Results 1 to 20 of 1411
    Aug 2004
    That's fine if you don't need to store anything that should be kept dry under. Though they look to seek no upkeep, the sublayer concrete is hygroscopic & requires thorough watertightening/sealing(periodic)....Molds & roaches love the dark & damp spaces below those tiled counters.
    Bai is there a sealant preferably in a spray can that I can use to seal this concrete? Our sink is sandwiched between a concrete slab and granite top and there seems to be a gap that lets water through from the edges.
    Sent from my SM-A605G using Tapatalk
    Mar 2004
    Grout perhaps? ...
    There should be a gap between top & concrete....use nothing less than Polyurethane Seal(not silicone). Preparation is key. Area should be clean of grease/dirt & dry prior to application. Sika, Bostik, even Pioneer now have em. Cure time must properly be observed. Liquid, i.e. Thompson's, won't likely work.
    How much would it cost to change a pivoting door with a sliding door? Is this allowed in condos?
    you should best check with condo administration, on what you may do and may not do, to your own unit.
    cost: i do not know. sorry.
    Mar 2004
    *travs
    Are you a building contractor?
House Constuction [Merged]
