Ooops ... sorry wasn't clear ... thought the sentence was complete ...
If you have NET metering and there's a power outage during the day, your solar panels are not allowed to deliver power since you are connected to the grid ... This is for safety of the power utility personnel that could be working on the grid near your house ...
NET metering is when you are connected to your electric company and selling your excess power to them ... also note that you do not get full value of amount you are selling to your electric company ... for example, if you are paying 10 pesos / kwh ... the power you sell are not credited as 10 pesos, it's much lower than that ...
They are used to installing solar panels to existing houses ... remember to factor-in cleaning charges every 2-3 years ... they charge per panel ...
True ba na nakakatipid pag solar? Yan kasi ang selling point nila palagi. And the payback period of 5-6 years parang hindi rin realistic. Wala kasi nagpopost ng actual figures puro claims lang. And silent din sila sa maintenance costs. Parang based on the available infoi get, I can make a rough guess na at least 10 years ang payback and that is if you're lucky enough na walang masisira sa panahon na yan, whether due to parts failure or AON. Para siyang Starlink, it only makes sense kung nasa lugar ka na walang serbisyo.
Pareho din pala tayo ng concern about potential leaks sa bubong. I'm sure the installers will not care to make sure na pulido ang kabit at walang leaks. May guarantee nga pero perwisyo rin ung pabalik balik sa bubong and ung frequent tapak ng tao contributes to the weakening of the roof itself.
Mas mabilis ang ROI if you apply for net metering. Yung sa akin hindi pa active yung net metering, pero nakakabit na ang meter, so i-credit din lahat ng exported electricity ko pag pumasok na sa billing ang net metering.
So far, naka tipid ako ng 40% sa electricity bill ko after nakabit ang solar. Pag mag start na ma-credit ang net metering, mas malaki mabawas sa bill ko.
Signature
Pareho pala kami ng thinking ni Shadow, but hybrid pala ang set up, parang may voltage regulator, pag na sense na kapos, papasok si Meralco. But then kung may outage pwede kaya gamitin for as long as pasok sa voltage supply nya. Alam mo naman more or less kung ano ang kaya nya i-power up, so you make a conservative load lang, like 1 or 2 electric fans lang, or 1 aircon if you oversized your panels.
Or baka konting kulimlim lang, voltage drop agad?
Will it do immediate damage, hindi ba pwede mag reduce ng load once nag outage? Dumadaan pa rin ba sa panel so you can just flick the breakers off and then flick on pag na adjust mo na load [emoji28]
