea37c3664c6e082a3d11-v.jpg
    #1019
    May alam ba kayo supplier ng moving partition? Yung parang sa mga ballrooms ng hotels, pero smaller para sa bahay.
    Signature
    Sep 2010
    #1020
    There is no flush. De buhos kasi walang tank at the back e. Pag sumandal ka, diretso ka sa shower hehe.
House Constuction [Merged]
